About forward slips
Old October 31st 06, 07:35 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default About forward slips
What's the proper procedure to execute a forward slip, how should the
aircraft be expected to react when it is performed, and what are the
main uses of the forward slip? And why is it called a _forward_ slip?
I've been reading about this, and from what I understand, the
procedure is to roll to one side and hold the rudder to the opposite
side. I've tried this in the sim. The aircraft rolls to the side I'm
rolling it to, and then seems to slide downward almost in the same
plane as the wings, only a bit steeper. Altitude is lost very quickly
indeed, but airspeed stays steady. Is this what happens in real life?
Am I doing it correctly? What's the correct procedure to return to
level flight?
Somebody said that MSFS cannot simulate forward slips correctly. What
is missing in the simulation?
Note that, by default, MSFS is configured to link the rudder to the
ailerons. All turns are forced into coordinated turns, and there's no
independent rudder control. This can be turned off to improve
realism. But with this default option enabled, it's impossible to
perform any maneuver that requires rudder control independent of
aileron control.
Old October 31st 06, 07:52 PM posted to rec.aviation.piloting,rec.aviation.student
Gary Drescher
"Mxsmanic" wrote in message
http://www.faa.gov/library/manuals/a...lane_handbook/
Old October 31st 06, 09:36 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
"Gary Drescher" wrote in
He won't read it :-(
Allen
Old November 1st 06, 02:40 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
A Lieberma writes:
Wrong tense. He had already read it. But he hoped that someone here
might have something useful to contribute. Perhaps that optimism was
without justification.
Old October 31st 06, 08:45 PM posted to rec.aviation.piloting,rec.aviation.student
gatt
A forward slip is a way of losing altitude rapidly without gaining
substantial airspeed, essentially by placing the airplane in a stable
condition in which the wings are less-effective. Another use of a slip is
to align the aircraft with the runway during a crosswind.
Executing a forward slip, for its most basic flight-sim-type purposes,
involves lowering one wing with the aileron and using opposite rudder to
keep the aircraft oriented; it can be dangerous at slow speeds because the
crossed controls create a perfect condition for spin entry on a stall during
short final.
The oppose rudder (if left wing is dipped, right rudder is applied)
introduces drag as the tail is no longer aligned with the direction of
travel, and the airflow comes over the wing at an angle instead of direct,
reducing the component of lift across the airfoil.
Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall
and 3) Don't stall.
-c
Old October 31st 06, 09:09 PM posted to rec.aviation.piloting,rec.aviation.student
Grumman-581[_1_]
and 3) Don't stall.
And ...
4) The ground will catch you...
Old October 31st 06, 09:37 PM posted to rec.aviation.piloting,rec.aviation.student
Stubby
short final.
and 3) Don't stall.
Right. The first turn of a spin will lose about 500' or more. Not good
if you are pulling from a long base to final. And, you probably won't
have enough rudder to get it out.
Old November 1st 06, 12:07 AM posted to rec.aviation.piloting,rec.aviation.student
and 3) Don't stall.
When I slip to landing, I always crank in some small forward (down)
trim just in case I get distracted. Am I the only one that's this
paranoid?
Kev
The smell of a decomposing mouse somewhere forward of the firewall Peter R. Owning 23 February 1st 06 03:52 AM
What is a "Forward Skip"? Gary G Piloting 57 January 7th 05 10:09 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
B-17 forward guin positions zxcv Military Aviation 13 March 16th 04 12:04 AM
Forward Swept Wings Canuck Bob Home Built 16 October 3rd 03 05:50 PM
