Is it possible to switch from VFR to IFR and back?
Old November 26th 06, 06:57 AM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Default Is it possible to switch from VFR to IFR and back?
Mxsmanic wrote:
Ron Garret writes:
Then you are missing something very fundamental: there is more to IFR
flight than simply flying by reference to instruments. It is also
flying according to a much more rigidly planned and stylized repertoire
of routes and maneuvers designed to keep you from hitting not only other
airplanes but also (and more importantly) terrain. That is why even
instrument-rated pilots flying instrument-equipped planes die on a
regular basis as a result of VFR flight into IMC.
If you have the right instruments, and an instrument rating, and ATC
to provide separation, why would it be dangerous?
Because ATC only provides separation from other airplanes. It does not
provide separation from terrain. Also, with VFR into IMC situations you
often don't have contact with ATC. So you have to get out your chart,
try to figure out where you are (not all planes have moving map GPS),
find the right frequency, dial it in, call them up, wait for a
response... and all the time you have to fly the plane without being
able to see where you're going. It's not so easy in real life as it
might appear in a sim.
I know that most IFR flights are rigidly planned, but it appears that
they don't have to be. You need to know where you are and where you
are going, but you don't have to plan every detail in advance.
And what will you do if your GPS fails?
That takes time. How are you going to keep from hitting things in the
meantime?
All it takes is a call to ATC.
No. ATC does not provide terrain separation.
If you already know your instruments
and you already have your navaids and what-not set up, you already
know where you are and where you are going, irrespective of what you
can see out the window.
Those are all big IFs.
You just look out the window for separation
and as an additional sanity check on your navigation, or just for
sightseeing. If visibility drops, you're covered, except for
separation--whence the call to ATC when you approach IMC.
Sure. But you keep switching the topic back and forth between "when you
approach IMC" and when you are IN IMC. Those are two very different
circumstances.
Flying using instruments is NOT the same thing as flying IFR.
What are the differences? ATC provides separation and guidance for
IFR flights, but besides that, what changes?
The major differences a 1) in IMC you cannot rely on your peripheral
vision. This makes a much bigger difference than you might imagine (and
you can't experience it in simulation unless you have a lot of
monitors). 2) approach to landing must be done in a much more stylized
and pre-planned way in order to avoid terrain that you can't see. 3) if
you don't have a moving-map GPS you have to twiddle a lot of knobs in
the right way at the right time, which adds to your workload. The
combination of all three of these factors makes for a very different
experience.
rg
  #62
Old November 26th 06, 11:52 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Garret writes:
If you know your position and altitude, charts will provide you with
separation from terrain. There are probably moving-map systems that
will do the same, although I'm not personally familiar with them (it's
certainly feasible to a large extent).
Also, with VFR into IMC situations you often don't have contact with ATC.
You call them when you see the clouds or fog coming.
So you have to get out your chart, try to figure out where you are
(not all planes have moving map GPS), find the right frequency,
dial it in, call them up, wait for a response ... and all the time
you have to fly the plane without being able to see where you're going.
If I'm flying the plane, I'll already know where I am based on
instruments, irrespective of weather conditions. I'm not going to
start looking at the chart and instruments only as I approach the IMC.
Additionally, I'll avoid aircraft that do not appear to have
instrumentation adequate to make IFR flight safe and reliable (in
addition to legal).
It's not so easy in real life as it might appear in a sim.
Maybe. How much of it have you done in a sim? I wouldn't call
instrument flight in a sim easy--most sim pilots don't know how to do
it.
Since I'll already know the nearest VORs and I'll be tuned to them, I
can go with that. I often do, anyway, as it's sometimes easier than
fooling with the GPS.
However, if all radio navaids fail, I'm in a bit more of a quandry, as
I have very little experience so far with dead reckoning.
Fortunately, it's relatively unlikely that I would have a total
failure of all navaids at the same time that I happen to get stuck in
IMC. And, by definition, if you have no instruments, you cannot fly
IFR.
I can provide terrain separation myself. In most cases I will already
be thousands of feet above the highest terrain in the area, out of
sheer prudence, and I have charts and navigational equipment to tell
me where I am and how high the terrain below happens to be. I only
need ATC for separation from other aircraft (TCAS helps in this
respect, but I'm assuming I wouldn't have that onboard, and it's not
100% reliable). Hopefully I'll have a radar altimeter, too, although
it's only useful in certain situations.
That depends on your personal policies as a pilot. If you routinely
make use of instruments to verify your position, you'll already know
where you are if you lose visual contact with the outside world.
You'll just have to be a bit more careful since you won't be able to
double-check anything visually. And you'll need ATC to help you stay
clear of other aircraft.
circumstances.
Visually, yes. But depending on how much you routinely use your
instruments, it might not be that much different in other ways.
I might well look for landmarks out the window in good weather. But
that would not prevent me from keeping track of a VOR or two, and
looking at the GPS display or EHSI occasionally to make sure that all
information sources agree on my position. If I see unavoidable IMC
approaching, I call ATC for separation services, and I watch my
instruments more carefully.
One of the things I like about aviation is that it _is_ possible to
fly without any external visibility at all (excluding landing and
take-off, which are special circumstances). All you need is a few
instruments, a couple of charts, and knowledge of how to use them. I
find it fascinating that I can fly for hours with nothing but fog out
the window, then descend below the weather and see a runway directly
ahead of me, _exactly where the instruments and charts promised it
would be_. It is very reassuring. It proves that if you follow the
rules, and you are careful and diligent, and you know your procedures,
you can always find your way home. Ultimately the only thing you have
to worry about is other aircraft ... and that's where ATC comes into
play.
vision.
If you are flying with instruments, you're not relying on peripheral
vision, either.
If you are flying with instruments, visual contact with the outside
world is only one of several sources of information. It helps you to
make sure that all is well, but if it abruptly becomes unavailable,
you still know exactly where you are, if you know how to use your
instruments.
In anything other than the severest of clear weather all the way to
the horizon, in the daytime, I'd be nervous relying on visual cues
alone. If it were required for a test, I could do it, but left to my
own devices, I'd look for confirmation from instruments and charts.
Mountains and rivers tend to look the same after a while; I want to
know if that twisty little river ahead really is the one that I think
it is before I try to follow it home.
monitors).
I can "turn my head" in a sim, but it is true that visibilty is in
most ways much more limited than in real life (although I can look
directly backwards in the sim, whereas the aircraft would block much
of my view in real life).
That's how I land already. I consider a purely visual landing to be
sloppy. I always check the instruments to see if I'm really at the
altitude I appear to be at, if I'm really aligned as I should be, and
so on. Even in perfect weather, I may still be tuned to the ILS for a
straight-in approach, just to make sure that my glide path and
alignment agree with the instruments.
Additionally, I always try to navigate in a way and plan ahead in a
way that allows me a straight-in approach. I'll fly a pattern if I
have to, but otherwise straight in is preferable. Even for flying a
pattern, I'll check instruments.
3) if you don't have a moving-map GPS you have to twiddle a lot
of knobs in the right way at the right time, which adds to your
workload.
Yes, but planning ahead seems to help a little. It makes me nervous
if I don't have at least a VOR or beacon or something that I can use
to double-check that I really am where I think I am, no matter how
familiar the view out the window might be.
I like to be sure that the little airstrip I see up ahead really is
the airstrip I'm looking for. I'm especially vigilant about this
because I understand that airports are hard to recognize in real life,
even though they are already hard to recognize in the sim.
The combination of all three of these factors makes for a very different
experience.
If one flies purely visually and is suddenly thrust into a situation
where visual information is unavailable, I can see how panic would set
in. But if one is already scanning instruments with an awareness of
one's position derived therefrom, a sudden transition into low
visibility should be far less stressful.
Some pilots are willing to fly aircraft that don't provide the minimum
necessary for instrument flight, but I don't think I'd be very
sanguine about trying that myself, no matter how great the weather
might seem. I spend a lot of time thinking "what if?"
  #63
Old November 26th 06, 03:30 PM posted to rec.aviation.piloting,rec.aviation.student
Newps
We most certainly do.
  #64
Old November 26th 06, 04:20 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
You always have separation from terrain, as long as the legs on your desk don't
collapse.
You fly a computer, man. Get over yourself.
  #65
Old November 26th 06, 04:42 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
vision.
vision, either.
You'd be surprised.
monitors).
Not the same thing at all I'm afraid.
Indeed.
experience.
Less stressful to be sure. But you'd be amazed how different it can be
if you really can't see out the window and your (real not simulated)
life is on the line.
Southern California in the summer is pretty safe for VFR flight.
rg
  #66
Old November 26th 06, 04:45 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Not if I pop up in some random place you don't (which is the situation
under discussion).
rg
  #67
Old November 26th 06, 06:10 PM posted to rec.aviation.piloting,rec.aviation.student
Christopher Brian Colohan
Disclaimer -- I am still a student pilot, so take what I say with a
grain of salt. :-)
Mxsmanic writes:
AFAIK, the majority of GA planes have neither radar altimeters nor
TCAS. Those are much more common on jets. Most jets are flown
commercially, and commercial flights amost always fly IFR from takeoff
to landing, no matter what the weather. Your assumptions may be a
little off...
Quick confirmation is okay. But if you are flying either IFR or VFR
in VMC, you probably don't want to keep your head in the cockpit too
much -- your primary responsibility is to look outside to avoid
hitting other planes. Even in the best weather spotting other planes
is hard, if the weather is less than optimal you need to be looking
even harder! That is no time to be focusing on your instruments --
you can only do that safely if you have ATC keeping the other planes
away from you -- and you can only assume ATC is able to do that if you
either flying in IMC (and so can assume no VFR traffic) or are in
airspace where ATC provides separation for all planes (not just IFR
traffic), such as class A or B airspace.
Bad or marginal weather is usually pretty easy to spot from a
distance. If you are flying a plane without an IFR rating, or without
IFR equipment, the trick is to just avoid the bad weather. Is it
foggy? Don't fly. About to rain, and may rain hard enough to
obstruct vision? Don't fly. Storm front between you and your
destination? Turn around or land. If you are conservative in your
flying decisions, the dreaded "visual flight into IMC" will never
happen. The trick is to have the judgement and willpower to remain
conservative, and to keep your margin of safety and resist the urge to
fly... (And if you want to fly more often in worse weather, first
acquire the necessary training and a better plane.... Of course, this
can cost big $$$...)
Chris
  #68
Old November 26th 06, 06:23 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Garret writes:
You'd be surprised.
I'd be in danger. If there's nothing but fog outside the windows, how
is peripheral vision going to help me with the instruments? Which
instruments are in my peripheral vision?
No, I would not be amazed. But I would try to be calm. Pilots die
when they cannot remain calm.
Sometimes, when listening to CVR recordings, I notice that the pilots
who ultimately survive sound a lot calmer than the ones who don't,
even in situations of equivalent risk. Transcripts show the same
thing.
That's one reason why I fly there in the sim, although much of it is
just the fact that I'm familiar with it. Arizona is similar. If I
need a challenge, I move up near Seattle. If I need a nap, I visit
the Great Plains in clear weather.
  #69
Old November 26th 06, 06:24 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
Christopher Brian Colohan wrote in
grain of salt. :-)
snip
distance.
Hi Chris,
The above is not necessarily true. Especially when the weather is
developing GRADUALLY. I have seen it gradually go from severe clear to
MVFR especially in the summer time and when haze is involved.
It's the gradual phase is what will catch you off guard. I have flown
many times where viz is greater then 10 miles and by the time I get to my
destination, viz reduces down to 2 to 3 miles. Only thing noticeble at
altitude is the forward visibility getting less and less on the ground,
as more often then not for me, it's severe clear at cruise altitude, but
milky white on the ground references, gradually getting worse and worse
as you proceed.
Just a word of advice.
PLEASE avoid responding to Mxmaniac. He is a resident troll.
Just look at his posting history and you will clearly see what I am
talking about. THANKS!!!
Allen
  #70
Old November 26th 06, 06:44 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Christopher Brian Colohan writes:
TCAS.
That is my impression, also. The Baron in my sim has a RA, and it
does in real life, too (from pictures I've seen). But it's an
expensive aircraft. In sims you always get the deluxe versions of
every aircraft, with all the options.
distance.
I've heard apocryphal stories of sudden changes that produce fog from
nowhere, but I don't know how reliable those stories are.
can cost big $$$...
[sigh] Everything costs big bucks in aviation. If automobiles were
like planes, most people would be driving go-karts to work.
