Spooky flights
Old January 28th 07, 05:34 PM posted to rec.aviation.piloting
Mxsmanic
Default Spooky flights
Sometimes some people get spooked when driving out in the middle of
nowhere (especially the desert southwest of the USA) for various
reasons. Obviously darkness, isolation, and a lack of signs of
civilization and humanity can play a role in getting one's mind to
wander in the wrong directions. These must all be greatly magnified
when flying alone at night in relatively unpopulated regions.
Have any of you ever been slightly spooked while flying alone? (And
are you prepared to admit to it?)
They say the area around Groom Lake in Nevada is particularly prone to
do this. I recall someone else mentioning being out in the desert and
the only noise was the eerie sound of power windmills that went on for
miles, and after a while that got to him. I recall being on a hill
once (on a cycle, not in the air) and accidentally thinking about
stories of alien abductions, and reflecting on the fact that I was in
exactly the situation that most abductees described when the little
green men came to call. That was a mistake, but I did make unusually
good time getting back into town.
A related question is whether or not you've ever seen anything in the
sky while flying alone at night that truly did not match any type of
airborne craft you could think of.
Old January 29th 07, 05:40 AM posted to rec.aviation.piloting
Allan9
Think about what you see or think you see while working in a contro tower at
night
Al
"Mxsmanic" wrote in message
Old January 29th 07, 08:19 AM posted to rec.aviation.piloting
Roger[_4_]
On Sun, 28 Jan 2007 23:40:53 -0500, "Allan9"
night
Visions of a nice soft, warm bed.
www.rogerhalstead.com
Old January 29th 07, 12:20 PM posted to rec.aviation.piloting
Mxsmanic
Allan9 writes:
night
I had not considered that. I suppose if one is working the tower
alone at night, and there's no traffic, and one is in an isolated
area, one might get a bit spooked at times, especially if things other
than recognizable aircraft appear in the sky. But at least you can
readily leave the tower if necessary (although I guess the tractor
beam of the Borg could still sweep across the parking lot and snatch
you up). In an aircraft, you can't just open the door and get out
while in flight, so if you get a chill down your spine or a bright
green light starts scanning the cockpit, you're stuck.
Old January 29th 07, 07:24 PM posted to rec.aviation.piloting
Orval Fairbairn
Mxsmanic wrote:
Allan9 writes:
at
night
If that bright green light starts scanning your cockpit, DON'T LOOK AT
IT!
It is probably a green laser, with which there have been several
illuminations of aircraft, with temporary to permanent eye damage.
The son of a friend of mine had it happen, although his eye damage
appears to be temporary. The crew in the plane behind him nmay have
permanent damage, however.
Old January 29th 07, 08:03 PM posted to rec.aviation.piloting
Mxsmanic
Orval Fairbairn writes:
IT!
Unfortunately, laser beams are so thin that you might not notice it
before it hits you.
Were they really green lasers? Did anyone ever find out who was using
them?
What was the situation?
I recall a rash of these attacks (because attacks is what they are)
some time ago, and then it seemed to quiet down. Unfortunately, I
can't think of any simple way to protect against laser attacks.
Throwing anyone who does one into a Supermax might serve as a
deterrent, though.
Old January 29th 07, 09:18 PM posted to rec.aviation.piloting
Tony
MX offered the opinon that
"Unfortunately, laser beams are so thin that you might not notice it
before it hits you."
There are a couple of problems with that statement. 1 if the beam is
that thin it would take exquisite marksmanship to hit someone's eye,
and 2 - visibility of a green laser beam is very high and it will
bloom big time on the windscreen, for example. I know of no windscreen
that's of a sufficient optical quality so as to not have that happen.
Off axis scattering in atmospheric transmissions is a serious problem
for high power lasers.
There would probably be an instinctive glance towards the source of
that pretty green light at night.
Infra red lasers would be a different sort of problem.
There was some stuff going on, maybe in Nevada, where very high
powered lasers were being used to perhaps target the moon, and there
were temporary restrictions on that airspace. (1970s or early 80s).
These were big power hungry lasers though, not the sort of thing that
are easily available for bad guys.
Old January 30th 07, 04:51 AM posted to rec.aviation.piloting
Kev
Spooked? Yes, but not in the way you mean. When the engine pulls
the usual "You're in the middle of nowhere, so I'm going to burp once
or twice just to get your attention", then yes I've asked ATC for
higher just in case :-)
When I was much younger and drove long lonely distances at night, I
used to sometimes get that creepy feeling that there was someone
(thing?) in the back seat. I can't imagine how bad that feeling would
be in an aircraft Fortunately, planes don't do that to me.
Kev
Old January 30th 07, 05:56 AM posted to rec.aviation.piloting
Mxsmanic
Kev writes:
Of course, now you'll have that to think about on your next flight.
Don't pick up any hitchhikers.
Old January 30th 07, 06:39 AM posted to rec.aviation.piloting
Roger[_4_]
Ive spent many hours flying alone and in the dark, both VFR and IFR.
I've never felt spooked. Rather it's quite peaceful and can be very
picturesque. Other times there is nothing to see at all and you have
to turn the stobes off to prevent "flicker vertigo". When the only
thing you see with each flash is featureless white it can be very
disorienting.
When I was much younger I burnt the candle at both ends so much I
needed something to keep me awake while driving.
Kev
Legality of a flight John Piloting 14 May 31st 06 01:22 AM
fuel subsidies for Angle Flight pilots sashley Piloting 17 September 11th 05 10:25 AM
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 06:56 AM
FAA to End part 91 Sightseeing flights? Vaughn Rotorcraft 7 November 2nd 03 02:20 AM
Ownership and passengers Roger Long Owning 30 October 11th 03 03:00 PM
