What do you do in the real world?
Old March 10th 07, 08:03 AM posted to rec.aviation.ifr
Ron Garret
Default What do you do in the real world?
Last night I flew from SJC to VNY. To my astonishment I was cleared
vectors to SNS, then direct VNY (despite having filed a more standard
routing) at 9000 feet. I knew perfectly well that the routing was going
to change because I've done that route a zillion times, and indeed, near
Bakersfield they switched me over to the standard LHS, LYNXX8 arrival,
followed by vectors to the ILS RWY 16R.
My question is: what should I have done if I'd been in IMC and lost comm
before they changed my routing? By the book I should have continued to
fly my clearance, which would have run me into a mountain around GMN, so
that's probably not the right answer. Viable possibilities seem to
include:
1. Divert (or climb) just enough to avoid the terrain around GMN, fly
to VNY, and commence an approach from there.
2. As above, but vector myself for the ILS before reaching VNY.
3&4 - as above but fly to LHS and the LYNXX8 arrival.
5. Divert to the nearest airport with an IAP.
My aircraft is /G so I know pretty much exactly where I am at all times.
rg
References:
LYNXX8 arrival:
http://www.airnav.com/depart?http://.../00067LYNXX.PD
F
ILS RWY 16R approach:
http://www.airnav.com/depart?http://.../00552I16R.PDF
Old March 10th 07, 09:35 AM posted to rec.aviation.ifr
Roger[_4_]
On Sat, 10 Mar 2007 00:03:57 -0800, Ron Garret
include:
There's only one. You fly it as last cleared.
You arrive at the expected time as the expected place.
www.rogerhalstead.com
Old March 10th 07, 10:08 AM posted to rec.aviation.ifr
Mxsmanic
Roger writes:
Even if the expected place is a mountainside? He mentioned that his last
clearance would have sent him into a mountain eventually. What do you do
then? I'm curious, too.
Old March 10th 07, 12:58 PM posted to rec.aviation.ifr
ArtP
On Sat, 10 Mar 2007 11:08:26 +0100, Mxsmanic
You still fly the assigned route at the highest of the last assigned
altitude (or any expected altitude at the expected time) or the
minimum altitude for the route.
Old March 15th 07, 02:35 AM posted to rec.aviation.ifr
Ray Andraka
include:
Radio failure is an emergency. You fly where ever you need to in order
to safely get on the ground. ATC will sort it out and keep other
aircraft out of your way.
Old March 15th 07, 03:32 PM posted to rec.aviation.ifr
Tim
going to change because I've done that route a zillion times, and
indeed, near Bakersfield they switched me over to the standard LHS,
LYNXX8 arrival, followed by vectors to the ILS RWY 16R.
comm before they changed my routing? By the book I should have
continued to fly my clearance, which would have run me into a
mountain around GMN, so that's probably not the right answer. Viable
possibilities seem to include:
So any time a piper cub flies it is an emergency?
So you can fly anywhere you want and atc is supposed to guess where you
are going or magically know whom to keep away from your unknown
position? They cancel and stop all flights while you fly wherever you want?
Does not sound good to me.
Old March 15th 07, 03:47 PM posted to rec.aviation.ifr
Dave Butler
This is rec.aviation.ifr
He didn't say "anywhere you want".
want?
Neither guessing nor magic is required. Your position is not unknown.
Flights are neither cancelled nor stopped.
Get your hearing checked.
Old March 15th 07, 05:01 PM posted to rec.aviation.ifr
Tim
Fair enough.
"Radio failure is an emergency. You fly where ever you need to in order
to safely get on the ground. That sounds like anywhere you want to
me. My point is that how the hell is atc supposed to figure out where
you are going to go if you don't follow any procedures? I am not saying
that the procedures are perfect, but guess work is not a good idea.
Putting in your expected nordo procedure (if it deviates from FARs) int
he comments section is a good idea.
want?
Um, if you are going to make up some route or your own clearance that is
not what it says int he FARs, then how is ATC going to "keep other
aircraft out of your way?" The answer is - they are going to impose a
far greater delay and re-reouting than if the nordo pilot followed the
right procedures. Are you saying radar covers all of the CONUS? I
didn't know that was the case.
I still don't like what I am hearing. There are a lot of advocates for
just making stuff up.
Old March 15th 07, 06:13 PM posted to rec.aviation.ifr
Ray Andraka
Tim wrote:
order to safely get on the ground. ATC will sort it out and keep
other aircraft out of your way.
want?
For starters, I won't be in the IFR system, nor will I be IMC in a piper
cub. That's a different duck altogether. If I am IFR, I am in the
system. ATC would rather have me out of the system as soon as practical
rather than spend the next several hours tracking me and anticipating
all possible moves on my part, clearing traffic out of the way. Yes,
the FARs say fly your flight plan, however, every FAA safety seminar
I've been to where this comes up, the FAA and ATC folks unequivocally
have said, lost comm in IMC is an emergency, ATC treats it as such
whether you declare it or not, and they'd rather have you get out of the
system as soon as practical over flying the rest of your flight plan and
having to get everyone out of your way.
Might be a little different in a non-radar environment, but here in the
NE pretty much everything is in radar coverage, so they know where you
are, which direction you are flying and your groud speed.
Old March 10th 07, 11:51 AM posted to rec.aviation.ifr
Ron Rosenfeld
include:
rg
"By the book", the route you fly should be the last clearance.
I don't understand, however, why you would run into a mountain if you are
following the altitude rules of the "lost-comm" regulations. Is your
aircraft not able to climb to the minimum IFR altitude for your route? If
that is the case, you have an emergency situation and can do whatever you
need to do.
Real world: I'm not familiar with your area. I would squawk 7600 and,
depending on my location, probably fly that "usual" clearance. Once ATC
notes that you have lost comm, they'll try to figure out what you're doing
and should be protecting all the approaches at VNY.
Real-world IFR currency Paul Folbrecht Instrument Flight Rules 47 March 23rd 05 04:19 PM
Real World Problem in FS9 The Real Cali Kid Simulators 12 December 6th 03 11:15 AM
Real World Weather (Isabelle) [email protected] Simulators 1 September 21st 03 09:53 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 04:13 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
