VFR "picking his way thru" heavy cells with XM Radio weather
Old June 6th 07, 02:49 PM posted to rec.aviation.piloting
Larry Dighera
Default VFR "picking his way thru" heavy cells with XM Radio weather
On Wed, 6 Jun 2007 06:17:34 -0500, "Dan Luke"
wrote in
"Larry Dighera" wrote:
I mentioned that I was trained to skirt CBs by 20 miles. Of course,
that is the reason.
Maintaining such a hard rule WRT to *all* CBs would make flyng a very
difficult proposition down South in the summertime, as Dylan has pointed out.
Not all CBs need such a wide berth.
What method of avoiding hail is used there?
It's often difficult to maintain good situational awareness of the
buildups if you are in VMC under a cell's base, or the buildups begin
to merge.
That's what XM WX is for, praised be its name!
Some information is better than none, even if it is stale.
  #62
Old June 6th 07, 03:44 PM posted to rec.aviation.piloting
Dylan Smith
It's extremely rare for hail to fall out of a typical airmass storm in
coastal Texas, and when it does, it tends to fall out of the bottom of
the storm, not be deposited miles from the rest of the precipitation.
Indeed, I've never known hail to fall out of such a storm at all
(although it undoubtedly must happen from time to time).
The times I saw hail in coastal Texas, it was always associated with a
line of severe thunderstorms, never the afternoon airmass storms. Flying
close to a line of thunderstorms anywhere is a bit foolhardy.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
  #63
Old June 6th 07, 04:50 PM posted to rec.aviation.piloting
Dan Luke
Have you used it?
  #64
Old June 6th 07, 05:22 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 6 Jun 2007 10:50:09 -0500, "Dan Luke"
wrote in
Have you used it?
No.
  #65
Old June 6th 07, 05:28 PM posted to rec.aviation.piloting
Matt Barrow[_4_]
"Jim Carter" wrote in message
t...
"Dylan Smith" wrote in message
... I hate to think what the ride would be
like only 10 miles from that storm!
No one has mentioned the phenomena where hail is thrown out of the top or
side of the really big CB and may be tossed for miles, and its really not
that uncommon.
A good case for a lightning detector.
  #66
Old June 6th 07, 05:45 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 6 Jun 2007 00:36:36 -0500, "Montblack"
wrote in
("Larry Dighera" wrote)
"A man has got to know his limitations"
Or in this case, the limitations of his equipment.
"I WAS IN THE POOL!"
Montblack
Okay, his aircraft's equipment. :-)
  #67
Old June 6th 07, 09:16 PM posted to rec.aviation.piloting
Dan Luke
Have you used it?
No.
Then, with respect, you have little practical information on which to judge
its value in operational situations. "Some information is better than none"
does not do justice to the superb weather awareness it provides. It is far
superior to using ATC/Fligh****ch.
As to the "stale" business, in 200+ hours of using the product in the most
thunderstorm-infested region of the U. S., I have found 6-8 minute maximum
lag a non issue for avoiding CBs.
Dan
"The future has actually been here for a while, it's just not readily
available to everyone."
- some guy at MIT
  #68
Old June 6th 07, 11:04 PM posted to rec.aviation.piloting
Peter R.
For strategic avoidance I agree but it still requires some thought. My
Bonanza is equipped with WSI downlinked weather displayed on an MX-20 moving
map, and WSI's refresh rates are normally 0 to 4 minutes old. I was under the
impression that NEXRAD could be up to five minutes old before being uplinked
to the delivery satellites (corrections appreciated). Therefore a worst-case
scenario is that the NEXRAD returns I see on my moving map could potentially
be up to nine minutes old.
At a groundspeed of 50 knots (my guess as to the average speed for a more
severe thunderstorm), nine minute-old data translates to about an 8 nautical
mile area ahead of the mature storm's direction as depicted on the moving
map. Thus, I add 8 nm to the recommended 10 to 20 nm (depending on storm
severity and type - frontal) to cover that lag time, assuming haze or IMC
prevents seeing the storm out the window.
What concerns me are those days where t-storms seem to be popping up
everywhere and returns go from light to intense in 15 minutes or less. In
those cases this relatively slow refresh rate makes flying through that zone
a bit of a butt clencher.
Peter
  #69
Old June 6th 07, 11:07 PM posted to rec.aviation.piloting
Montblack
("Dan Luke" wrote)
RV-10: Cruise Speed .....200 (3+) miles/minute
"It's like he flew right into the storm, as if he didn't no that it was
there," one witness reported. g
Montblack
  #70
Old June 6th 07, 11:40 PM posted to rec.aviation.piloting
Montblack
know
Radio "Squelch-type" Noise Kensandyeggo Owning 7 April 12th 06 07:20 PM
jeppesen "aviation weather" book Mike Instrument Flight Rules 0 March 26th 06 08:09 PM
