#61
At 03:06 30 September 2007, Eric Greenwell wrote:
Dan G wrote: BTW, on the gust issue, there is another solution (though not nearly as elegant as the rotating TE probe) - accelerometers. I think I understand how accelerometers could distinguish between a horizontal gust and the vertically moving air in a thermal, but I don't understand how aligning the probe with the horizontal gust will reduce it's effect on the vario. Wouldn't that accentuate, rather than attenuate, the gust effect? -- Eric Greenwell - Washington State, USA Not at all, at least not if it is the 2 or 3 way probe and this is why. It is first and foremost the static system that is particularly sensitive to gusting. When a horizontal gust hits the side of a plane, it creates positive pressure on one side of the static inputs (whether fuse or probe mounted), throwing the reading way out of whack. With the static on a rotating probe, it can align itself to always face directly into the wind and alleviate the big errors in static reading that horizontal gusts ( or other disturbances in yaw) create. It does not hurt to have the TE also rotate with it, and does not hurt to have the dynamic rotate as well (with rotating dynamic, a cup shaped Kiel tip is not required to maintain accuracy-less drag) but dynamic and TE are not as sensitive to misalignments in airflow as the static system is. This probe system will provide accurate readings during both slipping maneuvers (like if you mildly slip while thermalling ala Holighaus) as well as gusting incidents. BTW, the 'fancy' 2 way probe Dr Smolik sells is only 80 Euros, and the 3 way probe only 99. This video is the 3 way probe: http://youtube.com/watch?v=OpN9sYHF_yc , and this link shows drawings and prices for the whole line: http://www.eaglebrandproducts.com/TE...rices_2006.pdf I am only assuming here, but I would imagine these probes to be much cheaper than an accelerometer compensated computerized vario system (not to mention compatible with most anyone's current setup) but perhaps maybe not as effective in all situations. It is a simple and elegant aerodynamic solution to an old problem, that I'm sure will be seen on many more gliders in the near future. Again, I will share the data tables Ludek provides, once he sends them to me. Paul Hanson PS. I have no financial involvement with these probes, I just think they are very cool. PPS. there is a reason that NASA and most other flight test groups use static/dynamic (they don't mess with TE) probes that rotate (in 2 axis) to keep readings accurate while evaluating aircraft. |
#62
I think that if the airspeed is reduced by 40 knots or so in, say, 20
seconds, that's a zoom. I often see a quicker speed reduction than that. I would agree than smooth control inputs are better. Timing of the airspeed changes is more important than the amount. The key as to whether it worked or not is the barogram trace. If the downward trend of the glide is displaced upward at the zoom so a new trend starts at the top of the zoom, there was a net gain. If the thermal was too narrow or was followed by heavy sink, the barogram trace will just show a spike with no change in the trend - just a loss in average speed due to the slowing. A couple of pilots who seem to be the masters of the "Long Glide" are Kevin Wyatt and Gary Ittner. You will notice that their airspeed trace is almost an exact inverse of the vario trace. i.e. vario up, arispeed down and vario down airspeed up. On the other hand you will see pilots where there is only a weak correlation between airspeed and vario. These folks seldom get more than the published L/D. Bill Daniels wrote in message oups.com... Bill, are you seeing the effect of "dolphin" flying, or just following the lines of energy (or, avoiding sink). I try real hard to avoid the classic "pull hard in lif" type of dolphin flying, since in my experience it slows me down (from comparison flying); OTOH, I try real hard to look for and exploit lift lines, and gently vary speeds to match the trend of the airmass. Doing this, I consistently better my polar's L/D for the speed being flown. Of course, this is semantics - whatever technique being used, it is a skill that takes knowledge, practice, and good instruments. And the fast pilots usually have all three! Kirk 66 |
#63
Paul Hanson wrote:
At 03:06 30 September 2007, Eric Greenwell wrote: Dan G wrote: BTW, on the gust issue, there is another solution (though not nearly as elegant as the rotating TE probe) - accelerometers. I think I understand how accelerometers could distinguish between a horizontal gust and the vertically moving air in a thermal, but I don't understand how aligning the probe with the horizontal gust will reduce it's effect on the vario. Wouldn't that accentuate, rather than attenuate, the gust effect? -- Eric Greenwell - Washington State, USA Not at all, at least not if it is the 2 or 3 way probe and this is why. It is first and foremost the static system that is particularly sensitive to gusting. When a horizontal gust hits the side of a plane, it creates positive pressure on one side of the static inputs (whether fuse or probe mounted), throwing the reading way out of whack. With the static on a rotating probe, it can align itself to always face directly into the wind and alleviate the big errors in static reading that horizontal gusts ( or other disturbances in yaw) create. The gusting that cause false readings on my varios seems small enough that it doesn't move the yaw string very much. I can use the rudder to slip/skid the same amount, and the vario hardly notices it. So it seems like the gust itself is the problem, not the direction it comes from. If that's true, an aligning probe won't help any. Also, suppose the gust comes directly from the front or the back. This will cause a change in the airspeed and "fool" a TE vario. A probe that aligns with the airflow won't help in this case, as the airflow direction doesn't change at all. It does not hurt to have the TE also rotate with it, and does not hurt to have the dynamic rotate as well (with rotating dynamic, a cup shaped Kiel tip is not required to maintain accuracy-less drag) but dynamic and TE are not as sensitive to misalignments in airflow as the static system is. If that's the case, why don't we just use a TE probe and forget about using a pitot/static system to run the vario? This probe system will provide accurate readings during both slipping maneuvers (like if you mildly slip while thermalling ala Holighaus) as well as gusting incidents. It seems like the aligning probe ensures that a gust will add it's entire velocity to the glider's speed through the air, making it even more sensitive to gusts than a probe that doesn't align. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#64
Paul Hanson wrote:
When a horizontal gust hits the side of a plane, it creates positive pressure on one side of the static inputs (whether fuse or probe mounted), throwing the reading way out of whack. I can see that this would make the ASI twitch (and the altimeter if it wasn't on cockpit pressure) but I don't see the relevance to my varios because: - my B.40 only has one line that connects to the TE probe, so the static isn't affected and you say that a TE probe is relatively little affected by gusts. - my SDI C4 which has static and pitot as well as TE connections. My guess is that it only uses TE for its vario function and the static+pitot for airspeed and pressure altitude. BTW, what the heck is a "dynamic pressure" probe? Is it a pitot tube? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#65
At 12:06 08 October 2007, Martin Gregorie wrote:
Paul Hanson wrote: When a horizontal gust hits the side of a plane, it creates positive pressure on one side of the static inputs (whether fuse or probe mounted), throwing the reading way out of whack. I can see that this would make the ASI twitch (and the altimeter if it wasn't on cockpit pressure) but I don't see the relevance to my varios because: - my B.40 only has one line that connects to the TE probe, so the static isn't affected and you say that a TE probe is relatively little affected by gusts. Relative being a relative term, this is somewhat true. In comparison it is not AS affected as the static, but it is indeed affected. There are many plumbing combos for different types of system, so while something that works well with one system does not mean it will work for another. Although in this case, I do believe you would get better readings from your B-40 with the Yaw-free TEK probe. Read the stats on the charts for yourself that I am posting links to in a new post, that compare a standard TE and a yawing unit under the same conditions. - my SDI C4 which has static and pitot as well as TE connections. My guess is that it only uses TE for its vario function and the static+pitot for airspeed and pressure altitude. Without actually studying your system your guess is only that-a guess. Just because the B-40 runs only on TE does not mean that this one does, although it may. Rather than guess though, I would do my homework to figure that out if it were mine before deciding how to improve anything. BTW, what the heck is a 'dynamic pressure' probe? Is it a pitot tube? Dynamic pressure is what a Pitot tube is measuring, and what a TE is attempting to create a perfectly matched inverse of. Paul Hanson "Do the usual, unusually well"--Len Niemi |
#66
Paul Hanson wrote:
Dynamic pressure is what a Pitot tube is measuring, and what a TE is attempting to create a perfectly matched inverse of. Clear and concise. Thanks! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
WTB: CAI L-NAV readout meter and Sage or PZL mechanical vario. | [email protected] | Soaring | 2 | August 28th 07 03:18 AM |
Placement of Mechanical Vario in Panel? | V1 | Soaring | 3 | July 29th 07 08:55 PM |
Mechanical Vario or not? | Fish | Soaring | 15 | July 2nd 06 02:28 PM |
Winter mechanical vario reading high | Alan Meyer | Soaring | 13 | April 13th 06 02:38 AM |
Wanted: Used Mechanical Vario | Tim Hanke | Soaring | 0 | May 16th 05 05:35 PM |
