#61
"Gord Beaman" wrote in message ... "Dudley Henriques" wrote: "Gord Beaman" wrote in message news ![]() Yeff wrote: On Mon, 8 Dec 2003 09:57:13 -0500, George Z. Bush wrote: My conclusion, therefore, is that he didn't have any and, by so pointedly trying to avoid mention of the subject, only succeeded in having us become aware of what he'd rather we not know about him. You mean I was imagining all those times he said he *wasn't* military? -Jeff B. While I've seen one *hell* of a lot that he 'has' said about himself I don't think I've ever heard him say that he wasn't military Jeff...you got even one cite?...he's still one of the most obnoxious blowhard windbags that I've ever seen, bar none. But even more disgusting is his obviously desperate squirmings to cover his errors so as to avoid admitting to them...this latest effort of his takes the prize...tried to ascribe ownership of HIS statement to ME...miserable little prick... --Gord. "Bull ****! This is a constant speed prop. RPM is a set value. The RPM can be set at 3000 and the manifold pressure can be anywhere between 15 inches and 61 inches, and it's the manifold pressure combined with the set RPM that will determine the power.....NOT the RPM!!! Are you trying to tell me that the rotational (energy) of a propeller is the same at 15 inches as it is at 61?". -D Henriques Beamon; you CAN'T be this stupid. What you are quoting constantly as being incorrect is not only absolutely true, but it's totally inconceivable to me that someone who professes to have been a flight engineer on Merlins doesn't have the brains to have figured out by now how absolutely idiotic you are by pressing this. Please post anything and everything you wish from that stupid thread that makes your point. You have no point, as anyone bothering to actually read the entire thread will instantly see. I'm getting tired of teaching you what you should already have known about the constant speed prop we were discussing at the time; the 24D50 on the Mustang. I tried to tell you....Vlado tried to tell you.....no one could get through that think skull of yours. For the last time, you inserted yourself into a discussion between myself and someone else where I was explaining that if you yank the power back on a 51 to idle in preparation for a bail out without reducing the prop setting from cruise, the seizure momentum will be less than that with the power at cruise. To ANYONE knowing the first damn thing about constant speed propellers, this would indicate that the reason the momentum is less isn't because of the manifold pressure alone being less, but rather that the reduction of the power will most likely put the prop below the high rpm limiters which in turn will reduce the rpm which as you correctly stated, is the ONLY reason for reduced rotational inertia at seizure. The problem with you Beamon, (and anyone reasonably reading the thread in question can see this in an instant), is that instead of asking about the prop limiter issue, you inserted yourself blindly into the discussion as you always seem to do with me......with a sharp correction that went on and on and on and on about manifold pressure not being related to rotational inertia. Hell, I know this. Everyone knows this!!! Vlado tried to tell you about the idle issue with the 24D50, (he owns a f*****g P51 for Christ's sake) and I tried to tell you that I wasn't addressing that issue at all but you would have none of it. It becomes blatantly obvious to anyone reading this thread and the dialog that transpired between the two of us that I was merely telling you what is quoted correctly by me above; that being that it's the combination of manifold pressure and rpm that determines power, and posing the question to you that asks if you believe the rotational energy of the prop is the same at 15 inches as it is at 61. Keeping in mind that from the onset of this discussion, (unless you can post otherwise here and now from the thread ) absolutely no one has said anything about changing the prop setting from cruise, (where it was assumed to be in my initial post that you interrupted with your "corrections" 101" ) Your argument would hold water if this prop would maintain cruise setting with the power being reduced to idle, but I believe that power reduction puts the prop beyond the limiters which was assumed, since it should be normal procedure for this engine prop combination. Now ONE more time, rpm and manifold pressure equals power. RPM determines rotational inertia. Reducing power on a 51 from cruise to idle without changing the prop setting should reduce the rpm below the governor limits and as such reduce the rotational inertia at seizure from the level where it was at cruise to a new level with the power at idle. Now, once an for all Beamon; do you get this; or do you really think that after dealing with these props (expensively I might add) for all these years, I actually need YOU to have explained all this to me? For Christ's sake, give it a rest will you? It's stale to me, and probably to rest of the group as well. Better than that, write Vlado a letter will you. He flies the f*****g airplane every f*****g day. He has the f****g propeller and f****g engine on his airplane......Ask HIM! And as for the "windbag" crap. If you would simply not insert yourself into discussions before you have your brain engaged, there would be no need for these long drawn out replies. When I had commented to someone else about my flying with the Snowbirds......no big deal.......but to you it meant the following, "Absolutely amazing!...how did you manage that Dud?...they weren't equipped with the Tutor until 1978" Same modus operandi....Not only totally wrong, but inserted just like the prop post, unnecessarily sharp and sarcastic and meant to imply something negative rather than seek clarification. Do as you wish, Gordo, but I really think you're on the wrong path. I've told you before it's not necessary to do it this way. Every time you insert in this manner, you chip away at any credibility you have by creating the obvious impression that you dislike someone intensely. It's a very bad Usenet mistake, and anyone with half a brain can see right through it. I'll simply continue to respond if and when I deem it necessary with my usual constrained response to you. I can't conceive of anyone being so bored with life that they would actually go out and do research on the issue we're discussing here, but if they are, they are more than welcome to go seek out the thread you keep hollering about and read it from beginning to end. I have no problem with that whatsoever. In fact, I've decided that I'll simply keep a copy of this post and just paste it in as a standard response whenever you post about me and this stupid prop issue. Advice; the best way to discredit someone on Usenet is with a velvet glove :-) And do me a favor this time will you....save the long post stuff.......the pompous ass stuff....the windbag stuff....the SOB stuff.......the "he's an angry li'll f****r isn't he" stuff......and the "he didn't know any of this until I told him stuff. It's predictable and boring really, and instantly disprovable to anyone reading the engine seizure thread in toto. If you think someone on Usenet is worth discrediting, try doing it the right way for a change............use a velvet glove..........NEVER a sledge hammer!!! :-))))) All the best as usual and always regardless :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt ....I rest my case... Same. Let's just let it go shall we? :-) DH |
#62
"ArtKramr" wrote in message ... Subject: Fighter Pilot Fellowship (was: something else entirely) From: "Dudley Henriques" Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. Oh I don't know. Anyone who can handle a J3 on a windy day in August must have SOMETHING on the ball! :- Always courteous no matter what. Good for you. Regards, I'm TRYIN!!!!!! :-)))))) D |
#63
Cub Driver wrote:
That said, shall we move on? Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. My own biography is online at www.warbirdforum.com/dan.htm What does the middle initial stand for--Zounds? Zulu? Whatever rings your chimes.....it's a family secret. (^-^)))) George Z. |
#64
From: "Dudley Henriques" Date: 12/8/03 1:48 PM Pacific Standard Time Message-id: . net "ArtKramr" wrote in message ... Subject: Fighter Pilot Fellowship (was: something else entirely) From: "Dudley Henriques" Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. Oh I don't know. Anyone who can handle a J3 on a windy day in August must have SOMETHING on the ball! :- Always courteous no matter what. Good for you. Regards, I'm TRYIN!!!!!! :-)))))) D Nobody ever said it was going to be easy. But your eternal patience is remarkable. Regards, Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
#65
"George Z. Bush" wrote in message ... Cub Driver wrote: That said, shall we move on? Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. My own biography is online at www.warbirdforum.com/dan.htm What does the middle initial stand for--Zounds? Zulu? Whatever rings your chimes.....it's a family secret. (^-^)))) George Z. "Zounds" is what one says to one's self when one discovers the joy involved in flying something as challenging an airplane as the Bamboo Bomber!! :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
#66
... Cub Driver wrote: That said, shall we move on? Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. My own biography is online at www.warbirdforum.com/dan.htm What does the middle initial stand for--Zounds? Zulu? Whatever rings your chimes.....it's a family secret. (^-^)))) Zebulon, Zebedee, Zacharias, Zerottenschwein... :^) -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
#67
"ArtKramr" wrote in message ... Subject: Fighter Pilot Fellowship (was: something else entirely) From: "Dudley Henriques" Date: 12/8/03 1:48 PM Pacific Standard Time Message-id: . net "ArtKramr" wrote in message ... Subject: Fighter Pilot Fellowship (was: something else entirely) From: "Dudley Henriques" Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. Oh I don't know. Anyone who can handle a J3 on a windy day in August must have SOMETHING on the ball! :- Always courteous no matter what. Good for you. Regards, I'm TRYIN!!!!!! :-)))))) D Nobody ever said it was going to be easy. But your eternal patience is remarkable. Regards, I believe I have been known to depart from this "inner tranquility" on occasion :-))))) D |
#68
After an exhausting session with Victoria's Secret Police, Ron
blurted out: Didnt a British Airways pilot once say that a Cub pilot can fly a Corcorde, but the reverse isnt neccessarily true. Clearly he was being the typical well mannered brit, didn't want to honestly answer the question, "Could you fly the Concorde?...Not bloody well likely." Imagine the smiles on the passengers as they listened to the PA... "Ladies and Gentlemen, today it is British Airways' honour and extreme pleasure to have Elmo Bowlogritz, Cub pilot extraordinaire, in command of this flight. Mr Bowlogritz will be attempting his first takeoff and landing in a supersonic transport aircraft...with passengers..." Juvat |
#69
In message , Juvat
writes After an exhausting session with Victoria's Secret Police, Ron blurted out: Didnt a British Airways pilot once say that a Cub pilot can fly a Corcorde, but the reverse isnt neccessarily true. Clearly he was being the typical well mannered brit, didn't want to honestly answer the question, "Could you fly the Concorde?...Not bloody well likely." Imagine the smiles on the passengers as they listened to the PA... "Ladies and Gentlemen, today it is British Airways' honour and extreme pleasure to have Elmo Bowlogritz, Cub pilot extraordinaire, in command of this flight. Mr Bowlogritz will be attempting his first takeoff and landing in a supersonic transport aircraft...with passengers..." With my huge and exhaustive flying experience (twelve hours total as wannabe driver) I will say that the aircraft I was learning in could damn well fly itself, and was only at risk from the ham-handed intervention of its pilot. Even spin recovery was basically "let go and wait, she'll sort herself out" if you were clumsy and stupid enough to force a spin at all. (My instructor cheerfully showed me 'incipient spin' and how to avoid it, which was mostly 'let go' - then coached me through the now-optional "this is a spin, how do we recover?" which was basically 'let go and let her recover'!" Mind you, inducing a spin in G-TOUR needed not just negligence but outright malice...) I don't think many military aircraft are so forgiving, and I doubt that large civil aircraft are as generous to unskilled pilots. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#70
Cub Driver wrote: That said, shall we move on? Sure. I wasn't a military pilot either. In fact, I'm not much of a civilian pilot either. Damn! You mean there's TWO of us on this group? Bob McKellar, guilty of both of Dan's sins |
| Thread Tools | |
| Display Modes | |
| USAFE commander: 86th Airlift Wing will divide for combat, support operations | Otis Willie | Military Aviation | 0 | November 28th 03 12:31 AM |
| Air Force combat search and rescue joins AFSOC team | Otis Willie | Military Aviation | 0 | September 30th 03 10:49 PM |
| Combat Related Special Compensation update for Sept. 8-12 | Otis Willie | Military Aviation | 0 | September 17th 03 04:38 AM |
| Harrier thrust vectoring in air-to-air combat? | Alexandre Le-Kouby | Military Aviation | 11 | September 3rd 03 02:47 AM |
| Team evaluates combat identification | Otis Willie | Military Aviation | 0 | August 18th 03 09:52 PM |
