#61
#62
On Jan 17, 5:49 pm, Dudley Henriques wrote:
wrote: On Jan 17, 5:22 pm, Bob Moore wrote: wrote The 172 N Model I fly from time to time is only approved (and thus was only tested) for spins when CG falls within the utility category. Though it may be recovered from a spin when loaded within the normal category range, it was not certificated that way. Which tells me there is no assurance of recovery. BULL****!! Section 23.221: Spinning. (a) Normal category airplanes. A single-engine, normal category airplane must be able to recover from a one-turn spin or a three-second spin, whichever takes longer, in not more than one additional turn after initiation of the first control action for recovery, or demonstrate compliance with the optional spin resistant requirements of this section. (1) The following apply to one turn or three second spins: (i) For both the flaps-retracted and flaps-extended conditions, the applicable airspeed limit and positive limit maneuvering load factor must not be exceeded; (ii) No control forces or characteristic encountered during the spin or recovery may adversely affect prompt recovery; (iii) It must be impossible to obtain unrecoverable spins with any use of the flight or engine power controls either at the entry into or during the spin; I would suggest that you read the entire FAR section 23.221 for Normal, Utility, and Aerobatic category aircraft. Bob Moore ATP CFI I've read the FARs. I've also read the POH, which states "Spins approved when loaded within utility category." I'll see your Bullchip and raise you three chickships. Dan Dan You're arguing with the wrong guy Dan, and you are going to lose your three chickships whatever the heck they are :-))) . Bob's right and you are wrong. You seem to be hung up on the fact that because the POH states that spins are approved only in the Utility category, that this means the airplane can't be spun in the Normal Category. This simply is not true AERODYNAMICALLY which is the ONLY context we are discussing here. LEGALLY it can't be spun in the Normal Category but otherwise it will spin just fine in the Normal Category; unless you have an aft cg issue and then it's up for grabs either normal or utility category. Naturally, if your 172's POH says that spins are not approved in the Normal Category, that's exactly what it means. It means that spins are not APPROVED in the Normal Category. Whoa there, pardner... Let's back to flame train up. First, I'm not accepting anyone's statement because of "who he/she is." If it's reasonable and/or proven, I'll weigh it and accept it or reject it (to my advantage or peril, but so be it). I would hope anyone posting/reading a newsgroup about aviation would take this approach. Now, my point regarding spins is that I have no *assurance* (aerodynamically or legally) from anyone that the airplane will recover when flown with CG in the Normal range (FARS notwithstanding -- The fact that the airplane met the requirements of the FAR for certification tells me that the manufacturer certified to the letter of the law with an experienced pilot in ideal conditions. Neither the manufacturer nor anyone else will stand by the capability outside a certain narrowly defined range). I have assurance in the POH that the airplane can recover when CG is within the utility range. I am not a test pilot (and haven't even played one on TV), thus should not intentionally or unintentionally enter a spin in this airplane when CG load is outside the utility category. Now, while it may be the case that the airplane will recover in that condition, that is speculation to me and anyone else until proved otherwise in a fairly dangerous experiment in test piloting. To recap, since the discussion has blurred: Will a pilot who has been through spin training be better prepared if a spin should occur? Probably. Will the appropriate PARE reaction recover most airplanes from an incipient spin? Most likely. Does this establish that spin training is essential to PPL training? Not really. Dan |
#63
Bertie the Bunyip wrote:
Have you ever had to put down with no power, by the way? Only about 700 times! 696 were kind of expected to go that way, though. Bertie kinda curious What kind of flying are you doing where you're expecting to be letting down w/o power? I mean, for me its actually 100% -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200801/1 |
#64
I once had the chance to talk to the chief test pilot of a muanufactorer
(no names here) and asked exactly this. His answer was clear: Sure their airplanes recover from spins. But they don't trust the pilots, and they don't even trust the average instructor. So they decided to prohibit spins to avoid liability issues. This I believe. Let's see. The reasons for not asking a PPL to demonstrate a 1/2 or 1 turn recovery from a spin (or if not on the PTS then have an endorsement from their instructor like a CPL): 1) Kills more pilots than it saves 2) Instructors not competent enough. 3) Planes not available 4) FBOs won't allow it. 5) Spin awareness good enough There may be some other reasons given. I still say I'd feel better having performed at least one recovery by myself. If I were doing it again I'd ask my instructor to do some spins with me and have me recover before I soloed. Now some comments on the reasons given: 1) Let's see the numbers -- otherwise it's a myth 2) They should be trained up properly (competency of an instructor to recover promptly from a spin should NOT be in doubt) 3) This is more a result of litigation, I'd wager, than anything else. And probably is the biggest practical road block for pilots to be properly trained in handling an aircraft in all possible flight situations. 4) See 3 above. 5) No, it's not good enough, IMO. Experience in handling an aircraft in all flight situations, though, is good enough. Even once or twice is better than no training. Bertie pointed out in a post quite far up that it's the training, the instant response that is going to save you. Maybe not 1000 feet above the ground -- but at 2000 a little previous experience might just save your butt. By the way that long article by Rich Stowell has very interesting section titled "Student Pilots & Their Instructors" from which I quote as related to #2 above: "The most foreboding aspect of the Veillette study, however, involved the hands-on spin experience of flight instructors. Ninety-eight percent noted that their formal spin training consisted of no ground instruction and a mere two spins--one in each direction. Nonetheless, these instructors readily received logbook endorsements certifying that they were competent to teach spins. We'd surely consider it absurd, for example, if all it took to qualify to be an instrument instructor (CFII) was a logbook entry showing that the applicant had performed a grand total of two instrument approaches. On the contrary, instrument training has evolved into a rigorous process involving specially equipped airplanes and specially certified instructors. Just as the instrument flight environment places unique demands on its pilots and airplanes, so too does the spin environment place unique demands--aerodynamically, physiologically, psychologically--on those who enter its realm. It is equally unforgiving of incompetence as well. Yet too many pilots remain nonchalant in their attitudes toward spinning." So, okay, the FAA doesn't require spin recovery for PPL. As Dudley says, you ought to go get as soon as you are able after the PPL. No one seems to think you'll be worse off for it. |
#65
.. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff |
#66
Capt. Geoffrey Thorpe wrote:
"Bertie the Bunyip" wrote in message .. . wrote in : ... The typicl spin accident, if there is such a thing, is the famous overcooked turn onto final. I watched two guys die after doing that on a tight, low, turn to a short final... Geoff What gets them isn't really the turn per se, but the way that turn is flown. The combination of the increased stall speed due to the turn coupled with some excess inside rudder causing a skid as the stall breaks is a perfect pro-spin setup. The two ingredients for spin are present; stall and a yaw rate coupled simultaneously . You can get away with a tight low turn if it's coordinated and you feed in enough power to offset the drag rise; or even better yet an unloaded tight descending turn if some altitude and some radius need to be scrubbed off,(I don't recommend doing these BTW :-) but it's that lack of attention to the extra needed thrust as the drag rises in the turn and cheating a bit with inside rudder to "force that nose around that will get you killed. -- Dudley Henriques |
#67
Dudley Henriques wrote in
: Bertie the Bunyip wrote: Yeah. I always flew the J3 from the back as well. In fact, the one we had available was back seat solo only. Prewar, then. I flew one that only had a front seat for banner towing and ended up on my nose several times. Better from the back always,really, but ost of my time in them is instructing and that was always from the front. Talk about fun....I flew that damn thing all the way down the East Coast one spring when I had a month off to myself. Most of the way I was several hundred yards off shore. The weather was warm and I had the upper panel open most of the trip. Every now and then I would throttle back to idle and try shouting at people down below. I saw them shout back but to tell you the truth I never heard a word they were saying :-) Ended up at Key West, stayed several days, island hopped a bit then flew it home again. One of the best aviation experiences I ever had really. It's funny when you stop to think about it. Of all the fancy airplanes that crossed my path in life, that little J3 and that trip down the coast would be right up there at the top of the heap for just plain fun with an airplane. Yep. I'd never buy one but they were great fun to fly. I had several 'unique' experiences with them which I had better not post until i check the statute of limitations on them. Bertie |
#68
#70
Stefan wrote in news:c98be$478fd695$d9a2716b
: Cubdriver schrieb: some spins in the PA-18. The answer was no, because it might tumble the gyros. So there's another reason folks don't teach spins. I'll never understand why non-cageable gyros even exist. Money Bertie |
spins from coordinated flight | Todd W. Deckard | Piloting | 61 | December 29th 07 01:28 AM |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
Spins in Libelles 301 & 201 | HL Falbaum | Soaring | 9 | February 10th 04 06:12 PM |
Thanks for the Spins Rich | David B. Cole | Aerobatics | 17 | October 26th 03 08:37 AM |
