Post-Annual Flight
Old February 22nd 08, 01:51 PM posted to rec.aviation.piloting,rec.aviation.owning
Dave Stadt
Default Post-Annual Flight
On Feb 21, 10:36 pm, "Dave Stadt" wrote:
Mine bounce around so much they are useless.
Then your plane isn't airworthy.
Wrong! They work exactly as designed and as installed by the manufacturer.
Often times book learnin doesn't transulate to real life.
Perhaps not. But flying without basic required equipment often
translates to real death.
  #63
Old February 22nd 08, 02:04 PM posted to rec.aviation.piloting,rec.aviation.owning
On Feb 22, 7:15*am, B A R R Y wrote:
Jay Maynard wrote:
How does a fuel gauge that's so unreliable that you can't trust it to within
a quarter tank tell you whether you've got a fuel leak? That description
applies to every aircraft I flew during my primary training, late 1970s
vintage Cessna and Piper and Grumman products (this was in the late 1980s).
I was taught to verify the tank's level on preflight, and use time and
consumption per hour to figure usage.
That's my point.
Is "Airplane Sense" a simmer? *G
Only when I'm not flying for real.
I've rented dozens of planes throughout the US, and I don't recall any
in which the fuel gauges didn't perform well enough to provide at
least a rough cross-check of my calculations.
Look, aviation safety is about redundancy. And it's about being
prepared for unlikely but serious problems. So I find it disconcerting
to hear from pilots who habitually don't bother to perform a simple,
potentially useful cross-check, or who even habitually fly without the
required properly-working equipment to enable them to do so.
  #64
Old February 22nd 08, 02:17 PM posted to rec.aviation.piloting,rec.aviation.owning
You're saying the manufacturer designed your gauges to "bounce around
so much they are useless"?
Even if that were true, it wouldn't make your plane airworthy. If a
tank's fuel gauge doesn't give you information about the tank's fuel
level, then it fails to meet the airworthiness requirement 91.205b9.
  #66
Old February 22nd 08, 02:29 PM posted to rec.aviation.piloting,rec.aviation.owning
William Hung[_2_]
On Feb 21, 5:30*pm, "Jay Honeck" wrote:
http://www.metcoaire.com/products/pr...straight.shtml
Scroll down to 'Replacement Fiberglass *Tail Cone' section.
Metco's fiberglass parts are first rate quality.
Thanks for the link!
The repaint can't be all that bad. We had a custom paint job on old
wheelpants accurately duplicated onto a set of new ones by a local
auto paint & body shop for only a couple hundred dollars materials &
labor.
All the stripes on the plane (3 different colors) are on that tail cone,
plus the base coats of gray and white. * What a PIA to do, but I'm afraid it
will have to be done.
Jay Honeck
Iowa City, IA
Pathfinder N56993www.AlexisParkInn.com
"Your Aviation Destination"
Jay, you might want to try and take your broken tail tip and your new
tail tip to a shop that paints motorcycle helmets or to an airbrush
guy and have them paint the new one to match the old one. I'm not
sure if anyone else had suggested this, I haven't read the entire
thread yet, the part about the 'in-op' sticker is interesting.
Not having ever owned an airplane and looking into owning one in the
future, I found your write up a good read,
Wil
  #67
Old February 22nd 08, 05:34 PM posted to rec.aviation.piloting,rec.aviation.owning
Dallas
Yeah... it convinced me to keep on renting.
Dallas
  #69
Old February 22nd 08, 10:06 PM posted to rec.aviation.piloting,rec.aviation.owning
Dave Stadt
Then there are thousands if aircraft out there that are unairworthy. That
is not true and you are still wrong.
  #70
Old February 22nd 08, 10:43 PM posted to rec.aviation.piloting,rec.aviation.owning
Bertie the Bunyip[_25_]
"Dave Stadt" wrote in
manufacturer.
That is not true and you are still wrong.
It is true. All a fuel gauge will tell you accurately is that it is mounted
in the panel.
Bertie
Post-Annual Flight Jay Honeck[_2_] Piloting 114 March 2nd 08 10:55 PM
Post Annual Report Jack Allison Owning 7 July 7th 07 04:37 AM
Annual Xmas Post - HawkSanta.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
Annual Xmas Post - Flight Line Santa.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
Annual Xmas Post - 001index.jpg (1/1) Mitchell Holman Aviation Photos 0 December 21st 06 02:54 AM
