C172 and Spins
Old March 21st 08, 05:44 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default C172 and Spins
Dan wrote in news:d6ef000c-45fe-42e6-93e2-
On Mar 20, 10:15 pm, Bertie the Bunyip wrote:
Well, they're roughly the same planform, though the 150s surely must
be
smaller overall. I think they both use an old fat NACA semi-
symetrical.
In fact, I think Cessna only used one airfoil for all the strutted
pistons, so it would be CG and elevator authority that dicated it's
ability to do one. I'd say you could do it, but the chances of
pulling
something off would be pretty good. At the very least I'd say you
might
find some slightly stretched metal wing mounting parts if you looked
after doing a few snap rolls at a good speed.
Well, that's certainly more than enough reason NOT to do that in this
172!
The 150 series certainly stall breaks cleaner, but I don't know if
that's due to CG or wing design.
Proly CG and the relatively limited elevator available compared to
150. Neither will stay in a spin very long, but the 172, I dont think
I've ever managed over a turn in any of them, and a half a turn is
more
par for the course. The added power in a snap would probably aid in
elevator department and allow a complete rotation, but I'm only
guessing.
Bertie
The best spin wrung from the C172E (3 turns, tiny amount of residual
power going into the spin) was from a cross control stall to the left.
Full left rudder, full right aileron, full back elevator....
In a blink we were inverted, then into fairly nice high rotation rate,
low airspeed, very little pitch bobbing -- a by-the-book fully
developed spin.
Power off, full opposite rudder and simply release the back pressure
and the spin stopped.
Otherwise, you're right -- by turn 1 1/2 the 172 is pulling itself
into a steep spiral.
I never spun as early a one as that. in fact, I don't think I've ever
flown a continental powered 172, so they might be slightly different in
more than just the engine. You sure you weren't spiraling, though? The
very early square tail 172s might have had more elevator authority and
they definitely would have had more rudder. I don't think I'bve ever
spun a 170, though we definitly would have done things like falling
leaves and such in the one I used to fly since it was a trainer. Come to
think of it I've done falling leaves in a 172 as well. They'll drop a
wing allright, they just won't stay in the spin.
Bertie
  #62
Old March 21st 08, 07:35 PM posted to rec.aviation.piloting
Dan[_10_]
be
symetrical.
pulling
might
172!
more
guessing.
Bertie
developed spin.
Bertie
May have been spiraling by turn 3...
I was in right seat and had a hard time getting a good read on the
ASI.
Dan Mc
  #63
Old March 21st 08, 07:43 PM posted to rec.aviation.piloting
Dan wrote in news:1cb92ef6-6416-49a4-b564-eb00a52135a1
@b1g2000hsg.googlegroups.com:
Bertie
ASI.
Dunno, it wouldn't take much of a rigging change to make a difference.
Bertie
  #64
Old March 21st 08, 07:51 PM posted to rec.aviation.piloting
Dan[_10_]
ASI.
Bertie
Oh?
  #66
Old March 21st 08, 08:08 PM posted to rec.aviation.piloting
Dan[_10_]
difference.
Bertie
Oh?
More up elevator would probably do it for starters. There's only enough
to get you to crit alpha, no more, thats one reason why power helps, it
increases the authority of the elevator
Bertie
True... I was only thinking of rigging n the fly-straight sense, not
elevator -- duh.
This particular airplane seems to have weak right rudder -- 10 knot x-
wind is more than it can handle in a slip -- rudder is to the stop,
while left I can easily stay straight banking much more steeply (this
is in approach, so left turning tendency is not a factor).
Yet the airplane appears to fly straight...
I suppose it's asking alot of a 44 year old airplane for everything to
be in perfect harmony!
Dan Mc
Spins [email protected] Piloting 213 January 27th 08 12:37 AM
Any Spins Lately?? Ol Shy & Bashful Piloting 28 September 6th 07 10:22 PM
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 08:24 PM
Spins in Libelles 301 & 201 HL Falbaum Soaring 9 February 10th 04 06:12 PM
Thanks for the Spins Rich David B. Cole Aerobatics 17 October 26th 03 08:37 AM
