#61
![]() .... Jay, if your only alternative to keep flying was to drop, say, $40K into a diesel conversion for Atlas, would you? Jay's only choice would be the 235hp SMA diesel for about $100,000 firewall forward. And I don't think they've made any progress toward an STC for his PA28 model, so Jay would have to "transfer" into an Experimental Certificate. Seeing as Jay has expressed his opinion on the government bureaucracy rather strongly, I'd suspect his head would explode going down that road. ;-) |
#62
WingFlaps wrote:
To supply CA's 30 GW demand you would need about 300 square kilometers of solar panels(assuming 100W/m2). That's a truly huge area and I think it shows why solar is not a viable solution. 300 km^2 is chump change! (Lake Mead itself is ~640 km^2.) Want to know how much surface area it would take for SOLAR TO REPLACE ALL OTHER SOURCES OF POWER FOR THE ENTIRE PLANET? Here's my math and sources: As of 2005 all consumption of power for the entire world is estimated to be on the order of ~463 quadrillion BTUs/year (or ~5*10^20 J/year)[1]. Assuming an average of only ~3 full-sun-hours/day insolation (e.g. loss due to clouds and low angle attentuation) and ~10% conversion (or about 100 W/m^2) you get: 365 days/year * 3 hr/day * 3600 s/hr * 100 J/s/m^2 ~= 3*10^8 J/year/m^2 So (5*10^20 J/year) / (3*10^8 J/year/m^2) ~= 1.7*10^12 m^2 Or about 1,700,000 km^2. By comparison, the total surface area taken up by all man-made water reservoirs is about 500,000 km^2 [2]. I don't know what the surface area of farmland is (though reference [3] suggest it could be up to 30% of all land area), but I'm sure if only a small fraction of it were turned over to direct solar power production it would also suffice. The total land surface area of the Earth is ~150,000,000 km^2 [3] so the percentage needed is (drum roll, please!) 100*1,700,000/150,000,000 ~= 1.1% A tad over 1% of the land surface - a little over three times the area consumed by water reservoirs and probably much less area than that used for farming. Another comparison is road surface area. I've seen estimates that indicate that roads in the U.S. and UK take up ~1% to 1.4% of the surface area of those countries.[4][5] And I haven't even considered using ocean surface area, more efficient solar conversion, higher insolation average, or even solar power satellites. Even at today's low PV efficiencies, there appears to be adequate area to use solar energy to power human civilization on this planet. [1] http://www.eia.doe.gov/pub/internati...lf/table18.xls [2] http://webworld.unesco.org/water/ihp...bpc/pag21.html [3] http://hypertextbook.com/facts/2001/DanielChen.shtml [4] http://www.newscientist.com/backpage.ns?id=lw1065 [5] http://www.magicalliance.org/Fragmen...d_by_roads.htm |
#64
#65
On Thu, 10 Apr 2008 18:35:05 -0500, Jim Logajan wrote:
The total land surface area of the Earth is ~150,000,000 km^2 [3] so the percentage needed is (drum roll, please!) 100*1,700,000/150,000,000 ~= 1.1% A tad over 1% of the land surface - a little over three times the area consumed by water reservoirs and probably much less area than that used for farming. Another comparison is road surface area. I've seen estimates that indicate that roads in the U.S. and UK take up ~1% to 1.4% of the surface area of those countries.[4][5] And I haven't even considered using ocean surface area, more efficient solar conversion, higher insolation average, or even solar power satellites. Even at today's low PV efficiencies, there appears to be adequate area to use solar energy to power human civilization on this planet. And no one except those unable to understand more than one concept at a time thinks this is being proposed. Some P-V, some solar thermal, some geothermal, some wind, some hydro, some nuke, some algae-diesel; pretty soon we're telling OPEC to go **** up a rope. |
#66
"Mike Isaksen" wrote in
news:ATwLj.9840$Ug4.1603@trndny01: ... Jay, if your only alternative to keep flying was to drop, say, $40K into a diesel conversion for Atlas, would you? Jay's only choice would be the 235hp SMA diesel for about $100,000 firewall forward. And I don't think they've made any progress toward an STC for his PA28 model, so Jay would have to "transfer" into an Experimental Certificate. Seeing as Jay has expressed his opinion on the government bureaucracy rather strongly, I'd suspect his head would explode going down that road. ;-) At least it would be open then. Bertie |
#67
"Blueskies" wrote in message
... "Al" wrote in message . .. I just happened to see a sticker on a fuel pump today that stated "may contain up to 10% ethanol" while I was filling my car this morning. Upon further investigation with my fuel retailer, the local fuel jobber, and the fuel distributor here in Spokane, Washington that there is a federal mandate to add 9 billion gallons of ethanol per year to the nationwide gasoline fuel stream. A new twist is a 5.1 cent per gallon federal fuel tax break to the oil companies to get this "alternative" fuel into the market. Tomorrow (April 8) is the first day of the program and the dealers get their price tonight. According to my sources, there is a possibility that some retailers may opt out, however if that 5.1 cent break is passed on to them, it won't be likely. Worse than that, htere is NO requirement from the feds to mark the gas pumps with the 'may contain 10%' warning. There may be a local or state requirement to do so though. I wonder if the gas companies will pass on the 5.1 cent savings to us (Not!) to compensate for the degraded performance (read mileage) the contaminated gasoline provides. There is no savings and the 5.1 cents is only to help offset the petroleum distributors' increased cost to provide an inferior product. But enev if there had been any savings: on a purely mathematical basis, presuming the "closed loop" system is working correct for your computer controlled automobile engine, based on a pump price of $3.40 USD, 10% ethanol at 60% of the thermal content of gasolene reduces the value by 13.6 cents for a net loss to the customer of 8.5 cents--even if they reduced the price by 5.1 cents. Ignoring all of the compatibility issues; the 60% efficiency figure would mean that, if "pure" gasolene is worth $3.40, then pute ethanol would be worth $2.04 per gallon. There are indeed a lot of people who claim that, in actual use as a motor fuel, ethanol is actually 80% as efficient as gasolene. However, even if that was true, a 5.1 cent rebate for the use of E10 would still result in a net loss of 1.7 cents. So, we are clearly not receiving a good value! Peter |
#68
Dan Luke wrote:
On Thu, 10 Apr 2008 18:35:05 -0500, Jim Logajan wrote: The total land surface area of the Earth is ~150,000,000 km^2 [3] so the percentage needed is (drum roll, please!) 100*1,700,000/150,000,000 ~= 1.1% A tad over 1% of the land surface - a little over three times the area consumed by water reservoirs and probably much less area than that used for farming. Another comparison is road surface area. I've seen estimates that indicate that roads in the U.S. and UK take up ~1% to 1.4% of the surface area of those countries.[4][5] And I haven't even considered using ocean surface area, more efficient solar conversion, higher insolation average, or even solar power satellites. Even at today's low PV efficiencies, there appears to be adequate area to use solar energy to power human civilization on this planet. And no one except those unable to understand more than one concept at a time thinks this is being proposed. Some P-V, some solar thermal, some geothermal, some wind, some hydro, some nuke, some algae-diesel; pretty soon we're telling OPEC to go **** up a rope. OPEC and oil has little to nothing to do with electricity in North America. -- Jim Pennino Remove .spam.sux to reply. |
#69
On Apr 10, 2:55*pm, Cubdriver usenet AT danford DOT net wrote:
On Tue, 8 Apr 2008 09:34:01 -0700 (PDT), "Robert M. Gary" wrote: I believe out here in California its illegal to sell mogas w/o the ethanol. Good grief. So it's all true about the Left Coast? There was talk at one point of allowing pilots to purchase non-ethanol fuel but it didn't appear sure that anyone would actually be willing to make it and if it would be less expensive than 100LL. The ethanol is mandated by the state by region I believe. -Robert |
#70
On Apr 9, 11:35*am, wrote:
Mxsmanic wrote: M writes: Remember, ethanol is not mixed into the fuel until the local distribution terminal, because it can't be transported in pipelines. Just out of curiosity, why can't it be transported in pipelines? The same reason it can't be used in existing airplanes; pieces of the plumbing start leaking. -- Jim Pennino Remove .spam.sux to reply. Okay, that is true. However since the days of yore Indy 500 cars have run on ethanol (or is it methanol!!). Their plumbing does not leak the alcohol all over the engine all the time. Maybe it would if the race wasn't over so quickly though ... hmmm. I have a hard time believing there isn't a technical solution to this leak problem. It's a problem that could be fixed for new designs. Older planes are screwed of course. Having said all this I think the entire corn ethanol business is an extraordinary boondoggle that's screwing the average American. The Brazilian's do it with sugar cane / beet sugar. Now, I thought they were more corrupt than us? Guess not. |
A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 02:51 PM |
Our Worst Nightmare? | alank | Piloting | 56 | January 10th 07 10:10 AM |
Nightmare (long story) | JJS | Owning | 7 | April 2nd 06 11:34 PM |
Eurofighter is turning into German nightmare | Chad Irby | Military Aviation | 45 | October 4th 03 03:18 AM |
(long) WxWorx arrived... | Tom S. | Piloting | 0 | September 9th 03 04:54 PM |
