#61
On Jun 3, 5:41 pm, wrote:
The prop does not throw air outward. We've been over that one before. The air column actually narrows behind the prop, due to the lowered pressure caused by the air's acceleration. We can see it on cool mornings when the dew point is just below ambient temperature, and the vapor trails off the prop tips outline the periphery of the air column, showing it to be squeezing inward. More on the narrowing of fluid flows behind propellers: Marine propeller: http://www.aip.org/pt/feb00/maris.htm Helicopter rotor: http://www.camrad.com/CAMRADIIresults.html Behind transport props: http://home.att.net/~polar/130contrail.jpg Behind an F4U's prop: http://people.bath.ac.uk/ensmjc/Research/corsair.gif In no case do we see air (or any other fluid) being thrown out centrifugally. Dan |
#62
#63
"Maxwell" luv2^fly99@cox.^net wrote in
: Turbocharging can be set to two different levels: Turbonormalizing, which brings manifold pressure to sea level pressure; and boosting, which raises manifold pressures to more than 30" Hg. If an engine is boosted, the air density in the cylinder at the bottom of the intake stroke could be well above atmospheric. Dan Careful, Bertie the ButtlippS cross-posted this a few messages back. You're trying to explain something to someone on a kook group. Or someone here who is just a k00k. Bertie |
#64
#65
#66
"Ken S. Tucker" wrote in
: On Jun 3, 11:18 am, wrote: On Jun 3, 10:18 am, "Ken S. Tucker" wrote: I wonder if ram scoops were ever installed near the prop tips. Probably too expensive for GA, but a WW2 A/C with tips spinning at what(?) 500-600 mph would give a nice pressure boost. I've read dual phase superchargers were used in recon A/C to get the speed and altitude. Airspeed off the tips is the same as the speed off the inner blade areas, due to the pitch washout across the blade span, so there'd be no advantage to having scoops behind the tips. The propeller's blades are flying at an AOA of between 2 and 4 degrees in cruise flight, anywhere between the tips and hub, because of that pitch variation. See Figure 6-4 of this page:http://www.allstar.fiu.edu/aero/flight63.htm Dan Dan it was a trick question I asked you. Bwawhawhhahwhahwhahwhahwhahhwhahwhahwhahwhahwhahhw haw! Bertie |
#67
Big John wrote in
: On Mon, 2 Jun 2008 12:31:53 +0000 (UTC), Bertie the Bunyip wrote: "Ken S. Tucker" wrote in : On Jun 1, 7:59 pm, wrote: On Jun 1, 8:06 pm, Gezellig wrote: It happens that formulated : In the 1970's Ford sold some cars with "Ram-Air Induction" systems. A scoop mounted on the carb that stuck out above the hood, to ram vast volumes of air into the carb and get way more horsepower. That's what they wanted you to believe. At 60 mph the pressure recovery would have been laughably tiny, but Ford's profits were impressive. Had a Trans Am, scoop was reversed, facing the windshield, had a flap that opened when MP increased. They claimd that the reversed position was at the low pressure point at the base of the windshield hence enhancing the rammed air effect. I don't know, it was cool, the scoop assembly was attached to the engine so that on acceleration you could see the engine sitting down on its mounts as the scopp popped open and lowere ever so slightly. Locating the scoop at the low-pressure point wouldn't do much for ram-air effect, would it? I think the real idea would have been to make sure the driver heard that thing sucking loudly so it sounded like a real powerhouse I once converted a 14 foot outboard runabout to a 13 foot inboard Cracker Box with a Chev 283 straight-shaft setup. The exhausts were water-cooled and exited through the transom. Made so much noise that I made two mufflers and quieted it right down. The carb's flame arrestor stuck up far enough that I had a scoop on the deck, facing away from the cockpit (which was at the back). Everything else was covered. I dropped my Dad off on a gravel bar on a lake once, so he could fish off it while I ran to the far end of the lake to try the fishing there, three or four miles away. He told me he knew when I was coming back; he could hear that Rochester Quadrajet four-barrel open up and suck vast quantities of air; the boat got one mile per gallon at full throttle with that huge carb. But went real fast. I sold it years ago and I bet it don't go real fast no more, with fuel prices the way they are now. Dan I confess to enjoying ancedotal stories. As a monster nut brat I got some tin cans together and built a pulse jet, complete with a flapping duct input, and used a hair dryer for my air input source, in my parents downstairs fireplace. So I pour in some gas into the thing, lite it up, turn on the hair dryer and holy poop, the duct starts fluttering and flames are fluttering out the ass end! It worked! It buzzed! I probably used a pint of gasoline per minute of operation, but that wasn't the point, it was actually seeing the damn thing in operation. Hands on is good stuff. Please do build another one just like that and put it on youtube, then.. I've only ever seen one person die right in front of my eyes before. Bertie ************************************************** ******* Bertie I've seen two. Both stalled and spun in ![]() Big John Neer seen one die in an airplane accident in front of my eyes, but seen the aftermath, unfortunatley. Seen a girl crushed in a crowd right in front of me. Yipes. Saw a few die in an ICU a few years ago. That wasnt so bad, somehow. Bertie |
#68
On Jun 4, 7:56 am, Big John wrote:
On Mon, 2 Jun 2008 11:19:41 -0700 (PDT), "Ken S. Tucker" wrote: On Jun 2, 10:13 am, Tina wrote: On Jun 2, 12:01 pm, "Ken S. Tucker" wrote: On Jun 1, 4:39 pm, Tina wrote: The induction port for the ram air on the m20J bypasses the air filter as well, so we typically observe about a half inch improvement in MP. That's in line with some of the other numbers offered here. I guess there's no free lunch. There is no way we want to have an IO540 pull the airplane along, nor do we want the fuss with turbo charging. The payback for our typical for real flight mission is just not there. My thought was and is that if it was something pretty obvious someone would have done it on a homebuilt. Actually, knowing some of those guys, it does not have to be obvious at all, they are really creative designers. Tina, I think this analysis you posted is good, " It's only a 360 cubic inch engine turning at 2300 RPM or so. Isn't that a demand of, let's see, at 23 inches mp at sea level that's 23/30 * 2300/2 * 360 / 12^3 or 180 cubic feet a minute? " I see Tango 2 Denny has some interesting ideas. Ken Well, I think it's a dead issue for us. What is fun to think about is, let's see, about 200 cubic feet a minute, that's 40 cubic feet of oxygen a minute, or about 3 pounds. For 50% more O2, 1.5 pounds a minute, or say 20 pounds to get to a pleasantly high altitude. Maybe that translates in to dewer weighing a total of 50 pounds with liquid O2? But it would make 15 inches of MP look like 22 or so as far as the engine is concerned. I better get back to my day job. Without crackin' the books and pounding the abacus, you look like +/- 20% using BoE (Back of Envelope) calculation, which means you get either 80% or 120% on your physics exam, you choose. Resolved: psychologists should not be permitted to minor in the physical sciences. All in favor? OR pilots should not be permitted to engage in psychology in this group, now what's the chances of that happening...is "nil" close :-). Ken PS: What's the rationale of the 12,000' cruise? You know about the "bends" don't you, if not just read Berties post! ************************************************** * Ken Have you ever talked to anyone who got the bends flying? I have thousands of hours and never have. I have gone to 43K+ and made supersonic dives to 10K +/- with no problems. I have cruised for hours at 30K cockpit pressure and no problems during let down and landing. Is Mt. Everest summit at ~29K? You can get a quick overview here, http://en.wikipedia.org/wiki/Decompression_sickness Ken Big John |
#69
: On Jun 2, 10:13 am, Tina wrote: On Jun 2, 12:01 pm, "Ken S. Tucker" wrote: On Jun 1, 4:39 pm, Tina wrote: The induction port for the ram air on the m20J bypasses the air filter as well, so we typically observe about a half inch improvement in MP. That's in line with some of the other numbers offered here. I guess there's no free lunch. There is no way we want to have an IO540 pull the airplane along, nor do we want the fuss with turbo charging. The payback for our typical for real flight mission is just not there. My thought was and is that if it was something pretty obvious someone would have done it on a homebuilt. Actually, knowing some of those guys, it does not have to be obvious at all, they are really creative designers. Tina, I think this analysis you posted is good, " It's only a 360 cubic inch engine turning at 2300 RPM or so. Isn't that a demand of, let's see, at 23 inches mp at sea level that's 23/30 * 2300/2 * 360 / 12^3 or 180 cubic feet a minute? " I see Tango 2 Denny has some interesting ideas. Ken Well, I think it's a dead issue for us. What is fun to think about is, let's see, about 200 cubic feet a minute, that's 40 cubic feet of oxygen a minute, or about 3 pounds. For 50% more O2, 1.5 pounds a minute, or say 20 pounds to get to a pleasantly high altitude. Maybe that translates in to dewer weighing a total of 50 pounds with liquid O2? But it would make 15 inches of MP look like 22 or so as far as the engine is concerned. I better get back to my day job. Without crackin' the books and pounding the abacus, you look like +/- 20% using BoE (Back of Envelope) calculation, which means you get either 80% or 120% on your physics exam, you choose. Resolved: psychologists should not be permitted to minor in the physical sciences. All in favor? OR pilots should not be permitted to engage in psychology in this group, now what's the chances of that happening...is "nil" close :-). Ken PS: What's the rationale of the 12,000' cruise? You know about the "bends" don't you, if not just read Berties post! I double everyone up. Bertie |
#70
: On Jun 4, 7:56 am, Big John wrote: On Mon, 2 Jun 2008 11:19:41 -0700 (PDT), "Ken S. Tucker" wrote: On Jun 2, 10:13 am, Tina wrote: On Jun 2, 12:01 pm, "Ken S. Tucker" wrote: On Jun 1, 4:39 pm, Tina wrote: The induction port for the ram air on the m20J bypasses the air filter as well, so we typically observe about a half inch improvement in MP. That's in line with some of the other numbers offered here. I guess there's no free lunch. There is no way we want to have an IO540 pull the airplane along, nor do we want the fuss with turbo charging. The payback for our typical for real flight mission is just not there. My thought was and is that if it was something pretty obvious someone would have done it on a homebuilt. Actually, knowing some of those guys, it does not have to be obvious at all, they are really creative designers. Tina, I think this analysis you posted is good, " It's only a 360 cubic inch engine turning at 2300 RPM or so. Isn't that a demand of, let's see, at 23 inches mp at sea level that's 23/30 * 2300/2 * 360 / 12^3 or 180 cubic feet a minute? " I see Tango 2 Denny has some interesting ideas. Ken Well, I think it's a dead issue for us. What is fun to think about is, let's see, about 200 cubic feet a minute, that's 40 cubic feet of oxygen a minute, or about 3 pounds. For 50% more O2, 1.5 pounds a minute, or say 20 pounds to get to a pleasantly high altitude. Maybe that translates in to dewer weighing a total of 50 pounds with liquid O2? But it would make 15 inches of MP look like 22 or so as far as the engine is concerned. I better get back to my day job. Without crackin' the books and pounding the abacus, you look like +/- 20% using BoE (Back of Envelope) calculation, which means you get either 80% or 120% on your physics exam, you choose. Resolved: psychologists should not be permitted to minor in the physical sciences. All in favor? OR pilots should not be permitted to engage in psychology in this group, now what's the chances of that happening...is "nil" close :-). Ken PS: What's the rationale of the 12,000' cruise? You know about the "bends" don't you, if not just read Berties post! ************************************************** * Ken Have you ever talked to anyone who got the bends flying? I have thousands of hours and never have. I have gone to 43K+ and made supersonic dives to 10K +/- with no problems. I have cruised for hours at 30K cockpit pressure and no problems during let down and landing. Is Mt. Everest summit at ~29K? You can get a quick overview here, http://en.wikipedia.org/wiki/Decompression_sickness Ken You're an idiot. How's that kill file working out, BTW? Bwsawahwhahwhahwhahwhahhw! Bertie |
