Building an electronic Angle of Attack indicator
Old May 9th 09, 02:30 PM posted to rec.aviation.homebuilt
Mike[_27_]
Default Building an electronic Angle of Attack indicator
Has anyone built an electronic angle of attack meter kit. It seems to
be something that would be easy to design but beyond my feeble
electronics background.
I have seen the products that are out there and they are simple
differential pressure gauges and are expensive. I don't like the
round differential pressure gauges that many of the companies offer
for this kind of system. I was wondering if there would be a way to
put something together that would light up different color LED's for
the different levels of lift that we could build at home without
having to pay out hundreds of dollars for a prebuilt one.
Old May 9th 09, 06:50 PM posted to rec.aviation.homebuilt
RST Engineering - JIm
If somebody can tell me how to convert angle of attack to an electrical
signal, the rest is rather trivial.
"Mike" wrote in message
Old May 9th 09, 07:03 PM posted to rec.aviation.homebuilt
Dan[_12_]
Use variable capacitance, variable reluctance, resistor strip or
synchro connected to a vane. For a real giggle do as some Air Force
systems and employ a slotted, rotating cone for a probe. It involves a
feedback loop.
Dan, U.S. Air Force, retired
Old May 9th 09, 07:15 PM posted to rec.aviation.homebuilt
Those might get me airspeed but I'm not at all sure how you would get theta
from any one of these schemes.
feedback loop.
Old May 9th 09, 07:35 PM posted to rec.aviation.homebuilt
Jim Logajan
theta from any one of these schemes.
I believe he means the vane is lightweight and freely pivots up or down so
that it is always pointing into the relative wind. The angle the vane makes
with some reference line on the wing or fuselage is thus the AoA. I'd post
a link to a picture of what it would look like (pretty simple concept) but
can't see to find one!
Just think of the yaw string on gliders (e.g. the red string in this
pictu http://www.highonadventure.com/Hoa08...eYawString.jpg)
but used to show vertical component of the relative wind, not horizontal.
a feedback loop.
Old May 9th 09, 07:58 PM posted to rec.aviation.homebuilt
Jim Logajan
Jim Logajan wrote:
I'd post a link to a picture of what it would look like
(pretty simple concept) but can't see to find one!
Okay, found some, like this one:
http://commons.wikimedia.org/wiki/Fi...ndicator_1.jpg
And a simple mechanical kit (looks like no longer available):
http://www.aircraftspruce.com/catalo...baconsaver.php
My suspicion is that designers get fancy and use things like two non-
parallel pitots and use some mechanism to compute the AoA from their
differential pressures, which is then presented in some fancy digital
display. The irony is that AoA is easy to show, and if one is flying a
glider or pusher, a simple mechanical device could probably be mounted so
it is visible out front (i.e. "heads up") so that one can see the AoA at
the same time one is controlling their approach. But I suppose it'd be too
distracting during crusing flight and mess up the "look" of the airplane.
pictu
http://www.highonadventure.com/Hoa08...eYawString.jpg) but
a feedback loop.
Old May 10th 09, 06:30 PM posted to rec.aviation.homebuilt
And after all is said and done, we remind ourselves that we are supposed to
be building inexpensive airplanes that look good and fly well.
So a vane on a synchro? Sure, we had those on the Boeing 3-holer (7-deuce)
at a cost of slightly less than $10k a copy in 1965 dollars. Surplus
synchros? Sure, now you are doing a one-off and how to tell another builder
how to use another brand of surplus synchro isn't feasible...not to mention
the fact that most synchros are set up to use the 115v 3phase power that the
Air Force/Boeing is so pleased with.
Or a gas tank sender with a big flap on it? Well, that looks like hell,
doesn't it? Besides that wirewound pot on the gas gauge needs some REAL
FORCE to push it around and consumes a fair amount of current in the
process.
Or some thermistors inside the pitot? WIthout a little more description you
can't tell exactly what the scheme of that is. One thermistor on the inside
top of the pitot and one on the inside bottom, each thermistor heated
equally (difficult task) and then you hope that the incoming air is laminar
and not swirling around? This might be feasible with a little more
explanation.
Differential pressure sensors? Haven't done the research lately, but the
last time I looked Motorola had stopped making the inexpensive variety and I
don't know if anybody else picked up that ball.
So, let's take it from scratch and think about what the optimum solution for
cost, looks, and reliability might be ... and the rotated yaw string is a
good idea except for the fact that 95% of the homebuilts are tractors and
the prop blast will decalibrate anything we might come up with...
Old May 11th 09, 05:53 AM posted to rec.aviation.homebuilt
On Sat, 09 May 2009 12:35:38 -0500, Jim Logajan
a feedback loop.
See
http://www.pegazair.on-the-net.ca/Cl...rframe/lri.htm
and use electronic differential pressure in place of the DWYER
MINIHELIC II.
The diagram of the probe dissapeared, sorry.
Old May 9th 09, 09:32 PM posted to rec.aviation.homebuilt
Dan[_12_]
feedback loop.
The vane types are self explanatory.
http://www.aircraftmech.com/pics/aoa.jpg
http://spaceagecontrol.com/4239-01image.jpg
The cone type is a bit more complicated. Picture a hollow stainless
cone with two sets of slots running between base and apex. The slots
face towards the front of the airplane. Each set opens to its own
chamber in the cone. The pressure in each chamber is measured and the
cone is rotated until the pressures are equal. The position is then
transmitted to an indicator.
http://www.avionics-specialties.com/...thumb_stat.jpg
The cone types are usually heated to prevent icing.
If I were to build one for small aircraft I'd go with a vane and
resistance strip. In that case a standard d'arsonval meter or column of
LEDs could be used to indicate AOL.
Pressure differential systems have the disadvantages of icing or dirt
contamination.
Old May 15th 09, 01:45 AM posted to rec.aviation.homebuilt
Dan D[_2_]
Didja ever look at the nose of the x-15? The "ball" was a bit of magic!
"RST Engineering - JIm" wrote in message ...
feedback loop.
Prop angle of attack vs age sid Piloting 47 July 13th 08 05:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 01:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 07:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 03:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
