I would not have thought this was possible
Old July 11th 09, 07:07 AM posted to rec.aviation.piloting
Ron Garret
Default I would not have thought this was possible
http://www.youtube.com/watch?v=XZiP4...eature=related
Old July 11th 09, 07:32 AM posted to rec.aviation.piloting
Ron Garret
And indeed, it's fake. Bummer.
http://www.snopes.com/photos/airplane/onewing.asp
rg
Old July 11th 09, 07:23 PM posted to rec.aviation.piloting
Franklin[_8_]
rg
http://www.youtube.com/watch?v=L_gpPbpONK4
Some people WANT to believe this even though they need only look at a jet
engine for 2 seconds to know it's fake..
Old July 11th 09, 08:16 PM posted to rec.aviation.piloting
Ron Garret
rg
Actually, I was under the impression that the sucked-into-jet-engine
video was real. It's certainly plausible.
Even the one-wing landing video requires fairly close inspection to show
that it's a fake. It's quite well done IMHO.
rg
Old July 11th 09, 10:10 PM posted to rec.aviation.piloting
John E. Carty
"Ron Garret" wrote in message
rg
That one actually happened :-)
rg
Old July 11th 09, 11:01 PM posted to rec.aviation.piloting
Mike Ash
It's easy to be taken in by it, I agree, but I think that once you come
to the proper realizations it's not too hard to see that it must be
fake. To me, the most damning mistake in the video is the fact that the
plane sits perfectly level after the landing. Wings are *heavy*. Having
only one would make that plane tip right over onto its wingtip. Once I
realized what I was looking at, this to me was ironclad proof that they
were filming a plane with two intact wings, with the angle cleverly
chosen to hide one, and the rest done by some special effects trickery.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old July 12th 09, 07:26 PM posted to rec.aviation.piloting
Franklin[_8_]
Mike Ash wrote:
show that it's a fake. It's quite well done IMHO.
come to the proper realizations it's not too hard to see that it must
be fake. To me, the most damning mistake in the video is the fact that
the plane sits perfectly level after the landing. Wings are *heavy*.
Having only one would make that plane tip right over onto its wingtip.
Once I realized what I was looking at, this to me was ironclad proof
that they were filming a plane with two intact wings, with the angle
cleverly chosen to hide one, and the rest done by some special effects
trickery.
People believe almost anything once they suspend common sense. Just look
at a jet intake for 2 seconds. No calculations necessary.
Here's another http://www.youtube.com/watch?v=NTzSxxH2s3U
And another cat fake: http://www.youtube.com/watch?v=5dzi_8Rscfs
Old July 13th 09, 01:27 AM posted to rec.aviation.piloting
We regularly take wings off airplanes for repairs of one sort or
another. The airplane does NOT tip onto its other wingtip. The density
of wing structures is very light; like most of the rest of the
airframe, it's nearly all airspace. A 172's wing weighs maybe 70 or 80
pounds, max.
See this video about the wing-losing video, which was clearly faked.
See especially the last few seconds:
http://www.youtube.com/watch?v=I89EMDZ0dsc
Dan
Old July 12th 09, 03:38 AM posted to rec.aviation.piloting
Morgans[_7_]
Real. The flash you see, as he goes in, is his helmet FOD'ing the engine.
His shoulders were wider than the intake duct, which stopped him from going
through the turbine.
Sore and bruised, but lucky.
Old July 12th 09, 05:25 AM posted to rec.aviation.piloting
Jim Logajan
engine. His shoulders were wider than the intake duct, which stopped
him from going through the turbine.
Wow - the whole issue is a mess of fact and fiction. Consider:
1) There appear to a bunch of obviously faked videos on Youtube of
people getting "sucked" into jet engines. This makes it tedious to sort
out the legit from the bogus.
2) Some videos, like this one showing a helmet (cranial) getting sucked
off a guys head, seem perfectly legit:
http://www.youtube.com/watch?v=OswpNAH9nrk
3) I believe the velocity of the suctioned air should fall off roughly
with the inverse square of the distance from the intake - and so the
suction force for a fixed area should be roughly proportional with
inverse cube of the distance from the intake. Meaning you have to get
dang close to suck in something as dense and heavy as a person! (I know
I have problems vacuuming up heavy "grit"! Experiments with a vacuum
cleaner are easy and I'm sure everyone is aware how quickly the suction
force drops off.)
4) Although circumstances would make it rare, it appears it may have an
been issue as long as a few decades ago because there appears to be an
article titled "Survival after suction into jet engine intake" by Ayres,
ML in the May 1973 journal "Injury":
http://www.ncbi.nlm.nih.gov/pubmed/4710924
This seems to indicate the article is case reports:
http://www.unboundmedicine.com/medli...engine_intake_
A thought about handicapping....... XYZ Soaring 22 October 2nd 08 07:24 AM
T-18 more roomy than I had thought it would be Sliker[_3_] Home Built 11 April 17th 08 04:04 PM
Just when I thought I'd heard it all:-) Dudley Henriques Piloting 14 November 23rd 05 08:18 PM
A thought on BRS Martin Gregorie Soaring 47 April 29th 04 06:34 AM
I thought some of these are classics goneill Soaring 0 April 8th 04 10:51 AM
