#71
![]() "Larry Dighera" wrote in message ... If the controller who issued the "remain clear of Class C" instruction was not the controller responsible for operations inside of the Class C airspace, it would seem that radio contact with the controller who is would grant permission to enter. Entry is based on establishing two-way radio communications with the ATC facility, not with a specific controller. |
#72
![]() "Travis Marlatte" wrote in message ink.net... Sure it does. My position is that radio contact where the controller uses your tail number and lacking an explicit "remain clear" grants permission to enter the class C. Note 1 above says this. It doesn't. You stated that subsequent use of the tail number of an aircraft, that had previously established communications and been told to remain clear, especially with the phrase "radar contact", permitted entry to the Class C airspace. The AIM does not support that viewpoint. ATC can instruct aircraft that have established communications to remain outside of Class C airspace. FAA Order 7110.65N Air Traffic Control Chapter 7. Visual Section 8. Class C Service- Terminal 7-8-4. ESTABLISHING TWO-WAY COMMUNICATIONS Class C service requires pilots to establish two-way radio communications before entering Class C airspace. If the controller responds to a radio call with, "(a/c call sign) standby," radio communications have been established and the pilot can enter Class C airspace. If workload or traffic conditions prevent immediate provision of Class C services, inform the pilot to remain outside Class C airspace until conditions permit the services to be provided. PHRASEOLOGY- (A/c call sign) REMAIN OUTSIDE CHARLIE AIRSPACE AND STANDBY. You seem to be saying that once a "remain clear" has been issued that the only way to reverse that is with an explicit "cleared to enter the class C." The AIM doesn't really address this sequence of events but does not refer to a specific clearance to enter the class C either. I'm saying that an instruction to remain clear of Class C airspace issued to an aircraft that has established two-way radio communications remains in effect until another instruction is issued that permits that aircraft to enter Class C airspace. That is not my opinion, that is a simple fact. I think it is the case as presented by the original poster. He had received a "remain clear" prior to take off. After departure, he had a radio exchange that included his tail number and took that as permission to enter the class C. Yes. He erred. That radio exchange was not permission to enter Class C airspace. His instruction to remain clear was still in effect because no instruction permitting entry had been issued. Again, after departure, the pilot had a radio exchange where the controller used his tail number. That grants permission to enter the class C. And again, that is not the case. A subsequent radio exchange after communications have been established does not, by itself, override the instruction to remain clear. I don't know who told you otherwise but whoever it was does not have a correct understanding of Class C airspace. I am based at a class C airport. Which only proves that one can be based in Class C airspace without understanding it. I have heard "remain clear" many times. I have never heard "cleared to enter." As you gain experience you probably will. Subsequent radio contact that uses my tail number is enough to rescind the "remain clear" instruction. I'm sure you believe that. That statement is unsupported by any documentation and is completely illogical. I've explained this as simply as I can and you still don't understand. I don't think you're even trying to understand. Fine. Believe whatever you choose. |
#73
ink.net... Right. The pilot left the frequency so did not hear several calls from the controller. What "several calls"? It is hypothetically possible that the controller never called back. I certainly have no shortage of instances where ATC simply forgot I exist, even when I was flying on an instrument flight plan. It's not your hypothetical situation; you don't get to pick and choose the specifics. The person posing the hypothetical situation does. The controller saw the target proceeding around the Class C airspace, concluded the pilot no longer wished to transit Class C airspace, so he discarded the strip. Says who? Who knows what the controller did or did not do, except that controller? The pilot changed his mind about Class C services. The controller discarded the strip. Nothing was carried forward to the next day. The next day's request had nothing to do with the previous day's. So your claim is that the question of whether two-way radio contact suffices to allow entry into the Class C hinges on whether there's a flight strip? How in the world is the pilot to know whether a flight strip exists or not? That's not the sort of thing ATC is regularly reporting to us. What about the pilot who is told to remain clear, but who never gets a flight strip in the first place? What if the strip is discarded (for whatever reason) before two-way radio contact is made? Even if only a short period of time has passed? How is the pilot to know that they may enter the Class C, since they won't know the status of the flight strip, whether it ever existed, and whether it still exists? There is no way for the pilot to know whether a flight strip still exists, therefore the existence of the flight strip is completely irrelevant to the question of whether the pilot may enter the Class C or not. A controller might think it's completely black and white -- since after all, they have the strip right in front of them or they don't -- but that controller would be an idiot for thinking so, failing to comprehend that they only have half the equation. Pete |
#74
![]() "Peter Duniho" wrote in message ... What "several calls"? The several calls to the aircraft from the controller he had established communications with and who had told him to remain clear. Once the workload or traffic conditions that had prevent immediate provision of Class C services were under control the controller would have called the aircraft so he could provide the requested services. Those calls. It's not your hypothetical situation; you don't get to pick and choose the specifics. The person posing the hypothetical situation does. Sorry. I assumed it was a realistic hypothetical. My mistake. Says who? Says me. Who knows what the controller did or did not do, except that controller? I know what controllers do. So your claim is that the question of whether two-way radio contact suffices to allow entry into the Class C hinges on whether there's a flight strip? Nope. How in the world is the pilot to know whether a flight strip exists or not? He wouldn't, nor is it relevant to the pilot. That's not the sort of thing ATC is regularly reporting to us. As far as you understand. What about the pilot who is told to remain clear, but who never gets a flight strip in the first place? What about him? What if the strip is discarded (for whatever reason) before two-way radio contact is made? Even if only a short period of time has passed? How is the pilot to know that they may enter the Class C, since they won't know the status of the flight strip, whether it ever existed, and whether it still exists? The pilot should know that he may not enter Class C airspace because radio contact has not been made. There is no way for the pilot to know whether a flight strip still exists, therefore the existence of the flight strip is completely irrelevant to the question of whether the pilot may enter the Class C or not. Exactly. A controller might think it's completely black and white -- since after all, they have the strip right in front of them or they don't -- but that controller would be an idiot for thinking so, failing to comprehend that they only have half the equation. Why are you fixated on the strip? The strip has nothing to do with entering Class C airspace. What made you think it did? |
#75
ink.net... Sorry. I assumed it was a realistic hypothetical. My mistake. There's nothing unrealistic about a controller forgetting about traffic. Happens all the time. Says who? Says me. That was rhetorical. You don't have the authority to set the parameters for the hypothetical situation, since you didn't pose the situation. I know what controllers do. You know what you'd like all controllers to do always. But they don't comply. Why are you fixated on the strip? The strip has nothing to do with entering Class C airspace. What made you think it did? Your claim that the absence of a strip is why the "remain clear" is no longer valid the next day. Either the strip is important or it's not. If it's not (as you are now saying), then its absence the next day is completely irrelevant to the question of whether the "remain clear" is still in effect. Pete |
#76
In article . net,
Steven P. McNicoll wrote: I'm saying that an instruction to remain clear of Class C airspace issued to an aircraft that has established two-way radio communications remains in effect until another instruction is issued that permits that aircraft to enter Class C airspace. That is not my opinion, that is a simple fact. So Stephen, what specifically would constitute another instruction that permits entry, and don't try and tell me that it would have to include "cleared to enter" because that would be incorrect phraseology with respect to Class C airspace. |
#77
ink.net... "Travis Marlatte" wrote in message ink.net... It doesn't. You stated that subsequent use of the tail number of an aircraft, that had previously established communications and been told to remain clear, especially with the phrase "radar contact", permitted entry to the Class C airspace. The AIM does not support that viewpoint. ATC can instruct aircraft that have established communications to remain outside of Class C airspace. To enter class C airspace, the FARs say that you have to establish two-way radio communication. The AIM provides a few examples which indicate that no explicit clearance is required. I agree that ATC can establish communication but instruct the pilot to remain clear. It is what can happen next that we have been debating. From the FARs, the AIM , and my experiences, the acknowledgement of a particular plane by ATC establishes two-way radio communication and is sufficient for the plane to enter the class C - even after the issuance of a "remain clear." You seem to be saying that once a "remain clear" has been issued that the only way to reverse that is with an explicit "cleared to enter the class C." The AIM doesn't really address this sequence of events but does not refer to a specific clearance to enter the class C either. I'm saying that an instruction to remain clear of Class C airspace issued to an aircraft that has established two-way radio communications remains in effect until another instruction is issued that permits that aircraft to enter Class C airspace. That is not my opinion, that is a simple fact. It does seem to be your opinion and it is far from a simple fact. There is no language in the FARs or AIM that clearly supports either of our opinions. There is no text that says anything about what must happen after a "remain clear" has been issued for class C. I think it is the case as presented by the original poster. He had received a "remain clear" prior to take off. After departure, he had a radio exchange that included his tail number and took that as permission to enter the class C. Yes. He erred. That radio exchange was not permission to enter Class C airspace. His instruction to remain clear was still in effect because no instruction permitting entry had been issued. There is no such thing as an instruction to permit entry into class C. Again, after departure, the pilot had a radio exchange where the controller used his tail number. That grants permission to enter the class C. And again, that is not the case. A subsequent radio exchange after communications have been established does not, by itself, override the instruction to remain clear. I don't know who told you otherwise but whoever it was does not have a correct understanding of Class C airspace. The FARs say that two-way radio communication is sufficient. The AIM says that two-way radio communication is sufficient. Where does it say otherwise? If the controller intended for the pilot to remain clear that he would have simply ignored the pilot's radio calls or would have repeated the "remain clear." For the scenario described by the original poster, the departure controller instructed him to remain clear of the class C. Once in the air, the radio exchange that occured established two-way radio communication and was sufficient for him to enter the class C. I am based at a class C airport. Which only proves that one can be based in Class C airspace without understanding it. Or, that I'm right. I have heard "remain clear" many times. I have never heard "cleared to enter." As you gain experience you probably will. I'll agree with that. I'm sure some day that a class C or D controller will say something like "cleared to enter ..." but it is not necessary and I don't need to hear it whether or not I have been told to remain clear. Subsequent radio contact that uses my tail number is enough to rescind the "remain clear" instruction. I'm sure you believe that. That statement is unsupported by any documentation and is completely illogical. I've explained this as simply as I can and you still don't understand. I don't think you're even trying to understand. Fine. Believe whatever you choose. There is no documentation to support your point of view either. My position is consistent with the documentation that does exist. It is consistent with my experiences at class C and D airports. It is not completely illogical. I would suggest that having this ambiguity about a clearance to enter the class C/D in the FARs in the first place is illogical. You have explained it very simply and I do think that I understand what you are saying. Let me summarize to be sure. You claim that once a controller has issued a "remain clear" for a class C or D airspace that an explicit "cleared into the class C or D airpspace" or some instruction that requires entry is necessary before the pilot should enter. I disagree with you. I am trying to map what you are saying to the documentation and to my experiences. They don't seem to agree. ------------------------------- Travis |
#78
Ok Steven. New hypothetical.
Manly Piper 54321 calls approach from the ground desiring to enter Class C airspace after takeoff. Ralph at approach says "Piper 54321after takeoff remain clear of the class C" Ralph then goes off shift. Manly Piper takes off and begins to maneuver around the class C. He calls approach, and George annswers "Piper 54321 say direction of flight" Is Manly Piper permitted to enter the class C? What bearing toes Ralphs instruction have? What bearing does George's instruction have? Does the Manly Piper need to know whether it's Ralph or George? Does George need to know that Ralph told the Manly Piper to stay clear, or does George get to start with a clean slate and make his own evaluation? Jose -- (for Email, make the obvious changes in my address) |
#79
#80
ink.net... The pilot changed his mind about Class C services. The controller discarded the strip. Nothing was carried forward to the next day. The next day's request had nothing to do with the previous day's. You still haven't answered the question of *when* you claim the remain-clear instruction expires (in the sense that it no longer need be explicitly rescinded in order for subsequent two-way communication to constitute permission to enter). Is it when the pilot changes his mind? When the controller discards the strip? After ten minutes? At midnight, when the next day starts? Or when? You acknowledge that the remain-clear doesn't carry forward forever. But if there's no way to say when it stops, then (as others have proposed) a plausible alternative interpretation is that it stops immediately, in the sense that *any* subsequent call-sign "handshake" with ATC establishes permission to enter (unless the remain-clear is then repeated). --Gary |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Windshields - tint or clear? | Roger Long | Piloting | 7 | February 10th 04 02:41 AM |
Is a BFR instruction? | Roger Long | Piloting | 11 | December 11th 03 09:58 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
