Keep your hand off the release handle during aero tows!
Old October 11th 13, 01:01 PM posted to rec.aviation.soaring
Del Copeland
Default Keep your hand off the release handle during aero tows!
I have visited your site (Dunstable) quite recently and your
winch launches look pretty much the same as what we do at
Lasham these days, presumably because you have taken on
board the recommendations of the BGA Safe Winch Launching
Initiative. This hasn't always been the case, as your launches
used to make us gasp when we visited. The explanation given
was that you have a small site and had to get to get the most
height out of your launches. BTW I don't believe a reasonably
gentle and controlled rotation costs any launch height. You might
get a momentary overspeed, which is not critical low down, but
this then gets converted back into height as you pull back to
control the speed once established in the full climb.
Derek Copeland
At 11:20 11 October 2013, Justin Craig wrote:
At Dunstable we operate a 6 drum Van Gelda winch and have
done so for some
25+ years. It has NEVER been taught to start the launch with
the stick on
the back stop, in fact quite the reverse then followed by gentle
rotation
into a steeper climb. Given the operational restrictions of the
site, we do
climb "steeper" than at other sites, however certainly NOT
before we have a
safe height and safe airspeed to do so.
At 10:20 11 October 2013, Del Copeland wrote:
That's what we told to do when we first acquired our Tost
winches at Lasham, in order to contain the speed and get the
highest possible launches. Prior to that we autotowed, where
you
had to initially climb quite gently as the acceleration was slow
and it took time to build up a safe speed. After a few cases
when
K8's and similar lightweight gliders went into near vertical
climbs
before breaking the weak link, we backed off the instruction.
Fortunately we didn't kill any of the pilots. Dunstable went on
launching quite steeply for some years until they had a
fatality
caused by a flick spin. Certainly when we visited that club we
always used to hold our breath as we watched them winch
launching gliders. Some German pilots seem to pull up more
steeply than we now do, and I note from the accident
statistics
published earlier in this thread that they have had a couple of
flick spin fatalities in recent times.
Derek Copeland
At 09:29 11 October 2013, John Galloway wrote:
At 06:31 11 October 2013, Del Copeland wrote:
One of the reasons the UK historically had a poor winch
launching safety record was that we copied German
methods.
In
particular, when we first had powerful German Tost
winches
we
were told to start with the stick hard back to contain the
speed.
This led to a number of (usually fatal) flick spin accidents,
so
we
realised that this was not a good idea, as have the
Germans.
We
now start with the stick forward of centre and control the
rotation rate, and haven't had a flick spin accident for
several
years.
Del, when you say "we copied the German methods etc" -
who
is
the "we"? It was 1969 that I first trained and soloed on the
winch
in the UK and I have never personally encountered
instruction
to
start a winch launch with the stick hard back to contain the
speed.
John Galloway
  #72
Old October 11th 13, 02:17 PM posted to rec.aviation.soaring
George Knight
This discussion, that started as one about whether to hold the release
during an aerotow launch, has focussed on the risk to the glider pilot if a
wing drops during the launch and subsequently migrated to become a debate
about winch launch techniques.
The poor chap who has been forgotten in all this is the tug pilot! Over
the years a number of tug pilots in different countries have been killed by
glider pilots getting out of position and going too high too quickly. This
results in a big reduction in the tug's airspeed towards the stall, and
since it no longer has enough elevator authority the glider raises the
tugs tail and points it at the ground. Below about 700' a tug upset is
probably fatal for the tug pilot - but only a minor inconvenience to the
glider pilot.
Tug upsets, once triggered, occur in a very short elapsed time period -
probably two or three seconds. This does not give the glider pilot time to
search for the cable release and pull it so as to save the tug pilot's
life.
On aerotow a glider pilot should have his hand touching the release, or
holding a loop of nylon connected to it, if the stick movement would
otherwise be restricted until at least 1,000'. Tug pilots are doing you a
service. Respect them by being able to release instantly if the tow goes
wrong.
One entry in this thread stated that tows can be very rough and that the
release might get pulled by accident. Much better that than kill a tug
pilot.
  #73
Old October 11th 13, 03:11 PM posted to rec.aviation.soaring
Del Copeland
Totally agree George. However the tug pilot should have a
release at his end which he is perfectly entitled to pull if things
are getting out of hand.
Derek Copeland
release
glider pilot if a
become a debate
pilot! Over
been killed by
quickly. This
and
raises the
upset is
to the
glider pilot.
period -
pilot time to
pilot's
life.
release, or
would
doing you a
tow goes
wrong.
and that the
a tug
pilot.
  #74
Old October 11th 13, 04:09 PM posted to rec.aviation.soaring
George Knight
Agreed, but depending on the tug being flown this may be more difficult
than for the glider pilot. The tug pilot will normally have one hand on
the stick and the other on the throttle/gas so at a moment when he is
probably being subjected to a violent downward 'bunt' he needs to let go of
something (the throttle), look for the release, grab it and operate it. On
some tugs the release is near the throttle, on others it is in the roof, it
may be on his left when he has his right hand on the throttle. Evidence
suggests that tug pilots are not able to react fast enough.
The onus must be on the glider pilot not to put the tug and its pilot at
risk. If the glider pilot has his hand touching the release:
1. He/she can pull it faster than the tug.
2. The glider pilot is in a better position to see/realise that the tow is
going wrong. Unless the tug pilot is looking in the mirror at the right
moment, by the time he feels the speed going and the nose dropping it is
probably too late if he is much below 1,000'.
Derek Copeland
release
glider pilot if a
become a debate
pilot! Over
been killed by
quickly. This
and
raises the
upset is
to the
glider pilot.
period -
pilot time to
pilot's
life.
release, or
would
doing you a
tow goes
wrong.
and that the
a tug
pilot.
  #75
Old October 11th 13, 04:45 PM posted to rec.aviation.soaring
Gary Adams
I don't have a 3rd hand to hold the tow release. Practice tells me when I have aileron control. Flying my '20, my left hand is just as busy as the right. I agree with B4's description. I don't look to see what the ASI is saying. Sliding from flap 2 to flap 4 and the plane lifts off by itself.
On Friday, October 4, 2013 1:37:45 PM UTC-4, Soartech wrote:
In an ASW19, 20 or 27 it is common practice (even mentioned in the POH) to start an aero tow with partially deployed spoilers to help keep ailerons effective at low speeds. At around 30 knots put in spoilers and move flaps from 2 to 4. Works great.
Sounds OK in theory. An engineer probably came up with the POH entry, but....
Who has time to look at the airspeed, look at the runway, tow plane and keep it all straight plus close spoilers and change flaps at a certain speed? With our clubs 260 HP towplane it all happens fast! Ailerons seem to work fine in about 3 seconds.
  #76
Old October 11th 13, 05:54 PM posted to rec.aviation.soaring
glider pilot.
life.
wrong.
pilot.
Hi George,
Thanks for your comments. You are correct that we do need to remember the amazing guys and gals up in the tow planes and remember the risks they take to tow us up for our own fun. That said, I would like to assert that there have been many more accidents and bent ships from gliders accidentally releasing at low altitudes because their hand was on the release than tow planes being pulled into the ground because a hand was NOT on the release.
Bruno - B4
  #77
Old October 11th 13, 07:51 PM posted to rec.aviation.soaring
Mephistophilis __
At 16:54 11 October 2013, wrote:
Hi George,
remember the
a=
risks they take
that there
accidentally
rele=
than tow
plane=
release.=20
Bruno - B4
However.... it's not the number of accidents that really count, it's
both the number of occurrences and the severity of the outcome
you need to consider. The pilot of a "bent ship" released
accidentally at low altitude will probably walk away with only his
pride and wallet dented. The tug pilot in an upset incident will
almost certainly not walk away. So you can't simply choose
between the two assuming they are equally serious. To stop the
serious/fatal accident you may have to put up with a slight
increase in non-serious accidents. So if someone does
accidentally release because they hit turbulence, scrapes a
glider in the field they rapidly choose the lesson learned is not
"should have had my hand away from the release" it is "...these
things happen, at least you didn't kill the tug pilot too"
In my own experience the time between the last "if the rope
breaks now I will land ahead" and the first ""if the rope breaks
now I will return to the airfield" is actually quit small, even in the
most hostile terrain, and doing this in your head every launch
certainly focus the mind to not accidentally release where it
really matters
  #78
Old October 11th 13, 08:36 PM posted to rec.aviation.soaring
Del Copeland
The main thing is to ensure that the glider pilot's arm is not at full
stretch when holding the release knob, so there is a bit of slack in
the system and he is not likely to pull it accidentally due to
turbulence etc. Perhaps an extension cord should be attached if
the release knob is difficult to get at or too far away.
Derek Copeland
Hi George,
remember the
a=
risks they take
there
accidentally
rele=
tow
plane=
release.=20
Bruno - B4
  #79
Old October 11th 13, 09:03 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
I went solo in a glider in 1962 and for about 5 years after that my main
duties were that of winch driver undertaking about 50 launches per
weekend.In 50 years of gliding I have held or hold a CFS credited A2 Star
instructor category, a BGA Full Cat and Assistant Cat.I have been appointed
as the OC of awinch launched Air Cadet Gliding School, and CFI. I am
Currently DCFI at my club. I have over 10,000 launches the majority of
which are by winch. I have had no accident. I have released a glider at the
start of a winch launch on about 5 occasions after we started to move and
before we were airborne. I all cases my hand was on the release and was
because a wing was dropping. I all cases I was the instructor in the back
seat and I have no idea whether or not the wing drop would have been
recovered, I did not think it was prudent to wait to find out. I only
mention all this so that no one will be in any doubt that my next statement
is made with some knowledge gained by experience.
I have flown at many clubs and AC Gliding Schools and have observed
operations at many more. I can say that the winch operation at Portmoak,
The Scottish Gliding Centre is as efficient and safe as any I have seen,
and has always been so since I started visiting many years ago. Even the
launch round the pole was done in such a way as to be completely safe.
If anyone should know the primary cause of the cartwheel accidents I, and
many others would be glad to hear it. The wing drop is a symptom and the
actions of the wing runner do not appear to have any contribution to the
cause. In my opinion the most likely factors are aft fitted CoG hooks,
rapid acceleration, crosswind, too strong weak links, cable misalignment
and the pilot holding the aileron/rudder controls in any position other
than neutral or mishandling. I suspect that if only one factor is present
the result is not too serious but the presence of 2 or more factors is
likely to result in disaster but it does appear that no one really knows.
In those circumstances a very early release is the only action that will
mitigate the result and it is therefore sensible to be in a position to
release as quickly as possible. The events happen very quickly and even the
milliseconds or longer taken searching for the release can be too long. The
time saved by having your hand on the release can literally mean the
difference between life or death. As an aside on of the reasons for
removing the safe blind handle from ejector seats was to do away with the
time it took for a pilot to decide which handle to use. There is a time
penalty in deciding all actions, if you are holding the release at least
one decision/action is removed from the chain.
What concerns me is that some uninformed people have failed to grasp the
importance of holding the release (pun intended) and even worse have argued
against it. The danger is that people with less experience may not adopt
the procedure because of these irresponsible arguments and statements.
I flew an ASW 17 for several years and I did hold the flap lever on
aerotowing but I always had a paracord loop around my wrist and the release
knob. The use of air-brake to increase aileron effectiveness is unnecessary
on a flapped sailplane where negative flap, which has the same effect, is
available so the paracord loop would work for airbrakes as well.
Bottom line, holding the release from the moment the cable is attached,
whatever your method of tow is a sensible and safe practice. An inadvertent
release on the ground run is only likely to cause embarrassment and some
pushing and shoving, but at least you will be alive to do it.
  #80
Old October 11th 13, 09:40 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
cause.
It looks like aileron stall to me. I cannot have been the first to form this opinion, so I'm certain I'll now be told this cannot be the case for some very good reason.
Evan Ludeman / T8
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
