#71
![]() "atis118" wrote in message om... You're right..I stand corrected, I got mixed up with the fact that when a tower at a class "D" airport shuts down for the evening, the airspace reverts to class "E" with controlled airspace starting at 700' or 1200'. I started typing before thinking :-) A surface area requires: 1.) Communications. Communications capability with aircraft which normally operate within the surface area must exist down to the runway surface of the primary airport. This communications may be either direct from the ATC facility having jurisdiction over the surface area or by rapid relay through other communications facilities which are acceptable to that ATC facility. 2.) Weather Observations. Weather observations shall be taken at the surface area's primary airport during the times the surface area is designated. The weather observation can be taken by a Federally certificated weather observer and/or by a Federally commissioned weather observing system. If the tower is responsible for taking weather observations, then when the tower closes the airspace must become Class G. If the tower serves as the rapid communications relay for the ATC facility having jurisdiction over the surface area, then the airspace must again become Class G when the tower closes, even if weather observations are still taken by another entity, such as an AWOS or ASOS. If communications still exist and weather observations are still taken after the tower closes, then the airspace can become Class E or Class G. It will become Class E if necessary to accommodate instrument procedures if such action is justified and/or in the public interest. The following factors are among those that are considered: 1. Type of procedure including decision height or minimum descent altitude. 2. The actual use to be made of the procedure, including whether it is used by a certificated air carrier or an air taxi/commuter operator providing service to the general public. 3. The operational and economic advantage offered by the procedure, including the importance and interest to the commerce and welfare of the community derived by the procedure. 4. Any other factors considered appropriate. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
