SSA responds to ANPRM
Old August 19th 15, 06:20 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default SSA responds to ANPRM
On Wednesday, August 19, 2015 at 1:00:11 PM UTC-4, George Haeh wrote:
Here in Canada the air carriers are pretty
much on ADS-B already; so my PF sees
them. Aside from the odd towplane, my
PF has only alerted me to one
transponder target.
I can receive several ADS-B returns on a
single flight.
Hi George - the Dash-8's running Ottawa-Montreal over Gatineau and MSC aren't ADS-B equipped; neither are the Ontario provincial aeromedical evac helos that buzz through our MFA area. We see their transponders. Only the 3pm flights from Europe come in showing ADS-B. I expect we'll see more as 2020 approaches since most of the Dash-8's will also be going into NY and Boston.
We also see a lot of GA traffic over the Ottawa River...
  #72
Old August 19th 15, 10:23 PM posted to rec.aviation.soaring
George Haeh
transponder target.
single flight.
  #73
Old August 19th 15, 11:35 PM posted to rec.aviation.soaring
Darryl Ramm
On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote:
I have been slogging through the some
220 responses and came across a
response from the NTSB:
http://www.regulations.gov/contentStrea
mer?documentId=FAA-2015-2147-
0137&attachmentNumber=1&disposition
=attachment&contentType=pdf
"our main concern was to ensure that
gliders are detectable by an aircraft
equipped with a traffic alert and collision
avoidance system (TCAS)"
Gliders are already kept well away from
air carriers by Class B and C.
That is serious misunderstanding of how controlled airspace works.
Scheduled airline traffic for example flies in Class A, B, C, D and E airspace in the USA. Class E airspace in particular is a concern with gliders and airliners near some busy traffic areas. For example in the Reno Area you have Airliners fling approaches into Reno sharing airspace with glider traffic in the Carson Valley. It is interesting to look down from a glider and see multiple B737s on approach to Reno. That is why pilot education, voluntary carriage of transponders, established gliders procedures with ATC, etc. are so important there. And many owners/pilots, clubs, FBOs, organizations like PASCO have down great work to support that. And why when incidents like airliners getting anywhere near close to a glider gets a lot of attention. And while the Reno area may be the poster-child for airliner-glider saftey concerns in the USA that situation is far from limited to the Reno Area.
That makes the primary beneficiaries of
the ANPRM private jet owners able to
afford TCAS - $30K to $200K before
installation.
There are many valuable inputs that people can and should be making about this ANPRM and related concerns, from all possible points of view, but stating inflammatory opinions like this that are based on such obvious misunderstands is not likely to do anybody any good.
As long as they're transmitting ADS-B,
anybody with PowerFLARM knows
exactly where they are from several miles
away and can avoid.
PowerFLARM ADS-B In is a helpful feature, but when it comes to high-speed threats like fast jets and airliners (especially above 250 knots above 10,000') the usefulness may be more for educating PowerFLARM users about where that traffic generally is and to avoid that entire area if possible.. or to help convince those owners/pilots to get a transponder.. which has happened in a few cases I know. I'm not so convinced it's that useful for a glider pilot reliably avoiding ADS-B Out equipped high-speed jet or airliner that does not know the glider is there. For that it seems making the glider visible to TCAS in the high speed jet or airliner is much more useful approach.
  #74
Old August 20th 15, 03:29 AM posted to rec.aviation.soaring
George Haeh
transponder target.
single flight.
SSA's planned response to ANPRM Transponders, etc [email protected] Soaring 0 July 11th 15 05:01 AM
ANPRM - removal of transponder exception for gliders [email protected] Soaring 29 June 17th 15 11:00 PM
Sheriff Responds to AOPA Jp Stewart Soaring 27 January 29th 13 04:49 PM
USS Liberty Survivor Phil Tourney responds to Cindy McCain NOMOREWARS_FORISRAEL Naval Aviation 0 September 24th 11 11:22 AM
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
