#71
You are just plain wrong. The immediate effect of opening Schempp-Hirth
type airbrakes, if nothing else is done, is to make the wings bend more. Have you ever tried opening the airbrakes with a bendy wing and watched what actually happens? When I flew an ASW20L I always used some landing flap when approaching to land. Sometimes I would keep the brakes closed until near the ground. I always opened them as I rounded out, because as soon as I did this the wings bent up, to give me better ground clearance! I remember flying a Skylark 3 at about 75 knots (fast for the type), at this speed the tips bent down a bit, because of the washout. If I then opened the airbrakes, the wings bent up. Your theory is wrong, it does not work! Don't try to argue that I did not see what I know I did see, get in something with bendy wings such as a Pegasus, and try it. I also remember seeing an article in "Technical Soaring" with a photo of a Jantar 1 at Vne, and at 1 g., with the brakes fully out. The wing bend, at 1 g. remember, was horrendous. Don't try and give us some theoretical reason why this cannot happen, it does! You also say: "all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like "don't exceed VNE, but no problem if you exceed permitted G-loading" ". Who said that, which posting? This whole discussion has been around the point, if you look as if you are going to exceed Vne, what should you do? Exceeding Vne is outside limits and dangerous, so are any of the alternatives - the discussion is about which of the alternatives is the least worst. With the Minden accident on 13th July 1999, it is clear from the report that the glider was pitched down to well beyond a 45 degree dive, so the airbrakes would not have been speed limiting. You say "I never experienced a spin recovery", presumably you mean in a large span glider. I hope you have done plenty in training and short span machines. An essential part of stall/spin recovery training is to be able to distinguish at once the difference between a spin and a spiral dive. If you treat a spiral dive as if it is still a spin, this is very likely to lead to excessive speed, as well as using more height for the recovery. I still think that the advice I gave in my first posting to this thread is correct: "If you exceed Vne you are taking a risk, if you pull too hard above manoeuvring speed you are taking a risk, and if you pull hard and roll at the same time you are taking a risk. If you pull the brakes you are increasing the bending load on the wings. "If you get it wrong and have to take one of the risks, I am told that you should centralise the ailerons, then pull however hard is necessary not to exceed Vne, and make sure the brakes stay shut." Denis (Denis who and from where?), if you still feel like answering, please answer what I have actually written. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Denis" wrote in message ... W.J. (Bill) Dean (U.K.). wrote: There were postings to Rec. Aviation Soaring when the report was published, from pilots with experience of the Nimbus 4 and similar models who had experience of inadvertent deployment of the airbrakes. If the brakes deployed inadvertently while the pilots were recovering from the dive, this surely may have been the reason for the amount of bending seen; and for the overload which led to failure. Presumably those investigating the accident were not aware of these incidents when writing the report. If airbrakes deploy inadvertently, the first effect (along with the very high drag) will be a *decrease* in G-loading *and* bending moment), both due to the loss of lift near the airbrakes. The increase of bending would happen only after the angle of attack has been further increased (voluntarily or not) to restore the initial G-loading with more lift on the outer panels (instead of the airbrakes section), hence the higher bending. Denis, you are very scathing. That is not my intention... all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like "don't exceed VNE, but no problem if you exceed permitted G-loading". What do you think went wrong? What would you have done? Do you have any experience in the Nimbus 3 & 4 series? I don't. Are you more experienced or better than the pilots who did not make it? I don't know them and I would not pretend to be better (there are no good pilots, only old pilots...). And although I have some experience in Nimbus 4D (more on ASH 25) I never experienced a spin recovery and I hope I never will have to. Therefore I don't know what I would do in such a situation. All I can say is what I think (sitting comfortably in my chair) is the better thing to do, as I said in a previous post : "If your speed is going to exceed VNE within this manoeuvre [pulling up], you should stop or reduce pulling and apply full airbrakes. At any dive angle up to 45° this prevents the glider to exceeding VNE, and you have time to recover pulling gently (under 2 g's). This of course supposes that there is sufficient ground clearance... " Denis |
#72
At 18:54 29 March 2004, Denis wrote:
Pete Zeugma wrote: you pull as hard as you need, and its not impossible to know either, thats why you should practice spin recovery. AFAIK spin training is prohibited in most, if not all, open class ships... probably why we use k13's and puch's then and if you are going to examine spin characteristics of big floppy wings, you do it for spin entry and not any further. but then again, you shouldnt be flying at a speed where you are going to end up in a spin in the first place, let alone suddenly realising that you've let your speed build up to Vne! which is the whole point of spin training........ and presuming you have not blacked out by then also, i start to grey out at about 7g from more than 5 secs exposure at that level. you would probably have blacked out about 9g Yes, except grey out or black out happens only after a few seconds (the time needed for the blood to fall into your lower boby). er.. didnt i say that? 5 secs.... And it is very dependant of the condition and trainig of the pilot. and seating position, and how much height exposure he's had during the days flying........... (oxy saturation) but then a well trained pilot wouldnt have got himself into the position of entering a spin, let alone contemplating what to do because hes suddenly at all the airframe limits! But a glider wing breaks within milliseconds of overstressing ! no they dont, they have to fail progressivly. no glider would be alowed in the air by any regulating body if a wing could break in a 1000th of a second. i dont think you really understand the force that would be needed to do that. the instantanious g-load to do that would kill you out right. -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#73
You may be correct. However, I have heard of some cases where there have been structural failures
resulting from excessive g-forces, but the glider has remained landable after that. Aerobatics books also recommend to "pull as hard as necessary", but to keep an eye on your g-meter and ASI. High AoA eats energy rather fast. Flutter from overspeeding will definately disintegrate your wing. Excessive-g may not. The trick is to stay within the limits as long as possible. Therefore it's necessary to know the limits and their use. In abovementioned Nimbus 4 incident it seems that pilot exchausted g-limits before the Vne arrived. But no-one knows what really happened. BTW, there is one energy-burning device on every glider that may save you the very necessary second or two - the wheel. Lower it as soon as you feel the threat of overspeeding. You may lose the wheel doors because of the speed and g-forces, but this is not nearly as catastrophical as losing wing because of pulling the airbrakes at Vne and high-g. |
#74
You're both partially right. The moment you deploy the airbrakes and
maintain a constant angle of attack, you loose lift which means the glider accelerates it's sink rate. G load decreases, bending decreases. Once the sink rate is stabilized, the initial lift must have been restored but it's different distribution along the wing span increases the bending. BTW, Denis is fairly well know in France (an Morocco...) -- Bert Willing ASW20 "TW" "W.J. (Bill) Dean (U.K.)." a écrit dans le message de ... You are just plain wrong. The immediate effect of opening Schempp-Hirth type airbrakes, if nothing else is done, is to make the wings bend more. Have you ever tried opening the airbrakes with a bendy wing and watched what actually happens? When I flew an ASW20L I always used some landing flap when approaching to land. Sometimes I would keep the brakes closed until near the ground. I always opened them as I rounded out, because as soon as I did this the wings bent up, to give me better ground clearance! I remember flying a Skylark 3 at about 75 knots (fast for the type), at this speed the tips bent down a bit, because of the washout. If I then opened the airbrakes, the wings bent up. Your theory is wrong, it does not work! Don't try to argue that I did not see what I know I did see, get in something with bendy wings such as a Pegasus, and try it. I also remember seeing an article in "Technical Soaring" with a photo of a Jantar 1 at Vne, and at 1 g., with the brakes fully out. The wing bend, at 1 g. remember, was horrendous. Don't try and give us some theoretical reason why this cannot happen, it does! You also say: "all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like "don't exceed VNE, but no problem if you exceed permitted G-loading" ". Who said that, which posting? This whole discussion has been around the point, if you look as if you are going to exceed Vne, what should you do? Exceeding Vne is outside limits and dangerous, so are any of the alternatives - the discussion is about which of the alternatives is the least worst. With the Minden accident on 13th July 1999, it is clear from the report that the glider was pitched down to well beyond a 45 degree dive, so the airbrakes would not have been speed limiting. You say "I never experienced a spin recovery", presumably you mean in a large span glider. I hope you have done plenty in training and short span machines. An essential part of stall/spin recovery training is to be able to distinguish at once the difference between a spin and a spiral dive. If you treat a spiral dive as if it is still a spin, this is very likely to lead to excessive speed, as well as using more height for the recovery. I still think that the advice I gave in my first posting to this thread is correct: "If you exceed Vne you are taking a risk, if you pull too hard above manoeuvring speed you are taking a risk, and if you pull hard and roll at the same time you are taking a risk. If you pull the brakes you are increasing the bending load on the wings. "If you get it wrong and have to take one of the risks, I am told that you should centralise the ailerons, then pull however hard is necessary not to exceed Vne, and make sure the brakes stay shut." Denis (Denis who and from where?), if you still feel like answering, please answer what I have actually written. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Denis" wrote in message ... W.J. (Bill) Dean (U.K.). wrote: There were postings to Rec. Aviation Soaring when the report was published, from pilots with experience of the Nimbus 4 and similar models who had experience of inadvertent deployment of the airbrakes. If the brakes deployed inadvertently while the pilots were recovering from the dive, this surely may have been the reason for the amount of bending seen; and for the overload which led to failure. Presumably those investigating the accident were not aware of these incidents when writing the report. If airbrakes deploy inadvertently, the first effect (along with the very high drag) will be a *decrease* in G-loading *and* bending moment), both due to the loss of lift near the airbrakes. The increase of bending would happen only after the angle of attack has been further increased (voluntarily or not) to restore the initial G-loading with more lift on the outer panels (instead of the airbrakes section), hence the higher bending. Denis, you are very scathing. That is not my intention... all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like "don't exceed VNE, but no problem if you exceed permitted G-loading". What do you think went wrong? What would you have done? Do you have any experience in the Nimbus 3 & 4 series? I don't. Are you more experienced or better than the pilots who did not make it? I don't know them and I would not pretend to be better (there are no good pilots, only old pilots...). And although I have some experience in Nimbus 4D (more on ASH 25) I never experienced a spin recovery and I hope I never will have to. Therefore I don't know what I would do in such a situation. All I can say is what I think (sitting comfortably in my chair) is the better thing to do, as I said in a previous post : "If your speed is going to exceed VNE within this manoeuvre [pulling up], you should stop or reduce pulling and apply full airbrakes. At any dive angle up to 45° this prevents the glider to exceeding VNE, and you have time to recover pulling gently (under 2 g's). This of course supposes that there is sufficient ground clearance... " Denis |
#75
That's correct. If you kill the lift over part of the
wing by opening the spoilers, the rest of the wing needs to produce a higher coefficient of lift to keep the glider from accelerating downward. This can only happen through an increase in angle of attack. This will cause the wing to flex more because the center of lift has moved outboard (imagine lifting your glider on the ground by the wingtips versus the wing roots to appreciate the point). If you don't increase the angle of attack to compensate then liftweight and the glider will accelerate downward (accelerating sink rate). In this case the outer panels are producing no more lift (same aoa, same airspeed) and the inner portion of the wing is spoiled so net-net there is less lift, less bending moment and less flex in the wings. However, this is a transient state since we all naturally compensate for the loss of lifting surface by pulling back ever so slightly on the stick and loading up the tips - hence the extra flex. It's hard to notice the aoa shift in flight because you need a lower pitch attitude to maintain airspeed (due to higher drag) at the same time that aoa goes up to produce enough lift to hold the glider up. Remember pitch attitude and aoa are not the same. Try going from dive brakes closed and locked to fully open on landing rollout - AFTER you're sure you have the tailwheel down. In this case aoa should be held pretty constant. See what the wings do then. 9B At 07:54 30 March 2004, Bert Willing wrote: You're both partially right. The moment you deploy the airbrakes and maintain a constant angle of attack, you loose lift which means the glider accelerates it's sink rate. G load decreases, bending decreases. Once the sink rate is stabilized, the initial lift must have been restored but it's different distribution along the wing span increases the bending. BTW, Denis is fairly well know in France (an Morocco...) -- Bert Willing ASW20 'TW' 'W.J. (Bill) Dean (U.K.).' a écrit dans le message de ... You are just plain wrong. The immediate effect of opening Schempp-Hirth type airbrakes, if nothing else is done, is to make the wings bend more. Have you ever tried opening the airbrakes with a bendy wing and watched what actually happens? When I flew an ASW20L I always used some landing flap when approaching to land. Sometimes I would keep the brakes closed until near the ground. I always opened them as I rounded out, because as soon as I did this the wings bent up, to give me better ground clearance! I remember flying a Skylark 3 at about 75 knots (fast for the type), at this speed the tips bent down a bit, because of the washout. If I then opened the airbrakes, the wings bent up. Your theory is wrong, it does not work! Don't try to argue that I did not see what I know I did see, get in something with bendy wings such as a Pegasus, and try it. I also remember seeing an article in 'Technical Soaring' with a photo of a Jantar 1 at Vne, and at 1 g., with the brakes fully out. The wing bend, at 1 g. remember, was horrendous. Don't try and give us some theoretical reason why this cannot happen, it does! You also say: 'all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like 'don't exceed VNE, but no problem if you exceed permitted G-loading' '. Who said that, which posting? This whole discussion has been around the point, if you look as if you are going to exceed Vne, what should you do? Exceeding Vne is outside limits and dangerous, so are any of the alternatives - the discussion is about which of the alternatives is the least worst. With the Minden accident on 13th July 1999, it is clear from the report that the glider was pitched down to well beyond a 45 degree dive, so the airbrakes would not have been speed limiting. You say 'I never experienced a spin recovery', presumably you mean in a large span glider. I hope you have done plenty in training and short span machines. An essential part of stall/spin recovery training is to be able to distinguish at once the difference between a spin and a spiral dive. If you treat a spiral dive as if it is still a spin, this is very likely to lead to excessive speed, as well as using more height for the recovery. I still think that the advice I gave in my first posting to this thread is correct: 'If you exceed Vne you are taking a risk, if you pull too hard above manoeuvring speed you are taking a risk, and if you pull hard and roll at the same time you are taking a risk. If you pull the brakes you are increasing the bending load on the wings. 'If you get it wrong and have to take one of the risks, I am told that you should centralise the ailerons, then pull however hard is necessary not to exceed Vne, and make sure the brakes stay shut.' Denis (Denis who and from where?), if you still feel like answering, please answer what I have actually written. W.J. (Bill) Dean (U.K.). Remove 'ic' to reply. 'Denis' wrote in message ... W.J. (Bill) Dean (U.K.). wrote: There were postings to Rec. Aviation Soaring when the report was published, from pilots with experience of the Nimbus 4 and similar models who had experience of inadvertent deployment of the airbrakes. If the brakes deployed inadvertently while the pilots were recovering from the dive, this surely may have been the reason for the amount of bending seen; and for the overload which led to failure. Presumably those investigating the accident were not aware of these incidents when writing the report. If airbrakes deploy inadvertently, the first effect (along with the very high drag) will be a *decrease* in G-loading *and* bending moment), both due to the loss of lift near the airbrakes. The increase of bending would happen only after the angle of attack has been further increased (voluntarily or not) to restore the initial G-loading with more lift on the outer panels (instead of the airbrakes section), hence the higher bending. Denis, you are very scathing. That is not my intention... all I want is to give my opinion when I think something is said here that may lead to dangerous flying - such as sentences like 'don't exceed VNE, but no problem if you exceed permitted G-loading'. What do you think went wrong? What would you have done? Do you have any experience in the Nimbus 3 & 4 series? I don't. Are you more experienced or better than the pilots who did not make it? I don't know them and I would not pretend to be better (there are no good pilots, only old pilots...). And although I have some experience in Nimbus 4D (more on ASH 25) I never experienced a spin recovery and I hope I never will have to. Therefore I don't know what I would do in such a situation. All I can say is what I think (sitting comfortably in my chair) is the better thing to do, as I said in a previous post : 'If your speed is going to exceed VNE within this manoeuvre [pulling up], you should stop or reduce pulling and apply full airbrakes. At any dive angle up to 45° this prevents the glider to exceeding VNE, and you have time to recover pulling gently (under 2 g's). This of course supposes that there is sufficient ground clearance... ' Denis |
#76
When I made my original post on this subject my contention
was quite simple, if faced with the choice of exceeding VNE or pulling to avoid exceeding VNE and overstressing the glider I would choose the latter. I would hope that I would never get to the situation where I had to do either and if I keep my wits about me I never will. I stand by what I said but this was not an original thought, it was the advice of someone who knows a great deal more than me. An earlier posting said 'Also, I find it a bit strange that some here feel that it is possible to over-G a sailplane to damage, but not destruction. It seems like a fine point to me and there are several examples of unlucky souls who have misjudged the point'. Of course it is possible but I accept it is purely a matter of luck. I never made the above statement, I did say that overstress may cause serious damage, but flutter is much more likely to be catastrophic. With some gliders there is such a large margin between placarded limits and the forces the airframe will withstand that overstressing is definitely the lesser of 2 evils. The Grob Acro is a perfect example of this. One of the Acros delivered to the RAF in the UK in the 80's was given to Slingsbys to test on a rig. After the 'normal' testing (The wing spigot problem was discovered in this test and I was told that had this failed in flight the airframe would probably have stayed in one piece). Following this attempts were then made to break the glider but despite every effort the only thing that broke was the test rig, the glider never did. There is no such margin for the onset of flutter. Not all gliders have the strength of the Grob I would agreed but there is still a margin of some sort. The way the whole thing was explained to me was that pulling excess G may break the glider, in particular it may cause damage to the wing/fuselage fixing but this damage is not necessarily total (See above re wing spigot problem). The damage caused by flutter is much more likely to cause total failure not only of the wing but other aerodynamic surfaces as well (the tailplane and fin) and a glider without a tailplane/fin is not where I would want to be. I am told that the weakest point on any glider is the fuselage just in front of the fin. Again I am told that when an aircraft breaks up in flight the cause is almost invariably flutter, the result of overspeed, whether this is preceeded by overstress causing loss of control or not. There has been a lot of use of words such as rubbish and other derogatory terms. You do not have to agree with me but I would suggest that perhaps you might be better researching and then posting a cogent argument why I am wrong instead of just gainsaying. (Remember the Python :-) UK joke) I stand by my original post, faced with the choice of exceeding VNE or pulling too much G I would chose the latter as the lesser of two very great evils. |
#77
Don, I agree with you completely. You have made the points which I have
been trying to put. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Don Johnstone" wrote in message ... When I made my original post on this subject my contention was quite simple, if faced with the choice of exceeding VNE or pulling to avoid exceeding VNE and overstressing the glider I would choose the latter. I would hope that I would never get to the situation where I had to do either and if I keep my wits about me I never will. I stand by what I said but this was not an original thought, it was the advice of someone who knows a great deal more than me. An earlier posting said 'Also, I find it a bit strange that some here feel that it is possible to over-G a sailplane to damage, but not destruction. It seems like a fine point to me and there are several examples of unlucky souls who have misjudged the point'. Of course it is possible but I accept it is purely a matter of luck. I never made the above statement, I did say that overstress may cause serious damage, but flutter is much more likely to be catastrophic. With some gliders there is such a large margin between placarded limits and the forces the airframe will withstand that overstressing is definitely the lesser of 2 evils. The Grob Acro is a perfect example of this. One of the Acros delivered to the RAF in the UK in the 80's was given to Slingsbys to test on a rig. After the 'normal' testing (The wing spigot problem was discovered in this test and I was told that had this failed in flight the airframe would probably have stayed in one piece). Following this attempts were then made to break the glider but despite every effort the only thing that broke was the test rig, the glider never did. There is no such margin for the onset of flutter. Not all gliders have the strength of the Grob I would agreed but there is still a margin of some sort. The way the whole thing was explained to me was that pulling excess G may break the glider, in particular it may cause damage to the wing/fuselage fixing but this damage is not necessarily total (See above re wing spigot problem). The damage caused by flutter is much more likely to cause total failure not only of the wing but other aerodynamic surfaces as well (the tailplane and fin) and a glider without a tailplane/fin is not where I would want to be. I am told that the weakest point on any glider is the fuselage just in front of the fin. Again I am told that when an aircraft breaks up in flight the cause is almost invariably flutter, the result of overspeed, whether this is preceded by overstress causing loss of control or not. There has been a lot of use of words such as rubbish and other derogatory terms. You do not have to agree with me but I would suggest that perhaps you might be better researching and then posting a cogent argument why I am wrong instead of just gainsaying. (Remember the Python :-) UK joke). I stand by my original post, faced with the choice of exceeding VNE or pulling too much G I would chose the latter as the lesser of two very great evils. |
#78
Non-catastrophic may happen if you have a structure which has a plastic
behavious prior to rupture. Ironically, you don't have that with "plastic" gliders. You might well enconter that you can pull more g's because the designer has put lots of margins, and nothing will happen But if *something* happens, you're wings are simply gone on a GRP/CRP ship. The idea that you'll get away with some sort of damage and land the ship is, hm, fairly naive. But to the initial question: If you are going to exceed Vne in a dive, you can chose between putting your joker on a good spacing between Vne and flutter speed, or put your joker on a pessimistic design margin and a well crafted serial number. There is actually no way to tell the answer beforehand. But pulling the airbrakes would be fairly suicidal. -- Bert Willing ASW20 "TW" "W.J. (Bill) Dean (U.K.)." a écrit dans le message de ... Don, I agree with you completely. You have made the points which I have been trying to put. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Don Johnstone" wrote in message ... snip The way the whole thing was explained to me was that pulling excess G may break the glider, in particular it may cause damage to the wing/fuselage fixing but this damage is not necessarily total |
#79
iPilot wrote:
You may be correct. However, I have heard of some cases where there have been structural failures resulting from excessive g-forces, but the glider has remained landable after that. Aerobatics books also recommend to "pull as hard as necessary", but to keep an eye on your g-meter and ASI. Aerobatic aircraft are built to much higher G and Vne limits, and the pilots flying them are also accustomed to using high Gs. How many sailplane pilots have a G meter and will be looking at it in a spin recovery gone wrong? High AoA eats energy rather fast. Flutter from overspeeding will definately disintegrate your wing. It is this claim that we are discussing. I know of many people that have experienced flutter and not lost a wing. I also know flutter can have many different modes, including those that involve the rudder, elevator, ailerons, wing, and tail boom. It seems most dogmatic to claim "Flutter from overspeeding will definitely disintegrate your wing". Since you are so certain, perhaps you could tell us the reasons for your certainty? Excessive-g may not. Has flutter caused any of the in-flight breakups discussed here? Perhaps I missed them. I thought all were due to exceeding G limits, some likely due to the reduced G loadings with the spoilers extended. The trick is to stay within the limits as long as possible. Therefore it's necessary to know the limits and their use. In abovementioned Nimbus 4 incident it seems that pilot exchausted g-limits before the Vne arrived. But no-one knows what really happened. BTW, there is one energy-burning device on every glider that may save you the very necessary second or two - the wheel. Lower it as soon as you feel the threat of overspeeding. You may lose the wheel doors because of the speed and g-forces, but this is not nearly as catastrophical as losing wing because of pulling the airbrakes at Vne and high-g. Does anyone have an idea of how much effect this would have? If it is small, perhaps a pilot should not even think of attempting it as he struggles with a recovery near Vne. In many gliders, it requires the pilot to switch hands on the stick to lower the gear, and would be a distraction at critical time in all of them. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#80
Bert Willing wrote:
Non-catastrophic may happen if you have a structure which has a plastic behavious prior to rupture. Ironically, you don't have that with "plastic" gliders. You might well enconter that you can pull more g's because the designer has put lots of margins, and nothing will happen But if *something* happens, you're wings are simply gone on a GRP/CRP ship. The idea that you'll get away with some sort of damage and land the ship is, hm, fairly naive. But to the initial question: If you are going to exceed Vne in a dive, you can chose between putting your joker on a good spacing between Vne and flutter speed, or put your joker on a pessimistic design margin and a well crafted serial number. There is actually no way to tell the answer beforehand. I agree with Bert. To imagine Don's advice to be suitable for all gliders is too ignore the huge differences in design and materials. For example, the flexible, fiberglass wing of ASW 20 probably means it has a greater strength reserve because of the extra material needed to control flutter, while the stiffer carbon wing in the ASW 27 might give it the reverse margins. Consider the Standard Cirrus with it's relatively thick fiberglass wing: where are it's margins the greatest? And, it appears the 25 m gliders may have special problems. Until you have discussed the design of your _particular_ glider with it's designer, you are simply speculating about the dangers of overspeeding versus overloading. Even the designer may not know, if the glider hasn't been tested to flutter! And if you damage the structure during a high G pull-up, what do you suppose will happen to the speed at which flutter occurs? You may now have damaged glider experiencing flutter! Fortunately, this situation seems to rare. Personally, I have never encountered it in 4500 hours of soaring, not even an incipient spin. Here is more speculation: I think the reality is most pilots that have the problem will use Don's method out of reflex, not training or conscious choice. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 05:32 AM |
| Avoiding gliders | Stefan | Piloting | 16 | August 6th 03 06:44 AM |
