ADSB visibility with non certified GPS
Old October 1st 17, 06:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default ADSB visibility with non certified GPS
All off subject but around the year 2000, I flew a MD 500, mode C transponder, over the LA class bravo airspace. Listening to ATC there was some discussion about what I was and why I was there, one of the theories floated was is it a weather ballon, or hot air ballon. Come on, I was flying 110 knots indicated.
On Saturday, September 30, 2017 at 11:10:36 PM UTC-7, Andy Blackburn wrote:
FlightAware may be using the ICAO ID to look up aircraft type. I'm talking about the aircraft type embedded in the ADS-B transmission itself. It's also possible Stratux has some sort of glitch, but I was looking at the individual data packets and something wasn't right on some. I've heard similar reports from industry insiders - aircraft IDd as AC type "balloon". Go figure.
  #72
Old October 1st 17, 10:24 PM posted to rec.aviation.soaring
Ramy[_2_]
While we at it, will be good to know if we can connect any non TSO amplified GPS antenna to the TN72 and save an additional $300, and if anyone has a recommendation.
Ramy
  #73
Old October 2nd 17, 12:09 AM posted to rec.aviation.soaring
On Saturday, September 30, 2017 at 5:39:42 PM UTC-4, Darryl Ramm wrote:
I don't understand why you think existing PowerFLARM devices are related to UAT. The only ADS-B thing a PowerFLARM can do is receive 190ES In, and only that direct from the 1090ES Out aircraft. They come out of Europe were there is no UAT and are completely incompatible with UAT. If UAT never existed PowerFLARM would be *more* useful in the USA because you would see all ADS-B Out traffic. PowerFLARM does not transmit on UAT, can't see UAT, and can't receive ADS-R relay of UAT traffic (even if you have a suitable ADS-B Out system to cause your glider to become an ADS-R client).
- thanks Darryl. So I had the ADS-B frequency that PowerFLARM uses backwards. So is ADS-R one-way only, relaying 1090ES traffic to UAT and not the other way around? Doesn't that limit the usefulness of UAT for GA aircraft, if it does not make them directly visible to the heavies? Or is there some other reason why PF won't receive ADS-R? (This over-complicated system makes my head hurt.)
  #74
Old October 2nd 17, 02:02 AM posted to rec.aviation.soaring
Darryl Ramm
It might help to remember PowerFLARM does 1090ES In (ie. the 1090 MHz transponder reply frequency) because PowerFLARM also uses that same 1090 MHz receiver to provide PCAS detection. (UAT operates on 978 MHz).
ADS-R goes both ways. The ADS-B Out system in an aircraft has "CC" capability code flags that describe if the Aircraft has ADS-B In on UAT or 1090ES (and obviously if neither flag set then no ADS-B In). The FAA ADS-B Ground systems looks at that "client" aircraft and "target" aircraft nearby it (within 15 naut. mile radius +/- 3,500' "hockey puck") and transmits data from the ADS-B link layer it knows the client can't receive to the one it can. If the client has no or both link layers (as many the systems do now) it won't be an ADS-R client at all. A properly configured dual link layer receiver aircraft may still be a TIS-B client (if the target does not have ADS-B Out at all).
ADS-B In systems may not operate fully/as expected unless the ADS-B Out transmitter for that aircraft has the CC flags set correctly. This incorrect setup is especially likely with portable ADS-B In system. Luckily most portable and fixed (GA focused) ADS-B receivers are now dual-link which makes this less of an issue... but you might still not receive TIS-B. Make sure you understand how your setup in your specific aircraft will work.
The actual retransmission data message via ADS-R, is very slightly different than the message it is retransmitting... the FAA system could not work it it was exactly the same. PowerFLARM coming out of Europe was apparently never developed to handle those slightly different USA focused ADS-R messages..
Remember outside of gliders all UAT Out equipped aircraft that are expected to get near an airliner are also going to have a transponder. That transponder is going to always be seen by the airliners TCAS II system. The ultimate magic of a TCAS II RA (resolution advisory) where TCAS directs the pilot (and the pilot must follow) what to do, only ever happens via transponder interrogation. A TCAS II system will fly into a UAT only equipped target with no RA. Airliners may also have 1090ES In and Out and will be ADS-R clients, that can be used to paint traffic on displays etc. It does not drive a TCAS RA. The needs for transponders in areas of busy airliner and fast jet traffic for TCAS compatibility is a very important issue. That ASG29 vs. Hawker 800 middair... yep the Hawker 800 had full TCAS II, glider had its transponder (recently installed but not yet tested/signed off) turned off.....
  #75
Old October 2nd 17, 03:43 PM posted to rec.aviation.soaring
Dan Marotta
/snip/ yep the Hawker 800 had full TCAS II, glider had its transponder
(recently installed but not yet tested/signed off) turned off..../snip/
So...Â* Had the glider simply turned on the transponder, the collision
likely would not have happened?Â* Sounds a lot like being "dead right".Â*
What harm could have come from turning on the transponder before it was
signed off?
Dan, 5J
  #76
Old October 2nd 17, 03:51 PM posted to rec.aviation.soaring
signed off?
Dan, 5J
This is why the FAA has left gliders alone. They'd rather have no beepers in gliders than beepers that are not working properly or not all the time.
  #78
Old October 2nd 17, 05:17 PM posted to rec.aviation.soaring
Has anyone completed a fully compliant ADSB install in a glider that is willing to share who did it and the cost?
  #79
Old October 2nd 17, 05:26 PM posted to rec.aviation.soaring
Tango Eight
On Monday, October 2, 2017 at 12:16:22 PM UTC-4, Dan Marotta wrote:
Didn't answer the question.
What harm could have come from turning on a not-yet-approved transponder?
Violation of FAR 91.413.
best,
Evan Ludeman / T8
  #80
Old October 2nd 17, 05:50 PM posted to rec.aviation.soaring
Darryl Ramm
Andrzej Kobus has done at least one ADS-B out install in a glider and posted about it before on r.a.s. You can search for previous posts on that. Trig TT22 transponder and TN70 TSO-C145 GPS.
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 01:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 07:42 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
