Another E glider concept
Old August 16th 20, 06:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Another E glider concept
https://www.youtube.com/watch?v=ZIYU2zkGQFQ
Old August 17th 20, 12:11 AM posted to rec.aviation.soaring
Great cgi. What are the chines for, if the are for go fast, why don't mainstream gliders have them?
Old August 17th 20, 01:37 AM posted to rec.aviation.soaring
Marc Ramsey[_5_]
If you mean the fins on either side of the nose clearly marked "sensor", likely angle of attack vanes. Not very useful when the motor is running...
Old August 17th 20, 02:19 AM posted to rec.aviation.soaring
Not thinking about the sensor fin.
at 0:25 in the video. The horizontal line mid screen a few inches below the canopy. Looks like a transition between a flatish underbelly and vertical cockpit upper side. Looks like the chines under a boat?
Old August 17th 20, 03:53 AM posted to rec.aviation.soaring
2G
I wonder if they are also accepting deposits for this concept.
Old August 17th 20, 04:04 AM posted to rec.aviation.soaring
Marc Ramsey[_5_]
I see what you mean, the odd transition between the upper and lower fuselage profile that extends to the tail. Perhaps structural, or for style? I find it hard to believe it does much for the aerodynamics except produce a bit of drag.
Old August 17th 20, 12:40 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
motor is running...
Graphical artifact?
In the top view just from the right it looks as though it sticks out as
far as the sensor does and is blurred, while from the top left it only
seems to extend a cm or so and in other views it just looks like a
blurred line along the fuselage.
Martin | martin at
Gregorie | gregorie dot org
Old August 17th 20, 05:43 AM posted to rec.aviation.soaring
2G
On Sunday, August 16, 2020 at 8:19:10 PM UTC-7, Eric Greenwell wrote:
wrote on 8/16/2020 6:19 PM:
The lines extend along the tail boom, too. I can't think of any reason for them.
I do like the propeller concept. It allows 3 blades, giving it 50% more swept area
for the same diameter propeller as a two blade prop. That should enable them to
use a 50% more powerful motor than the two blade FES, or more ground clearance for
the same swept area. The reasons for the Vee tail are not obvious to me.
Concepts are really nice because you don't have to worry about any of those pesky engineering details.
Old August 17th 20, 02:14 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by Jonathan St. Cloud View Post
Interesting concept although on first look got to wonder if he was dreaming of an updated, stretched and powered 2 seat Salto that could fly him to fame and fortune (just kidding about the fortune)
:-) Colin
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
