On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in
:: -1G is nothing more than hanging in your belts during level inverted flight. Isn't also the maximum negative G limit of a C-150 operating in the Normal category? If so, the only reason it doesn't fail, is the safety margin in certification standard. |
"Larry Dighera" wrote in message ... On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in :: -1G is nothing more than hanging in your belts during level inverted flight. Isn't also the maximum negative G limit of a C-150 operating in the Normal category? If so, the only reason it doesn't fail, is the safety margin in certification standard. I doubt -1G is a limit. The 120/140 limit is -2.26 G plus a 150% safety margin. It is nearly impossible to get a Cessna to come apart in the air. |
On Mon, 02 May 2005 03:45:21 GMT, "Dave Stadt"
wrote in :: "Larry Dighera" wrote in message .. . On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in :: -1G is nothing more than hanging in your belts during level inverted flight. Isn't it also the maximum negative G limit of a C-150 operating in the Normal category? If so, the only reason it doesn't fail, is the safety margin in the certification standard. I doubt -1G is a limit. A quick perusal of the Airworthiness certificates shows a load factor of +4-4, -1.76 for non aerobatic C-150s and +6.0, -3.0 for Aerobats. http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/f9939cf761ddfa3f86256e2b0053faa3/$FILE/3a19.pdf The 120/140 limit is -2.26 G plus a 150% safety margin. That seems to exceed the C-150 specification. It is nearly impossible to get a Cessna to come apart in the air. Do you have some data to support that, or is that opinion empirically derived? :-) |
derived? :-) "empirical" means "by experiment" (data). As opposed to "by theory" (mathematics and modelling) Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
On Mon, 02 May 2005 12:56:55 GMT, Jose
wrote in :: Do you have some data to support that, or is that opinion empirically derived? :-) "empirical" means "by experiment" (data). As opposed to "by theory" (mathematics and modelling) While what you assert is true, given Merriam-Webster's definition: Main Entry:empirical Pronunciation:-i-k*l Variant:also empiric \-ik\ Function:adjective Date:1569 1 : originating in or based on observation or experience *empirical data* 2 : relying on experience or observation alone often without due regard for system and theory 3 : capable of being verified or disproved by observation or experiment *empirical laws* 4 : of or relating to empiricism –empirically \-i-k(*-)l*\ adverb I wonder why you felt the need to define the meaning of the word. What was your point? |
derived? :-) "empirical" means "by experiment" (data). As opposed to "by theory" (mathematics and modelling) ...given [webster's definition, consistant with my statement] I wonder why you felt the need to define the meaning of the word. What was your point? It was a UU. ("usenet urge"). The original quote seemed to misuse the word, pitting "empirical" against "having some data", when they mean the same thing. The usage I would expect would be something like "is there any theory behind this, or is that opinion empirically derived?" or "do you have some data to support that, or is this merely a theoretically based opinion?" Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
"Larry Dighera" wrote in message ... On Mon, 02 May 2005 03:45:21 GMT, "Dave Stadt" wrote in :: "Larry Dighera" wrote in message .. . On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in :: -1G is nothing more than hanging in your belts during level inverted flight. Isn't it also the maximum negative G limit of a C-150 operating in the Normal category? If so, the only reason it doesn't fail, is the safety margin in the certification standard. I doubt -1G is a limit. A quick perusal of the Airworthiness certificates shows a load factor of +4-4, -1.76 for non aerobatic C-150s and +6.0, -3.0 for Aerobats. http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/f9939cf761ddfa3f86256e2b0053faa3/$FILE/3a19.pdf The 120/140 limit is -2.26 G plus a 150% safety margin. That seems to exceed the C-150 specification. Yep, 2.26 is further from 0 than is 1.76. It is nearly impossible to get a Cessna to come apart in the air. Do you have some data to support that, or is that opinion empirically derived? :-) The NTSB has the data. Those attempting to win a Darwin award would do well to avoid Cessnas. |
Dave Stadt wrote: "Larry Dighera" wrote in message ... On Mon, 02 May 2005 03:45:21 GMT, "Dave Stadt" wrote in :: "Larry Dighera" wrote in message .. . On Sun, 01 May 2005 20:00:07 GMT, "Ed" wrote in :: -1G is nothing more than hanging in your belts during level inverted flight. Isn't it also the maximum negative G limit of a C-150 operating in the Normal category? If so, the only reason it doesn't fail, is the safety margin in the certification standard. I doubt -1G is a limit. A quick perusal of the Airworthiness certificates shows a load factor of +4-4, -1.76 for non aerobatic C-150s and +6.0, -3.0 for Aerobats. http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/f9939cf761ddfa3f86256e2b0053faa3/$FILE/3a19.pdf The 120/140 limit is -2.26 G plus a 150% safety margin. That seems to exceed the C-150 specification. Yep, 2.26 is further from 0 than is 1.76. It is nearly impossible to get a Cessna to come apart in the air. Do you have some data to support that, or is that opinion empirically derived? :-) The NTSB has the data. Those attempting to win a Darwin award would do well to avoid Cessnas. The older C150s are rated at +4.4 / -1.76 g and you'd be pushing to get anywhere over either number |
Oh I dunno, it's pretty easy to reach -2G in a poorly done slow roll. You let the nose drop a bit during knife edge flight, and then push a little too aggressively to keep the nose up as you come over into inverted, and you'll be pushing -2G easily. I've done it plenty of times in a Decathlon when I was rusty. You're probably right about the positive G's. Loops and other standard aerobatic maneuvers can normally be done at +3.5G easily, and the difference between 3.5 and 4.4 is more than most folks would think. The only time I normally exceed 4.5 in my Decathlon is when I hold a straight downline with full power and then then pull hard to level. But then all this presupposes that the pilot knows what he is doing. Sure, an experienced acro pilot could fly basic maneuvers in a C150 and not be at serious risk. But a novice who watched it on TV or got some hangar flying lessons could still easily kill himself trying it. He tries a slow roll, panics when the engine burbles while inverted, and tries to Split S out of it. Those wings are coming off. The older C150s are rated at +4.4 / -1.76 g and you'd be pushing to get anywhere over either number |
On 17 May 2005 09:12:43 -0700, "Robert M. Gary"
wrote in .com:: Ever see those things on T.V. when they put the fighter pilots in the G simulator by spinning them around in a circle. If you sat in the middle of that machine you would feel no G's (just like the cockpit of the airplane) but the guy out at the end of the arm (or wing tip) sure feels some G's. -Robert While the rolling aircraft was inverted, wouldn't any centrifugal force generated act against (rather than add to)any negative G forces the wing may feel? |
| Thread Tools | |
| Display Modes | |
| Rolling a Non Aerobat 150 | Jose | Piloting | 1 | May 2nd 05 04:59 PM |
| Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 1 | April 29th 05 08:31 PM |
| Rolling a Non Aerobat 150 | kage | Owning | 0 | April 29th 05 05:26 AM |
| Rolling a Non Aerobat 150 | Larry Dighera | Piloting | 4 | April 28th 05 06:06 PM |
| ??Build rolling tool chest? | Michael Horowitz | Owning | 15 | January 27th 05 05:56 AM |
