Class B busted...My problem or the controller's ?
Old May 29th 05, 08:48 AM
Peter Duniho
"Antoņio" wrote in message
Slow flight would have been good had there been time. I was abeam the
end of the runway when cleared to follow the Arrow. I was in B airspace
(so it seems) around 20 seconds later.
Where you aware, abeam the numbers, that you were approaching the Class B
airspace? If so, why not just slow down when abeam the numbers? It doesn't
take 20 seconds (or 30, which is what you wrote before) to slow an airplane
down, and of course as you are slowing, you get more time.
BFI has radar and is separating me from other traffic, right? That is
not technically "radar service"?
KBFI, as is the case at many Class D airports, has a radar display. In
almost all cases (and as far as I know, this includes KBFI), the tower
controller uses this strictly for informational purposes. They aren't
providing radar services, nor do they provide separation any more than any
tower without a radar display would (that is, they basically don't, even
though it may sound like they are sometimes).
Pete
  #72
Old May 29th 05, 08:50 AM
Peter Duniho
How could I have done that in this case?
You could ask the Class D controller to obtain a clearance for you, though
given how busy you say the airport was at that time, I doubt he would have.
You could have contacted the Class B approach controller yourself to obtain
the clearance.
The fact that neither of those methods would have been very practical at
that point in time is immaterial. They still remain the only options for
obtaining the required clearance.
However, the question is moot, since you did not need to enter the Class B
airspace, and thus did not need to obtain a clearance to do so.
Pete
  #73
Old May 29th 05, 11:05 AM
Happy Dog
ink.net...
"Jose" wrote in message
m...
It's not unreasonable. I've been told to turn off mode C, and if the
radio is causing interference (a stuck mike comes to mind) it's a
reasonable request.
If your mike is stuck you're not going to hear a request to turn off your
radio.
Mike, many planes have more than one radio these days.
moo
  #74
Old May 29th 05, 11:08 AM
Happy Dog
"Steven P. McNicoll" wrote in message \ "Jose"
m...
It doesn't block the other frequency.
It only broadcasts on one frequency.
Maybe your tower won't do that.
No tower will.
They often broadcast on ground and tower frequencies simultaneously.
moo
  #76
Old May 29th 05, 12:06 PM
Gary Drescher
Gary Drescher wrote:
I don't think there's anything in the FARs themselves that would let a
pilot
conclude that following ATC instructions is secondary to complying with
other FARs. That's not the way analogous situations work when driving a
car,
for example; there, police directives do take precedence over the traffic
laws that would otherwise hold (even though there are other, implicit
exceptions of the sort you mentioned; e.g. if you're instructed to stop
your
car ten feet above the pavement, you presumably can't be penalized for
failing to comply).
--Gary
Well said and exactly my dilema which, as yet, is unresolved.
Hm, I'm not sure why it's still unresolved.
Even though the AIM does not set forth regulations as such, it is
nonetheless an official document that the FAA expects pilots to be familiar
with as an advisory about best practices. AIM 4-4-1a says:
"An ATC clearance... IS NOT AN AUTHORIZATION FOR A PILOT TO DEVIATE FROM ANY
RULE, REGULATION, OR MINIMUM ALTITUDE." (capitalization in the original)
And AIM 4-4-1b says:
"If ATC issues a clearance that would cause a pilot to deviate from a rule
or regulation... IT IS THE PILOT'S RESPONSIBILITY TO REQUEST AN AMENDED
CLEARANCE." (capitalization in the original)
Admittedly, these passages only talk about clearances, not instructions more
generally. But it would make no sense for other instructions to override the
FARs if a clearance--which is an especially formal kind of instruction--does
not. (I'm not addressing emergency instructions here, since it goes without
saying that emergencies take precedence over everything.)
Although I'd be happier if the statement that the FARs override clearances
were in the FARs rather than just the AIM, it still strikes me that these
passages in the AIM resolve the question without ambiguity. Can you explain
why you think otherwise?
Gary
  #77
Old May 29th 05, 01:27 PM
A Lieberman
Antonio,
Sounds to me, you may need to assess your own flying. Based on your
statement above, sounds to me, that you were 20 seconds behind the airplane
rather then ahead of the plane.
FOR ME, by the time I am abeam the numbers, unless I am asked to keep my
speed up, I am at my final approach speed of 70 knots in my Sundowner.
This allows for a shorter final at this speed and I am taking a lot less
real estate in my pattern.
Allen
  #78
Old May 29th 05, 02:16 PM
Steven P. McNicoll
You were there?
I didn't have to be.
I was.
You didn't understand what was happening.
  #79
Old May 29th 05, 02:20 PM
Steven P. McNicoll
Not so Pete... The controller told me to "follow the Arrow" . To do so
*safely* (in my opinion) required I extend the downwind leg right into
class B.
But to do *safely* (in fact) probably didn't require you to extend the
downwind leg right into Class B airspace. Where were you on the downwind
when the instruction to follow the Arrow was issued and what were you
flying?
  #80
Old May 29th 05, 02:23 PM
Steven P. McNicoll
You mean flight into class B for landing at BFI is not *normally*
required. In this particular case I maintain it was for safe
separation.
You can maintain that if you like, but that doesn't make it so. All it does
is cause others to question your knowledge and abilities.
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Class III vs. Class II medical G. Sylvester Piloting 11 February 8th 05 06:41 PM
One Design viability? Stewart Kissel Soaring 41 December 10th 03 03:27 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Copyright Š2004-2025 AviationBanter.
