#71
When I'd had my Comanche less than a month, and hadn't yet figured out an
accurate fuel burn rate, I accidently ran a tank dry -- at night over Puget Sound. Switched tanks and hit the boost pump and it started immediately. Then I restarted my heart, turned east and landed at Skagit to fill up. Seth "Dylan Smith" wrote in message ... On 2005-08-19, Paul kgyy wrote: The ACS magazine this month mentions sometimes 2-3 minutes to restart a Comanche engine after running a tank dry. They don't recommend doing it... Not borne out by experience, though. A friend of mine would routinely run a tank dry in his Comanche - when he did it with me on board, the engine caught immediately when the tank was changed. It may as well have been a high wing Cessna single. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#72
Gets your attention over trees, rocks, or water, doesn't it?
Jim Then I restarted my heart, turned east and landed at Skagit to fill up. |
#73
Ayup.
Pretty religious about my reserves since then. I have two 30-gallon tanks. I switch tanks as soon as I reach cruise altitude -- usually about 20 min at full power, which I interpret as burning half an hour of fuel at 65% cruise. Then I switch each hour thereafter. In theory, this leaves me thirty minutes if I go dry. Seth "RST Engineering" wrote in message ... Gets your attention over trees, rocks, or water, doesn't it? Jim Then I restarted my heart, turned east and landed at Skagit to fill up. |
#74
Greg Copeland wrote:
In September 2004 issue of AOPA Flight Training, Mark Cook has an article, "No Fueln' Around". Under the "Selector boy" side article, he mentions that he runs some of his tanks dry in his Bellanca Viking. In at least one of John Deakin's articles (http://www.avweb.com/news/columns/182044-1.html), he not only recommends running tanks dry but puts forth a powerful argument that it's a responsible fuel management strategy. Furthermore, Deakin also offers that he has never found an NTSB accident report related to a failed engine start when running a tank dry and switching to the next. Both guys recommend setting a timer a couple of minutes before the tank should run dry; which acts of both early warning and as validation of your anticipated fuel consumption. Is this common? How many run their tank(s) dry as part of their fuel management strategy? If you don't run dry, why not? Aside from the heat beat skipping which is sure to follow the first couple of times, what's the down side to this strategy? Yes, as usual John Deakin is right on the money. Just ran the tanks dry today, in fact. I do a commute to work two to three times per week and have found that by carefully managing my fuel consumption, and by completely utilizing the aux tanks, I can avoid an extra stop for fuel every third trip. There is nothing I can think of relating to running a tank dry in cruise that would cause any difficulty or concern other than psychological. Go ahead and do it... the article you read gave you all the right data, and all the right reasons. |
#75
That is possibly the dumbest thing I've ever read in these newsgroups.
IMHO, proper fuel management means never even coming *close* to running a tank dry, let alone doing it intentionally. And now you expect us to call you names, too? Readthe other posts here, and you may learn that it is not as simple to judge as you make it. I'm sorry, was I calling someone a name? I thought he was quoting an article? I have read all the posts in this thread with great interest. Nothing said here has come close to explaining how the minimal utility you might get from running a tank dry could possibly overcome the very real danger that the engine might stop. My statement stands -- it's a dumb idea. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#76
They should stop being cheap *******s and just buy the damn fuel
computer. Then you know how much fuel is in each tank. You back woods pilots worry me. -Robert |
#77
I have a real airplane and as such, I could see if my caps developed a
leak in flight. ![]() And yes, ,my gauges can tell the difference between 30 minutes of fuel and none even in turb. Fuel gauges can be VERY accurate, you just need to spend the money to keep them in good repair. -Robert |
#78
So, you're ok over the Sierras without the motor running?
#79
I have run the tanks dry on both sides about three times each so I
know my gauges are accurate and can predict to within about 0.2 to 0.3 gallon useage when the engine will stumble. Not once did the engine quit. To be honest about the first time I was circling over an unused runway and for some unexplained reason the circles became tighter (smaller radius) as the tank got closer to zero. Obviously I had planty of altitude. Ron Lee |
#80
![]() "Robert M. Gary" wrote in message ups.com... I have a real airplane and as such, I could see if my caps developed a leak in flight. ![]() -Robert No way the sumps can leak, eh? ;-) |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Engine running again, the good, bad and ugly | Corky Scott | Home Built | 34 | July 6th 05 05:04 PM |
It's finally running! | Corky Scott | Home Built | 19 | April 29th 05 04:53 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
