ILS critical area when the tower is closed?
Old November 21st 05, 07:54 PM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
Steven P. McNicoll wrote:
wrote in message news:cjlgf.4216$pF.687@fed1read04...
Not so, Steve. It can cause control problems and certainly adversely
affect an autoland. That is why your handbook contains a caveat about
such approaches.
Approach couplers and autoland systems are weather independent.~
You're mistaken. There's no need for approach couplers and autoland systems
when the weather is good. It's not a problem because the pilots can see.
Well, okay, Steve. When I flew that equipment we often did autolands in
good weather as part of the continuing certification of the system for
CAT III operations. And, an air carrier flight could be going into a
non-towered airport using the ILS when the weather is "iffy" VFR.
The "need" to use couplers and perhaps autoland systems is determined by
the carrier and it POI.
  #73
Old November 21st 05, 08:13 PM posted to rec.aviation.ifr
wrote in message news:3Bpgf.4263$pF.2160@fed1read04...
good weather as part of the continuing certification of the system for CAT
III operations.
Fine, there's no problem with that.
And, an air carrier flight could be going into a non-towered airport using
We're not talking about "iffy" VFR, we're talking about good weather.
Well, their "need" to use couplers and perhaps autoland systems in good
weather does not give them priority over other users.
  #74
Old November 21st 05, 08:16 PM posted to rec.aviation.ifr
"Newps" wrote in message
The airlines will always fly the ILS if there is one up and running. They
are required to.
Do you suppose you could cite that requirement? I've known many an airline
flight to do a visual approach when there was a perfectly good ILS approach
available.
  #75
Old November 21st 05, 08:19 PM posted to rec.aviation.ifr
They are required to.
Is this a FAR requirement or airline's operational procedural requirement?
Peter
  #76
Old November 21st 05, 08:26 PM posted to rec.aviation.ifr
"Peter R." wrote in message
Neither.
  #77
Old November 21st 05, 08:33 PM posted to rec.aviation.ifr
Both. The FAA makes sure the airline puts it into their ops specs. If
there is an operating ILS to the runway that they are landing on they
have to use it. If a controller clears pretty much any jet with no
restrictions on the size of the pattern almost without fail they will
turn final at the outer marker.
  #78
Old November 21st 05, 08:35 PM posted to rec.aviation.ifr
there is an operating ILS to the runway that they are landing on they have
restrictions on the size of the pattern almost without fail they will turn
Please cite the applicable FAR.
  #80
Old November 21st 05, 11:21 PM posted to rec.aviation.ifr
On Mon, 21 Nov 2005 09:48:30 -0600, "Jim Macklin"
Limitations on the approach chart probably do not allow the
ILS when the tower is closed or more than one hour after the
last weather observation.
RW 29 at PWM has an ILS hold charted on the airport diagram, but I
don't see anything preventing it's use when the tower is closed on the
approach chart:
http://204.108.4.16/d-tpp/0511/00329IL29.PDF
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
