What do YOU want for Xmas?
Old December 18th 05, 02:47 AM posted to rec.aviation.piloting
Default What do YOU want for Xmas?
A day or two to measure the faceplate. That plus whatever mailing time.
Then I'd take my time to get to the faceplate.
John
  #72
Old December 18th 05, 02:12 PM posted to rec.aviation.piloting
Hmm, did you reinforce the cracked area with fiberglass fabric? It is
needed to provide structural strength.
No. We're talking about an area the size and thickness of two quarters, in
spots.
I might try laying in a few strands (if I ever try this again), just to see
if it helps. Maybe I'll try embedding a couple of reinforcing strands
taken from a piece of heavy duty packing tape...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #73
Old December 18th 05, 02:13 PM posted to rec.aviation.piloting
Wow, you must be an A&P!
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #74
Old December 19th 05, 01:09 AM posted to rec.aviation.piloting
spots.
Maybe this is the reason why the patched area cracked again. We put
a layer of fiberglass fabric soaked with ABS cement on all cracked area
big a small then either add more ABS cement or a small piece of thin
ABS on top depending on the size of the cracks. Both the fiberglass
cloth and ABS cement were quite cheap ($5 or less - we got the cloth at
automotive store and ABS cement at Lowe). Cracks tend to occur at
high stress areas (screw holes etc.). The fiberglass is quite
essential to prevent future cracks.
Hai Longworth
  #75
Old December 19th 05, 01:41 AM posted to rec.aviation.piloting
uh, make that take my time to MAKE the faceplate.
  #76
Old December 19th 05, 02:11 AM posted to rec.aviation.piloting
Try a hobby shop where they sell products for MODEL aircraft.
Fine , light weight fiberglass cloth,-- ask for fiberglass
tape for reinforcing wing center sections..
I use CA glue to layer the cloth in place after roughing the
surface...
Dave
On 18 Dec 2005 17:09:55 -0800, "Longworth"
spots.
Hai Longworth
  #77
Old December 19th 05, 03:55 AM posted to rec.aviation.piloting
Heck, here is a guy who manages to prove Godwin's law every time he
opens his mouth. I guess that makes Iran the automatic loser of any
international debate, eh?
  #78
Old December 19th 05, 02:42 PM posted to rec.aviation.piloting
Dave,
CA glue works but not as good as ABS cement. It appeared that
previous owner(s) had used CA glue to patch some ABS plastic cracks in
our plane. In some areas, the old CA glue cracked (probably due to
thermal expansion mismatch with ABS which eventually caused fatigue
cracking). Patching ABS plastic with ABS material eliminates this
problem. Areas with thick globs of CA glue did not crack but turned
brownish yellow and looked pretty ugly. If only a small amount is
needed, one can make ABS cement by dissolving small ABS shavings in
MEK. For bigger repair job, the premade ABS cement can is the way to
go.
  #79
Old December 19th 05, 02:57 PM posted to rec.aviation.piloting
Something that burns Jet-A !!!
One engine or two.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #80
Old December 19th 05, 10:16 PM posted to rec.aviation.piloting
Montblack wrote:
My brother got a cow in our name last year. Nice.
He did much research last year and this .org came up with fantastic
charitable/gift giving scores across the board - plus, he liked
organization.
http://www.heifer.org/
Cows, cows!!!! Here is a cow and it is an airport!
8D1, New Holstein, Wisconsin
Hey, isn't this airport near OSH? :-)
Montblack
.....no cattle my arse! :-)
Best regards,
Jer/ "Flight instruction/mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 235 Young Eagles!
