End of Season Sunset Warning for SSA-OLC Participants
Old September 2nd 06, 12:55 PM posted to rec.aviation.soaring
Doug Haluza
Default End of Season Sunset Warning for SSA-OLC Participants
This is cross posted from the SSA Home News & Information General
News:
As the days get shorter as the end of the soaring season nears, the
SSA-OLC Committee has been receiving complaints about flights after
sunset without required aircraft lighting. Although the requirements
for night flight begin at twilight for pilots in the US, the
requirements for aircraft lighting begin at sunset. Gliders without
approved lighting must land, and move clear of lighted runways and
taxiways before sunset.
IGC flight logs contain a GPS time stamp which is the most exact time
standard readily available. So, violations of this requirement are
quite plain to see in these logs. The SSA Board was concerned about
flight logs with obvious violations damaging the sport if they were
posted in the public record of the OLC. So the board adopted a policy
disqualifying such flights from the OLC, as well as FAI awards such as
badges and records. See:
http://www.ssa.org/download/SSA%20Po...Violations.pdf
The SSA-OLC Committee prefers that pilots voluntarily remove the
flights, rather than having them removed by an admin. We have contacted
a number of pilots to request this, and they are currently in various
stages of the 5-step grieving process (denial, anger, bargaining,
depression, and acceptance). You can avoid this emotional roller
coaster by planning and executing your flights to be complete before
sunset, unless you have approved night lighting.
You can't just duct tape a flashlight to the nose for night flight. The
requirements for navigation lights are very specific to color,
intensity and direction. If your aircraft is equipped with approved
night lighting, and it was used for flight after sunset, you must put a
note in the comments section of the OLC claim form explaining this.
We also have been advised of flight claims that show altitudes in the
log well above the 18,000' MSL limit for Class-A airspace in the US.
The IGC logger altitude is subject to a number of errors, which could
total to several hundred feet. We are currently reviewing with the
pilots a number of flights that appear to exceed even a reasonable
error budget.
Note that unless your flight reference altimeter has been properly
calibrated for IFR flight, and is set to a current ATC altimeter
setting, you will need to allow an extra buffer below 18,000' MSL
indicated altitude to account for possible errors. If you have an
encounter with an IFR aircraft with calibrated altitude references, the
calibrated references and ATC logs will be used to determine your
actual altitude in any subsequent investigation.
Again, if your flight log shows flight above 18,000 MSL, after
correcting for field elevation at takeoff, you will need to provide an
explanation in the comments section of the OLC claim form explaining
this. The same requirement applies to entering special use airspace.
This will immediately answer any questions that may concern other
competitors, or anyone else reviewing your flight log in the future.
Finally, if you note a flight that appears to be questionable, do not
speculate in public forums (like news://rec.avation.soaring). Contact
the pilot privately if you can. If the flight is in the US, contact the
SSA-OLC Committee by email at olcatssadotorg. Or use the complaint
tab on the OLC Web header to initiate a partner check.
Doug Haluza
SSA-OLC Admin
Old September 3rd 06, 03:33 AM posted to rec.aviation.soaring
5Z
night lighting,
So has anyone in the USA investigated options to add lighting to a
sailplane?
The new generation of super bright LEDs seem to be a perfect solution
for us. They could even be embedded in various parts of the wingtip or
winglet. A couple AA batteries installed at each light location would
probably last 20 or more hours, so no need to run wires. But since
current draw would be quite low, a fairly lightweight wire would be
suitable.
-Tom
Old September 4th 06, 07:06 PM posted to rec.aviation.soaring
Mike the Strike
"GC flight logs contain a GPS time stamp which is the most exact time
quite plain to see in these logs."
Unfortunately, sunset doesn't come with a GPS timestamp, so I'm afraid
this isn't as easy as you make it sound.
Yes, I know there are standard tables of sunset times, but these make
assumptions that may not be exactly correct and at a given location
actual sunset may differ from the calculated one by many minutes.
(Ask any local physicist./astronomer).
Of course, gross violations are pretty obvious, but I have operated
from a field where landing to the west is best done after the sun has
descended behind mountains, which usually occurs close to the time of
"official" sunset and is standard practice by those flying late.
Methinks all this scrutiny of flight logs is getting a bit too
intrusive and nit-picky.
Old September 5th 06, 04:25 AM posted to rec.aviation.soaring
Doug Haluza
Mike the Strike wrote:
"IGC flight logs contain a GPS time stamp which is the most exact time
The apparent movement of the sun in the sky is known very precisely (we
have been observing the sun for centuries). The only variable is the
refraction of the atmosphere, which changes the precise angle at which
the sun appears to pass below the local horizon. Various sunset
calculations use different refraction calculations, so they may differ
by a few minutes, but not "many minutes". The time of actual sunset may
also vary by a few minutes from the calculated value. The US Naval
Observatory has a sunrise/sunset calculator available online, and this
is probably the most reliable source for sunset times.
Unfortunately there is widespread ignorance of the sunset rule for
aircraft lighting, despite the fact that it has remained unchanged for
many years--longer than most pilots have been flying. So, we have seen
a few gross violations posted to OLC.
The point of all this is to get pilots to self-police, and not post
these flights in the first place. They should not be making flights
that continue after sunset witout lights anyway, but we certainly don't
want to see them on the OLC in any case.
P.S. The sun will appear to set below mountains before official sunset
when at an altitude lower than the mountains, becase the mountains will
appear to project above the local horizon.
P.P.S. Note that the sun will appear to set later than official sunset
when flying for the opposite reason--the local horizon appears to be
depressed. So you will need to enter the pattern to land well before
the sun appears to be setting in flight.
Old September 20th 06, 12:58 AM posted to rec.aviation.soaring
I am both of those and I assure you that the time of sunset is well-
defined and readily predicted for any location to a tiny fraction of
a second.
You may have difficulty observing the position of the sun. Like,
it might be cloudy, there might be a mountain in the way, or
you might be indoors. But that is not relevent.
Any regulatory requirement should (and I daresay will) be based
on that well-defined time, or the equally well-defined times of civil,
nautical, or astronomical twilight.
http://en.wikipedia.org/wiki/Astronomical_twilight
http://aa.usno.navy.mil/faq/docs/RST_defs.html#top
Obviously you may be safer flying a few minutes after sunset in
a clear sky than a few minutes before sunset in a cloudy sky.
But that is a practical consideration.
You are correct that these definitions are based on certain
assumptions, but the point is that a rule that says you are
supposed to be on the ground by sunset, the end of civil
twilight, or whatever, should be a rule that uses the defined
time, not some local observation. That gives you a clear,
unambiguous requirement.
FF
Old September 20th 06, 01:14 AM posted to rec.aviation.soaring
Doug Haluza
A minor clarification:
a second.
Well, not exactly to the second. Even the USNO only reports sunset time
to the nearest minute (see the "Accuracy of rise/set computations"
section in the link below). And their calculator only accepts Lat/Lon
to the nearest 1/10th of a dagree. So the error in the calculations are
+/- a minute or more. This is a technical point, but it is important to
remember that all measurements have some error.
You are correct that the time of actual sunset is moot, since nobody
regularly observes and records this. The only relevant time is the
official prediction. This prediction is normally in the pilot's favor,
since the sun sets earlier than predicted at high surface elevation and
high temperature due to recuced refraction in the less dense air.
FF
Old September 21st 06, 12:11 AM posted to rec.aviation.soaring
a second.
True it is not possible to predict when the sun would be
observed tangent below the horizon, with an accuracy of
better than a minute or so. But that's a silly way to define
sunset in the first place. If the atmospheric conditions
(e.g. clouds) made make the sun unobservable, you wouldn't
say there was no sunset that day. (Though the sun would
still be observable outside of the visible spectrum)
If the "time of sunset" is _defined_ based on nominal atmospheric
conditions that moots the issue, just like defining the horizon
to be 90.8333 degrees from zenith moots the issue of the local
topography.
Those conditions can be defined as accurately as one wants.
Similarly, uncertainty in your lattitute, longitude and elevation
may also be mooted. You may be uncertain as to where
YOU are, but the estimation of the time of sunset for an arbitrary
location (which therefor you can define with arbitrary accuracy)
is uncertain only due to the variablity in the motions of the earth,
uncertainty and variablility in the orbital parameters of the Earth,
and uncertainty and variability in the apparent size of the sun.
Actually, since Universal Time is _defined_ by the orientation
of the Earth and not by atomic time, the time of sunset is
only affected by variabilty in the motions of the Earth because
they affect the place on the horizon where the sun is tangent.
That is why we have leap seconds from time to time, to
keep international atomic time and universal time in agreement
(coordinated) to within one second, though there has been
debate about discontinuing that practice.
Those leap-seconds are pretty important in orbit determination,
which gets us back to something of potential interest to glider
pilots. A GPS satellite moves moves more than a mile in one
second.
FF
Old September 21st 06, 07:48 AM posted to rec.aviation.soaring
Mike the Strike
Fred:
You should really check your facts before posting twaddle!
Clearly I should have said to ask any physicist or astronomer who is
conversant with atmospheric refraction, which you clearly are not.
Because of variations in refraction, sunset (the time when the limb of
the sun becomes invisible to an observer) may vary by several minutes
from that calculated by the accepted formula. This formula assumes a
constant refraction that is unlikely to be exact for any specific place
or time.
(also a physicist and astronomer - and who knows a sunset when I see
one!)
a second.
FF
Old September 21st 06, 10:11 AM posted to rec.aviation.soaring
Doug Haluza
Fred:
or time.
This is like the advice from the old joke about the guys who get lost
in a balloon, then ask someone on the ground where they are, and the
person on the ground tells them they are up in the air in a balloon.
The joke is that the person on the ground must be a lawyer, beacuse his
answer was technicaly correct, but totally useless.
Same goes for actual sunset. Unless you are on a ship at sea, you won't
have a clear level horizon to observe actual sunset. So the refraction
issue is moot. And if you wait until you observe actual sunset in
flight, the sun will have already set on the ground.
The predicted sunset time is the only thing relevant for flight
planning.
Old September 21st 06, 03:55 PM posted to rec.aviation.soaring
Fred:
or time.
The issue is not atmospheric refraction.
The issue is not the definition of sunset.
The issue is the defintion of _time_ of sunset.
If the "time of sunset' is defined by a mathematical model,
then the time of sunset is independent of the actual atmospheric
conditions and therefor does not vary with them.
That was my point, and I am sorry that I was unclear.
The issue at hand was what time should be used to determine
if a pilot has landed befor sunset. OP's complaint was that
'time of sunset' was highly uncertain. My point is that it is
only highly uncertain if you use an entirely impractical
definiton of 'time of sunset'.
As an astronomer who knows a sunset when he sees one,
how do you know the sun has set when the sky is overcast?
FF
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 06:18 AM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 09:11 PM
