what exactly constitutes a troll?
Old October 6th 06, 11:47 AM posted to rec.aviation.piloting
mike regish
Default what exactly constitutes a troll?
But temperature *is* a measure of energy.
mike
"T o d d P a t t i s t" wrote in message
"mike regish" wrote:
Think the stresses on the metal tank might have anything to do with it?
No.
I also like Grumman's explanation above, but just speculating...
Read my enthalpy/entropy response to Grumman. He's confused
conservation of energy with conservation of temperature.
Rule books are paper - they will not cushion a sudden meeting of stone and
metal.
- Ernest K. Gann, 'Fate is the Hunter.'
  #72
Old October 6th 06, 10:03 PM posted to rec.aviation.piloting
Matt Whiting
It is a partial measure of energy. It doesn't measure potential energy.
Matt
  #73
Old October 6th 06, 11:03 PM posted to rec.aviation.piloting
mike regish
This thing has me curious. I just found this little tidbit. See what you
think.
It comes from the work done compressing the gas in the cylinder.
The Temperature changes in response to compression due to addition of
more molecules of air to the closed, fixed-volume cylinder. Work is
produced. Temperature rises.
The temperature must change by following Ideal Gas Law:
P V = N k T
Where P = pressure, V = volume, N = number of gas molecules, k = is
Boltzman's constant and T is Kelvin.
The equation must balance. Pick any system of gasses at a specific
pressure, temperature and volume. Change any of those four conditions,
the others must change proportionately.
See also, http://scienceworld.wolfram.com/phys...ealGasLaw.html
mike
"Matt Whiting" wrote in message
Matt
  #74
Old October 6th 06, 11:15 PM posted to rec.aviation.piloting
mike regish
What other form of energy are we talking about here?
mike
mike
What's your point? Conservation of energy does not require
conservation of temperature. That's illustrated by the fact
that reversible expansion of all the gas causes all the gas
to cool. Temperature changed for the gas, but energy was
conserved.
metal.
  #75
Old October 7th 06, 12:20 AM posted to rec.aviation.piloting
Matt Whiting
think.
P V = N k T
mike
Matt
Yes, so what is your point with respect to temperature as a measure of
energy?
Matt
  #76
Old October 7th 06, 01:33 AM posted to rec.aviation.piloting
mike regish
Not a thing.
mike
energy?
Matt
  #77
Old October 7th 06, 03:38 AM posted to rec.aviation.piloting
Matt Whiting
mike regish wrote:
Not a thing.
mike
energy?
Matt
OK, I was trying to figure out the connection and didn't see one. :-)
Matt
  #78
Old October 7th 06, 11:58 AM posted to rec.aviation.piloting
mike regish
My point was that I don't understand where the confusion is as to where the
heat comes from in filling a scuba tank. You are cramming a whole crapload
of molecules into a confined space and it makes heat. If you cram those
molecules into that space quickly (with respect to how fast you can
dissipate that heat) you get a VERY hot tank. This formula just explains it
better to me, though it doesn't seem to satisfy some as an explanation. It's
the same as a deisel engine except that rather than increasing the number of
molecules of air, the deisel decreases the volume of a fixed number of
molecules. It does it rapidly, so there's no time to dissipate the generated
heat through the cylinder walls, and the air heats up enough to ignite the
fuel when it's added by the injector. If you filled up the scuba tank very
slowly, giving it time to give up its heat to the surroundings (they're
filled in a water tank, no?), then it would not get so hot. I'm guessing
that they are filled from a pressurized tank. That TANK will get cold due to
the decreasing number of molecules in it as the scuba tank fills.
I guess I just don't get where all the confusion comes from. What do scuba
tanks get filled to? Something like 2 or 3 THOUSAND psi, no?
mike
mike regish wrote:
Not a thing.
mike
energy?
Matt
Matt
  #79
Old October 7th 06, 02:04 PM posted to rec.aviation.piloting
Jose[_1_]
Yes, but you are cramming a whole crapload of =cold= molecules into that
space. The heat generated seems like it wouldn't be enough to
compensate for the cold of the inflowing gas.
That gas is cold because it expanded from the other tank, which was
under even higher pressure.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
  #80
Old October 7th 06, 02:59 PM posted to rec.aviation.piloting
Morgans[_2_]
"Jose" wrote in message
et...
heat comes from in filling a scuba tank. You are cramming a whole crapload of
space. The heat generated seems like it wouldn't be enough to compensate for
That gas is cold because it expanded from the other tank, which was under even
higher pressure.
The gas in the tank that is expanding has all of the cold being produced, shared
among all of the gas in the tank, not just the gas that is leaving the tank.
If the cold was contained in, and limited to just the molecules that were
leaving, then the tank being compressed might not get hot. That is not
happening though, and much of the cold is left behind in the now, very cold
tank.
PLEASE DON'T FEED THE TROLL Darkwing Piloting 2 March 16th 06 03:46 AM
Troll of the year award Skylune Piloting 78 October 7th 05 08:10 PM
Art...Best Troll Ever? [email protected] Military Aviation 7 September 8th 04 11:55 PM
