Sometimes some people get spooked when driving out in the middle of
nowhere (especially the desert southwest of the USA) for various reasons. Obviously darkness, isolation, and a lack of signs of civilization and humanity can play a role in getting one's mind to wander in the wrong directions. These must all be greatly magnified when flying alone at night in relatively unpopulated regions. Have any of you ever been slightly spooked while flying alone? (And are you prepared to admit to it?) They say the area around Groom Lake in Nevada is particularly prone to do this. I recall someone else mentioning being out in the desert and the only noise was the eerie sound of power windmills that went on for miles, and after a while that got to him. I recall being on a hill once (on a cycle, not in the air) and accidentally thinking about stories of alien abductions, and reflecting on the fact that I was in exactly the situation that most abductees described when the little green men came to call. That was a mistake, but I did make unusually good time getting back into town. A related question is whether or not you've ever seen anything in the sky while flying alone at night that truly did not match any type of airborne craft you could think of. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Think about what you see or think you see while working in a contro tower at
night Al "Mxsmanic" wrote in message ... Sometimes some people get spooked when driving out in the middle of nowhere (especially the desert southwest of the USA) for various reasons. Obviously darkness, isolation, and a lack of signs of civilization and humanity can play a role in getting one's mind to wander in the wrong directions. These must all be greatly magnified when flying alone at night in relatively unpopulated regions. |
On Sun, 28 Jan 2007 23:40:53 -0500, "Allan9"
wrote: Think about what you see or think you see while working in a contro tower at night Visions of a nice soft, warm bed. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Allan9 writes:
Think about what you see or think you see while working in a contro tower at night I had not considered that. I suppose if one is working the tower alone at night, and there's no traffic, and one is in an isolated area, one might get a bit spooked at times, especially if things other than recognizable aircraft appear in the sky. But at least you can readily leave the tower if necessary (although I guess the tractor beam of the Borg could still sweep across the parking lot and snatch you up). In an aircraft, you can't just open the door and get out while in flight, so if you get a chill down your spine or a bright green light starts scanning the cockpit, you're stuck. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Allan9 writes: Think about what you see or think you see while working in a contro tower at night I had not considered that. I suppose if one is working the tower alone at night, and there's no traffic, and one is in an isolated area, one might get a bit spooked at times, especially if things other than recognizable aircraft appear in the sky. But at least you can readily leave the tower if necessary (although I guess the tractor beam of the Borg could still sweep across the parking lot and snatch you up). In an aircraft, you can't just open the door and get out while in flight, so if you get a chill down your spine or a bright green light starts scanning the cockpit, you're stuck. If that bright green light starts scanning your cockpit, DON'T LOOK AT IT! It is probably a green laser, with which there have been several illuminations of aircraft, with temporary to permanent eye damage. The son of a friend of mine had it happen, although his eye damage appears to be temporary. The crew in the plane behind him nmay have permanent damage, however. |
Orval Fairbairn writes:
If that bright green light starts scanning your cockpit, DON'T LOOK AT IT! It is probably a green laser, with which there have been several illuminations of aircraft, with temporary to permanent eye damage. Unfortunately, laser beams are so thin that you might not notice it before it hits you. Were they really green lasers? Did anyone ever find out who was using them? The son of a friend of mine had it happen, although his eye damage appears to be temporary. The crew in the plane behind him nmay have permanent damage, however. What was the situation? I recall a rash of these attacks (because attacks is what they are) some time ago, and then it seemed to quiet down. Unfortunately, I can't think of any simple way to protect against laser attacks. Throwing anyone who does one into a Supermax might serve as a deterrent, though. -- Transpose mxsmanic and gmail to reach me by e-mail. |
MX offered the opinon that
"Unfortunately, laser beams are so thin that you might not notice it before it hits you." There are a couple of problems with that statement. 1 if the beam is that thin it would take exquisite marksmanship to hit someone's eye, and 2 - visibility of a green laser beam is very high and it will bloom big time on the windscreen, for example. I know of no windscreen that's of a sufficient optical quality so as to not have that happen. Off axis scattering in atmospheric transmissions is a serious problem for high power lasers. There would probably be an instinctive glance towards the source of that pretty green light at night. Infra red lasers would be a different sort of problem. There was some stuff going on, maybe in Nevada, where very high powered lasers were being used to perhaps target the moon, and there were temporary restrictions on that airspace. (1970s or early 80s). These were big power hungry lasers though, not the sort of thing that are easily available for bad guys. |
On Jan 28, 11:34 am, Mxsmanic wrote: Have any of you ever been slightly spooked while flying alone? (And are you prepared to admit to it?) Spooked? Yes, but not in the way you mean. When the engine pulls the usual "You're in the middle of nowhere, so I'm going to burp once or twice just to get your attention", then yes I've asked ATC for higher just in case :-) When I was much younger and drove long lonely distances at night, I used to sometimes get that creepy feeling that there was someone (thing?) in the back seat. I can't imagine how bad that feeling would be in an aircraft Fortunately, planes don't do that to me.Kev |
Kev writes:
When I was much younger and drove long lonely distances at night, I used to sometimes get that creepy feeling that there was someone (thing?) in the back seat. I can't imagine how bad that feeling would be in an aircraft Fortunately, planes don't do that to me.Of course, now you'll have that to think about on your next flight. Don't pick up any hitchhikers. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On 29 Jan 2007 19:51:11 -0800, "Kev" wrote:
On Jan 28, 11:34 am, Mxsmanic wrote: Have any of you ever been slightly spooked while flying alone? (And are you prepared to admit to it?) Ive spent many hours flying alone and in the dark, both VFR and IFR. I've never felt spooked. Rather it's quite peaceful and can be very picturesque. Other times there is nothing to see at all and you have to turn the stobes off to prevent "flicker vertigo". When the only thing you see with each flash is featureless white it can be very disorienting. Spooked? Yes, but not in the way you mean. When the engine pulls the usual "You're in the middle of nowhere, so I'm going to burp once or twice just to get your attention", then yes I've asked ATC for higher just in case :-) When I was much younger and drove long lonely distances at night, I When I was much younger I burnt the candle at both ends so much I needed something to keep me awake while driving. used to sometimes get that creepy feeling that there was someone (thing?) in the back seat. I can't imagine how bad that feeling would be in an aircraft Fortunately, planes don't do that to me.Kev Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| Thread Tools | |
| Display Modes | |
| Legality of a flight | John | Piloting | 14 | May 31st 06 01:22 AM |
| fuel subsidies for Angle Flight pilots | sashley | Piloting | 17 | September 11th 05 10:25 AM |
| Radio outage at ZLA grounds flights | A Guy Called Tyketto | Piloting | 0 | September 15th 04 06:56 AM |
| FAA to End part 91 Sightseeing flights? | Vaughn | Rotorcraft | 7 | November 2nd 03 02:20 AM |
| Ownership and passengers | Roger Long | Owning | 30 | October 11th 03 03:00 PM |
