Altimeter Calibration Height
Old April 3rd 07, 04:50 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Altimeter Calibration Height
"Maxwell" wrote in message
Maybe I'm missing something here, but would it simplify to say:
That if you mount an altimeter at the 100' level of a 200' tower,
equiped it with a static tube 100' long,
that the altimeter will read the same regardless if end of the tube,
is stationed at the top or bottom of the tower.
Why didn't I think of that?
  #72
Old April 3rd 07, 04:55 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Neil Gould" wrote in message
et...
I think the issue is with your use of the term "indicates altitude", which
should be "senses pressure".
It's not an issue with me. Altimeters indicate altitude by sensing
pressure.
The altimeter "indicates" via the display
(dial or digital), and the display is adjustable both during
installation/calibration and by the pilot to adjust for atmospheric
pressure. Consider that when you tell a pilot that the "altimeter is
30.12", the pilot adjusts the _indicated altitude_ by setting the Kollsman
window to that _pressure setting_.
When you tell a pilot "altimeter 3012" the pilot simply adjusts the Kollsman
setting to 3012.
We don't watch the Kollsman (the only
"indication" of "altitude" consistent with the controller's information)
when trying to land. ;-)
Correct.
  #73
Old April 3rd 07, 06:42 PM posted to rec.aviation.piloting
Neil Gould
Recently, Steven P. McNicoll posted:
et...
which should be "senses pressure".
pressure.
Correct, however the "indication" (display) is not the *method* (sensing
pressure). So, your assertion: "In other words, an altimeter indicates
altitude at the level of the instrument itself." is only valid under a few
specific circumstances.
[...] Consider that when you tell a pilot that the "altimeter is
Kollsman window to that _pressure setting_.
Kollsman setting to 3012.
Do you see a difference between my statement and yours, other than the
decimal point?
Neil
  #74
Old April 3rd 07, 07:08 PM posted to rec.aviation.piloting
Maxwell
"Jose" wrote in message
That is a mostly true statement. Conditions inside the tube could differ
from ambient conditions, this would engender a teeny (but real) difference
in readings.
Jose
You mean like pressure loss of the long length or something?
  #75
Old April 3rd 07, 07:14 PM posted to rec.aviation.piloting
Steven P. McNicoll
t...
pressure).
Who said it was?
What would those few specific circumstances be?
decimal point?
Yes. You say the pilot adjusts the indicated altitude, I say he adjusts the
altimeter setting.
  #76
Old April 3rd 07, 07:37 PM posted to rec.aviation.piloting
Jose
pressure.
Yes, but there's a very important step in between, and that step is the
one that answers the original question.
Jose
Get high on gasoline: fly an airplane.
  #77
Old April 3rd 07, 10:13 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Matt Whiting" wrote in message
Show me one that indicates in units of "altitude at the level of the
instrument."
http://www.auf.asn.au/groundschool/altimeter1.jpg
Try again. It is adjustable so I can make it read any altitude I like.
Is that a good way to avoid busting Class Bravo?
Geoff
  #78
Old April 3rd 07, 10:14 PM posted to rec.aviation.piloting
Neil Gould
t...
(sensing pressure).
Who said it was?
You do when you imply that there is a necessary agreement between what the
altimeter senses and what it displays.
a few specific circumstances.
Jose listed them in response to an earlier post of yours.
the decimal point?
adjusts the altimeter setting.
You actually said, "When you tell a pilot "altimeter 3012" the pilot
simply adjusts the *Kollsman
setting* to 3012." (emphasis mine). As we described the same action, this
distinction is without a functional difference.
Neil
  #79
Old April 4th 07, 12:20 AM posted to rec.aviation.piloting
Matt Whiting
Jose wrote:
An altimeter senses pressure in order to indicate altitude.
Now we're getting somewhere. The pressure is sensed based on the laws
of physics. The altitude is indicated based on calibration and Kollsman
setting.
Right and the altitude indicated has little to do with the altitude of
the instrument.
Matt
  #80
Old April 4th 07, 12:22 AM posted to rec.aviation.piloting
Matt Whiting
t...
Now we're getting somewhere. The pressure is sensed based on the laws of
setting.
Yes, that is correct. There might be a slight transient as you moved
the tube, but at steady state the location of the tube would not matter.
Matt
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
