#71
On 2007-05-17 14:59:44 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at
wow way d0t com said: "Cubdriver" usenet AT danford DOT net wrote in message ... On Wed, 16 May 2007 22:00:14 -0700, C J Campbell wrote: People will say it is technically impossible, but I think it is wishful thinking. An engine may not run backwards very well, During World War II (really!) I worked on a farm in Concord, Mass. There was a great steel-wheeled tractor that was started with a hand crank. One time the tractor backfired while the lad was spinning the crank, and the engine started running backwards. He jumped aboard and had a great time wheeling it around the yard, one speed forward and three in reverse. Blue skies! -- Dan Ford That was a Diesel engine, correct? My great uncle Ern was nearly killed by a Model T Ford that he cranked up and the engine backfired and ran backward. 'Course, that guy was nearly killed so many times... -- Waddling Eagle World Famous Flight Instructor |
#72
Cubdriver usenet AT danford DOT net wrote: On Wed, 16 May 2007 21:39:54 -0700, Don Tuite wrote: Now you holler "Hot!, Brakes!" (assuming somebody's in the cockpit -- otherwise you switch the mags to hot and check the chocks and tiedown. With me, it's BRAKES! CRACKED! (referring to the throttle), HOT! Reach up, pads of your fingers just over the top of the blade. Left leg on ground, right leg swings forward and smartly back at the same time that you snap the blade down. The leg swing propels your body backward, away from the propeller arc. Huh. With me it's the left leg that swings. Then the right leg turns me farther back and to the left, out of the propeller arc. Blue skies! -- Dan Ford I was taught: SWITCH OFF! BRAKES! (Propping guy pushes plane to verify) THROTTLE CRACKED! CONTACT! (so as not to confuse with switch on) Now the propping begins. |
#73
![]() "C J Campbell" wrote in message news:2007051720300843658-christophercampbell@hotmailcom... On 2007-05-17 14:59:44 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com said: "Cubdriver" usenet AT danford DOT net wrote in message ... On Wed, 16 May 2007 22:00:14 -0700, C J Campbell wrote: People will say it is technically impossible, but I think it is wishful thinking. An engine may not run backwards very well, During World War II (really!) I worked on a farm in Concord, Mass. There was a great steel-wheeled tractor that was started with a hand crank. One time the tractor backfired while the lad was spinning the crank, and the engine started running backwards. He jumped aboard and had a great time wheeling it around the yard, one speed forward and three in reverse. Blue skies! -- Dan Ford That was a Diesel engine, correct? My great uncle Ern was nearly killed by a Model T Ford that he cranked up and the engine backfired and ran backward. 'Course, that guy was nearly killed so many times... -- Waddling Eagle World Famous Flight Instructor A Model T will not run backwards. Even if it did run backwards it would in no way would put your life in danger. |
#74
On 2007-05-17 21:00:36 -0700, "Dave Stadt" said:
"C J Campbell" wrote in message news:2007051720300843658-christophercampbell@hotmailcom... On 2007-05-17 14:59:44 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com said: "Cubdriver" usenet AT danford DOT net wrote in message ... On Wed, 16 May 2007 22:00:14 -0700, C J Campbell wrote: People will say it is technically impossible, but I think it is wishful thinking. An engine may not run backwards very well, During World War II (really!) I worked on a farm in Concord, Mass. There was a great steel-wheeled tractor that was started with a hand crank. One time the tractor backfired while the lad was spinning the crank, and the engine started running backwards. He jumped aboard and had a great time wheeling it around the yard, one speed forward and three in reverse. Blue skies! -- Dan Ford That was a Diesel engine, correct? My great uncle Ern was nearly killed by a Model T Ford that he cranked up and the engine backfired and ran backward. 'Course, that guy was nearly killed so many times... -- Waddling Eagle World Famous Flight Instructor A Model T will not run backwards. Even if it did run backwards it would in no way would put your life in danger. The Model T was notorious for running backwards momentarily and causing the crank to hit people in the face or it would break an arm. Ern was knocked unconscious and suffered a broken nose. It will not run continuously backwards, but it will run for a stroke or two, just enough to hit you hard. -- Waddling Eagle World Famous Flight Instructor |
#75
On 2007-05-17 14:26:01 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at
wow way d0t com said: "C J Campbell" wrote in message news:2007051622171050878-christophercampbell@hotmailcom... On 2007-05-15 05:59:05 -0700, "Doug Palmer" said: ... An engine can be made to run backwards. Model airplane engines do it all the time, usually as a result of mixture that is too rich. Granted, Those are two strokes and don't rely on valve timing to run. A buddy had a Bultaco motorcycle that liked to do that - it was pretty funny when he dumped the clutch not realizing that it was running backwards. real airplane engines are different and have more safety systems, but I could not say that it is impossible, especially given the enormous variety in types of engines, magnetos, starters, and fuel systems you see on airplanes. If you turn a conventional four stroke engine backwards, what would have been the exhaust stroke is now an intake stroke, and what was the intake stroke is now an exhaust stroke - the air will flow backwards through the engine from the exhaust to the intake so fuel will not find it's way in to sustatin combustion. On the other hand, an engine can "kick back" for a revolution or so - and that's enough to do the damage... To make a conventional four stroke run backwards, you have to re-arrange the location of the lobes on the cam. Trivia: Kettering developed his electric starter after a friend was killed when an automobile engine kicked back while he was starting it with a hand crank... Sounds like it was running backwards to me. Maybe it would not keep running, but the prop only has to hit you once. -- Waddling Eagle World Famous Flight Instructor |
#76
On May 18, 7:38 am, C J Campbell
wrote: On 2007-05-17 14:26:01 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com said: "C J Campbell" wrote in message news:2007051622171050878-christophercampbell@hotmailcom... On 2007-05-15 05:59:05 -0700, "Doug Palmer" said: ... An engine can be made to run backwards. Model airplane engines do it all the time, usually as a result of mixture that is too rich. Granted, Those are two strokes and don't rely on valve timing to run. A buddy had a Bultaco motorcycle that liked to do that - it was pretty funny when he dumped the clutch not realizing that it was running backwards. real airplane engines are different and have more safety systems, but I could not say that it is impossible, especially given the enormous variety in types of engines, magnetos, starters, and fuel systems you see on airplanes. If you turn a conventional four stroke engine backwards, what would have been the exhaust stroke is now an intake stroke, and what was the intake stroke is now an exhaust stroke - the air will flow backwards through the engine from the exhaust to the intake so fuel will not find it's way in to sustatin combustion. On the other hand, an engine can "kick back" for a revolution or so - and that's enough to do the damage... To make a conventional four stroke run backwards, you have to re-arrange the location of the lobes on the cam. Trivia: Kettering developed his electric starter after a friend was killed when an automobile engine kicked back while he was starting it with a hand crank... Sounds like it was running backwards to me. Maybe it would not keep running, but the prop only has to hit you once. -- Waddling Eagle World Famous Flight Instructor- Hide quoted text - - Show quoted text - The engine can fire when pulled through forward, but if the prop has too little momentum to carry the piston past TDC or the firing is advanced enough, it will kick backward. One blade, travelling at the speed it does, will split your skull. I work on these things all day, and when I forget that the prop is there and I stand up after doing something on the engine and whack my head on a stationary prop blade, it hurts big time. When it's swinging after a kickback it's moving faster than an axe and weighs a lot more. Whether dull or not, that trailing edge will do plenty of damage. You learn respect for these things when you bash your head occasionally. I used to own a '78 Dodge pickup truck, the worst vehicle I ever encountered. It would "diesel' on after I turned the ignition off, ignition being caused by hot carbon points in the cylinder head. Some cylinders would fire, some wouldn't, and the result was an exhaust system full of fuel vapours. An auto's exhaust system is a lot longer than a lightplane's, and it can store plenty of vapour. Sooner or later the engine would kick over backward, the exhaust would get sucked into a cylinder, and it would run backward for a half-second or so and finally die when the fuel vapours ran out. The hot carbon was still doing the igniting, like a glow plug. If an airplane does that it won't run so long, and it only does it if there's hot carbon in the head which means that it's been running. And that's why I consider a prop most dangerous immediately after shutdown. Dan |
#77
Many years ago I had a 125 hp Tripacer kick back when hand propping in
cold weather. The trailing edge of the prop put a 1/2 inch cut in my fingertip - right through the leather glove I was wearing. Needless to say I didn't go flying that day. Lessons learned - 1) Fingers on the prop face only. Never over a trailing edge. 2) Don't over prime. 3) Know you mag system so that you are hand propping on only impulse magnetos. |
#78
news:2007051806380943658-christophercampbell@hotmailcom... On 2007-05-17 14:26:01 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com said: "C J Campbell" wrote in message news:2007051622171050878-christophercampbell@hotmailcom... On 2007-05-15 05:59:05 -0700, "Doug Palmer" said: ... Trivia: Kettering developed his electric starter after a friend was killed when an automobile engine kicked back while he was starting it with a hand crank... Sounds like it was running backwards to me. Maybe it would not keep running, but the prop only has to hit you once. -- Waddling Eagle World Famous Flight Instructor So, we are arguing over the definition of the word "run"? Now, if you brought your car in to where I work because it would just fire a couple cylinders and quit and I tried to tell you that it was "running" wouild you buy that? :-) But, yea, one cylinders worth of "running" would be all it would take to split one's skull. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#79
C J Campbell wrote:
On 2007-05-17 21:00:36 -0700, "Dave Stadt" said: "C J Campbell" wrote in message news:2007051720300843658-christophercampbell@hotmailcom... On 2007-05-17 14:59:44 -0700, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com said: "Cubdriver" usenet AT danford DOT net wrote in message ... On Wed, 16 May 2007 22:00:14 -0700, C J Campbell wrote: People will say it is technically impossible, but I think it is wishful thinking. An engine may not run backwards very well, During World War II (really!) I worked on a farm in Concord, Mass. There was a great steel-wheeled tractor that was started with a hand crank. One time the tractor backfired while the lad was spinning the crank, and the engine started running backwards. He jumped aboard and had a great time wheeling it around the yard, one speed forward and three in reverse. Blue skies! -- Dan Ford That was a Diesel engine, correct? My great uncle Ern was nearly killed by a Model T Ford that he cranked up and the engine backfired and ran backward. 'Course, that guy was nearly killed so many times... -- Waddling Eagle World Famous Flight Instructor A Model T will not run backwards. Even if it did run backwards it would in no way would put your life in danger. The Model T was notorious for running backwards momentarily and causing the crank to hit people in the face or it would break an arm. Ern was knocked unconscious and suffered a broken nose. It will not run continuously backwards, but it will run for a stroke or two, just enough to hit you hard. That is called "kick back" and isn't "running backward" at all. Matt |
#80
On Thu, 17 May 2007 17:59:44 -0400, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote: crank. One time the tractor backfired while the lad was spinning the crank, and the engine started running backwards. He jumped aboard and had a great time wheeling it around the yard, one speed forward and three in reverse. Blue skies! -- Dan Ford That was a Diesel engine, correct? I doubt it. We didn't even know what disel was! At least I didn't. This tractor was built in the 1930s or 1920s, before the days of pneumatic tires. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
