Tow cars and trailers
Old May 18th 07, 12:07 AM posted to rec.aviation.soaring
Bill Daniels
Default Tow cars and trailers
Well, gas is $3.50/Gal in many parts of the US and who is to say it won't be
$4/gal next summer. This is starting to hurt - and getting me to think of a
more economical vehicle.
Many of us drive larger vehicles than we might otherwise choose simply to
pull our trailers 1% of the time. 99% of the time, we could be driving,
say, a Volkswagen Passat TDI diesel getting 45mpg. The problem isn't the
gas milage when towing a glider trailer. We don't do that often enough for
it to impact out annual fuel budget. The problem is a big SUV as a daily
driver.
So, are there any tricks here? One is to simply own two cars. One to pull
a trailer and another for a daily driver that gets good milage. Paying
license fees, insurance and other fixed costs for a vehicle driven 1% of the
time seems outrageous though.
The other thread about surge brakes got me thinking WAY outside the box. Is
there a way for the trailer to be self-propelled? If one were to install a
load sensor in the trailer tongue that could sense the pull of the tow
vehicle as well as the push of an over-running trailer, could that control a
small power plant in the trailer that drove the trailer's wheels? If done
perfectly, a light towing vehicle might not feel the trailer at all.
If the trailer power were electric, you would have a parallel, plug-in
hybrid. The car engine would charge the trailer batteries when they were
not needed for propulsion and the electrics would kick in on the hills.
Downhill regenerative braking would also charge the trailer batteries as
could large solar panels on the trailer.
It might work fine for a short commute to the glider field and maybe not so
well on a cross country trip but it's fun thinking about.
Bill Daniels
Old May 18th 07, 12:19 AM posted to rec.aviation.soaring
anonymous
The Volkswagen Passat TDI is a fairly common tow vehicle in Europe. No
need for a SUV. But then, this has been discussed here many times.
Old May 18th 07, 12:48 AM posted to rec.aviation.soaring
Bill Daniels
"anonymous" no.email@spamfree wrote in message
Yes, I know that. However, it's not common in the US bacause of the higher,
hotter, longer trip conditions here. Almost any trip in the western US will
include at least one long, steep grade starting with temperatures above 40C
that may climb to 3600 meters ASL. I know of one VW that arrived as
essentially junk after one trip. The next time I saw that pilot, he was
driving a much bigger tow vehicle.
If you prefer the manufacturer's position, here's a comment from USA Today's
James R. Healey::
"Back to the Passat towing spec question: VW just called to say towing's not
recommended with the Passat and that's why no towing spec is provided. Would
towing void the warranty? Uh, um, well, probably not, VW says, as long as
you tow light loads with a proper hitch installed and used per the
aftermarket supplier's recommendations. Unless, of course, some damage is
the obvious result of towing. Sounds to me as if anybody who wants to tow
should choose a different car. Too much 'maybe' factor with Passat. "
The VW Passat TDI diesel is a great car. I just wouldn't abuse it by towing
a glider trailer.
Bill Daniels
Old May 18th 07, 01:15 AM posted to rec.aviation.soaring
Dan G
I can only think that it was very old or not maintained. Gliders are
light; a modern European TDi would barely notice the load even over
the roads you describe (which are common in the Alps).
Dan
Old May 18th 07, 01:46 AM posted to rec.aviation.soaring
Ed Winchester
James R. Healey::
a glider trailer.
Bill Daniels
Bill,
I have to agree with Dan. With the TDI (turbocharged diesel injection)
the elevation would have almost no effect. Yes, pulling up the hills
would work the engine a bit, but gearing down and watching the temps
should cover that.
Ed
Old May 18th 07, 04:14 AM posted to rec.aviation.soaring
Paul Hanson
At 00:48 18 May 2007, Ed Winchester wrote:
Bill Daniels wrote:
'anonymous' wrote in message
choose simply to
in Europe. No
here many times.
VW that arrived as
James R. Healey::
'Back to the Passat towing spec question: VW just
VW says, as long as
and used per the
who wants to tow
with Passat. '
abuse it by towing
a glider trailer.
Bill Daniels
Bill,
diesel injection)
up the hills
the temps
should cover that.
Ed
I think we must be careful not to use too light of
a vehicle to tow our glider trailers with. Although
the 2:1 ratio some trailer rental companies use ('U-Haul
used to require 2:1 ratio between the towing vehicle
and the trailer. Stated differently, the towing vehicle
must weigh twice as much as the trailer and its contents.
To increase rentals, U-Haul lowered that ratio from
2:1 to 1:1. This change decreased stability and increased
accidents'.--from http://www.beasleyallen.com) may
be suitable for short coupled trailers, our glider
trailers although admittedly light in weight, have
much greater moments due to the longer arm, so for
me at least, that unfortunately rules out small, lightweight
super efficient vehicles, due to safety concerns. I
did find this in another thread though, talking about
glider towing with a Toyota Highlander Hybrid:
'I'll add my two cents to this thread. I towed my glider
trailer last weekend with a HH 4wd. Glider trailers
are tricky to tow because of their length (28') and
the fact that they have a lot of sail area. Weight
is about 1800 lbs. The rig was rock solid in mountainous
terrain with a 25 mph crosswind. Was at least as good
as my previous vehicle, a Grand Cherokee. I am quite
pleased with the performance. Overall, I am getting
about 26-27 MPG'.
found in:
http://townhall-talk.edmunds.com/direct/view/.f0daea6
I like the idea of good gas mileage, since I tow mine
enough for that to be a major budget concern, for me.
(Ca to Memphis last Feb, Ca to Oshkosh later, plus
several milk runs...ouch) I currently tow with a Chevy
Astro Van, and get around 18-19mpg, doing normal interstate
speeds (70-80mph), so 26-27mpg does not sound too bad,
although I would need a motel when I got where I was
going because the Highlander Hybrid does not sound
big enough for me to camp in with my dog while on site.
It does sound like a good possible solution for some
of you though.
I do really like the idea of some sort of drive-assist
system in the trailer though, an idea I've considered
before, although my gas mileage without the trailer
is near the same in the Astro. Somebody needs to develop
a hybrid van, with good towing capacity, coupled to
a trailer that assists and then we would be on to something.
Although, the excessive cost of this combo would probably
outweigh the extra money that would be saved on gas,
it seems like a step in the right direction none the
less.
Paul Hanson
"Do the usual, unusually well"--Len Niemi
Old May 18th 07, 10:59 AM posted to rec.aviation.soaring
On May 18, 3:14 pm, Paul Hanson
. ch...
choose simply to
in Europe. No
here many times.
VW that arrived as
James R. Healey::
VW says, as long as
and used per the
who wants to tow
with Passat. '
abuse it by towing
a glider trailer.
Bill Daniels
Bill,
diesel injection)
up the hills
the temps
should cover that.
Ed
accidents'.--fromhttp://www.beasleyallen.com) may
about 26-27 MPG'.
found in:http://townhall-talk.edmunds.com/direct/view/.f0daea6
of you though.
less.
Paul Hanson
"Do the usual, unusually well"--Len Niemi- Hide quoted text -
- Show quoted text -
A little sideways on this thread ,how does a Chevy Blazer 4.3 litre,
handle the towing loads as I am considering one as a tow
vehicle ,pulling
a tube type of trailer for a Ventus b or Nimbus 2 model. Any bad
reports or known problems I should be aware of .
gary
Old May 18th 07, 09:54 PM posted to rec.aviation.soaring
Ramy
. ch...
choose simply to
in Europe. No
here many times.
VW that arrived as
James R. Healey::
VW says, as long as
and used per the
who wants to tow
with Passat. '
abuse it by towing
a glider trailer.
Bill Daniels
Bill,
diesel injection)
up the hills
the temps
should cover that.
Ed
about 26-27 MPG'.
of you though.
less.
While we're on the subject, any comments on the Lexus RX hybrid as a
tow vehicle?
Ramy
Paul Hanson
vehicle ,pulling
gary- Hide quoted text -
Old May 19th 07, 12:49 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Volkswagon, Ford, Mercedes and Fiat (and others) all make great small vans, diesel powered that will tow large trailers easily. Nowadays they drive like a large family sedan!
There is tons of space for extra gear in the back, they run on the sniff of fuel, pull like a 14 year old and you can sleep in the back very comfortably if you need to.
Go try one!
Bagger
Old May 19th 07, 06:13 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Unfortunately, none of these small vans are available in the US...
Marc
Flying Cars bryan chaisone Home Built 2 September 10th 04 07:01 PM
Flying Cars bryan chaisone Rotorcraft 0 September 10th 04 01:57 PM
Air cars ? Felger Carbon Home Built 9 January 3rd 04 07:41 AM
Air cars will never fly (911 more reasons) [email protected] Piloting 36 October 4th 03 03:26 PM
(was) Air cars will never fly (911 more reasons) Montblack Owning 6 September 29th 03 08:56 PM
