#71
![]() On Wed, 19 Dec 2007 12:21:28 -0500, "Peter R." Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? A) Automobiles have the advantage of 50+ years of research and innovation. When did you last see a magneto ignition on a car? GA aircraft, however.. B) Ditto automobile oil. When I lived in the Twin Cities, Mobil 1 oil at -25C was astonishing; you can spun over as if it was 35 degrees warmer. C) Cars get used daily by most/many folks. D) We're a nation of impatient, who GAF? people who'll sooner buy a new car anyhow.. [ps: I did plug in my car when it got REALLY cold..] -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#72
On Mon, 24 Dec 2007 04:47:22 +0000 (UTC), David Lesher
wrote: On Wed, 19 Dec 2007 12:21:28 -0500, "Peter R." Why is it that here in the Northeast US seemingly no one preheats their automobile engine before start-up in very cold temperatures? A) Automobiles have the advantage of 50+ years of research and innovation. When did you last see a magneto ignition on a car? GA aircraft, however.. aircraft have the same period of innovation but the developments have been for a different aim. longevity. once the designs reached their light weight optimum many aspects have stayed fixed. an engine running for long periods at the same rpm has what sort of need for vacuum advance? ...for instance. it does have a need to be able to continue to run in spite of electrical failure and a magneto and gravity feed do that for many designs quite adequately. simplicity removes failure points due to complexity. failures can kill you, simplicity keeps you alive. aircraft have a higher risk of being struck by lightning. how much of the high tech auto technology can survive a lightning strike? I must admit that the dead hand of certification needs to be phased out if there is any prospect of innovation again. the current cosworth formula1 engines deliver 950hp at 20,000rpm from an engine package smaller in capacity than an O-200. I wouldnt mind a little bit more bleed through of the technology into aviation. B) Ditto automobile oil. When I lived in the Twin Cities, Mobil 1 oil at -25C was astonishing; you can spun over as if it was 35 degrees warmer. C) Cars get used daily by most/many folks. D) We're a nation of impatient, who GAF? people who'll sooner buy a new car anyhow.. ahhh but that is the actual reason for the technical inovation behind the automobile. it self perpetuates the sale of new cars. functionally a T model ford would get you around as well as any modern car. the expectations driven by technology wouldnt allow you to be seen dead in one so you go out and buy a new high tech car capable of 200mph and a standing quarter in 5 seconds ...so that you can drive it in peak hour stop start traffic all the while dreaming of a circuit at brands hatch. cunning buggers arent they :-) |
#73
![]() aircraft have the same period of innovation but the developments have been for a different aim. longevity. once the designs reached their light weight optimum many aspects have stayed fixed. an engine running for long periods at the same rpm has what sort of need for vacuum advance? ...for instance. it does have a need to be able to continue to run in spite of electrical failure and a magneto and gravity feed do that for many designs quite adequately. simplicity removes failure points due to complexity. failures can kill you, simplicity keeps you alive. The thing that inhibits aircraft engine development appears to be simple economics. With the HUGE certification and liability hurdles, there simply are not enough potential sales to offset this economic mountain. Auto engines can afford to fail in use because the consequences are generally much less severe (you coast to a stop on the side of the road). If the proposed auto innovation passes its early tests, the market potential is generally large enough to make financial sense to go ahead and put the thing in production. The litigation blood suckers just about DARE anyone to attempt to introduce any changes to the airplane market. The idiotic public puts up with this nonsense and cheers on the suing family as they battle the "big, bad corporation" who harmed their poor, defenseless family with their "defective" product. Airplane owners have a split personality as far as I can tell by reading these forums. We cry "foul" when some idiot jury awards millions of dollars in damages for an airplane mishap. But pilots are the first in line to blame anyone in sight when it happens to them. Curious lot. Be Safe, Mike |
#74
Stealth Pilot writes:
A) Automobiles have the advantage of 50+ years of research and innovation. When did you last see a magneto ignition on a car? GA aircraft, however.. aircraft have the same period of innovation but the developments have been for a different aim. longevity. once the designs reached their light weight optimum many aspects have stayed fixed. I respectfully disagree. There are many things we've learned from which GA aircraft could benefit: automotive, electronic, metallurgical, human factors. That they don't is likely due to a "coffin corner" of low volumes, and high overhead {including but not limited to regulatory burden..}. Do I think aircraft engines could benefit from closed loop fuel systems [ie fuel injection/FADEC]? Yep. Do I think such can survive lightning? Yep. The Big Boys and the military aircraft do now; I recall that thunderstorm research fighter at NASA-LaRC with the dozens of thunderbolts stencils. Ditto TV/FM transmitters, who unlike the aircraft, ARE a direct sink for the lightning. It takes some design but nothing earthshaking. But even small stuff, such as integral voltage regulators [inside alternators] does not seem to come to pass. an engine running for long periods at the same rpm has what sort of need for vacuum advance? ...for instance. Suppose a computerized fuel injection system offered oh, say 7% better fuel consumption and 20% better TBO; would that be worth it? Look at the MPG and engine life of a 1950's car and one from the last 5 years. D) We're a nation of impatient, who GAF? people who'll sooner buy a new car anyhow.. ahhh but that is the actual reason for the technical inovation behind the automobile. it self perpetuates the sale of new cars. Perhaps, but the outcome is better cars. Until the Japanese invasion, Detroit built crap, at multiple levels: engineering, manufacturing, QC. The dope-slap they got took years to wake them up, but it and regulatory burdens [1] have given the customer a vehicle that's far far better than what [s]he could buy 40 years ago. I wish the GA industry could say the same. 1: The MPG/smog ones forced them to give up on carbs. How could anyone ever have improved on a Rochester Quadrajet for example -- why, it's a marval of simplicity exceeded only by the 6.02E23 parts found in a Model 28 Teletype, right?] -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#75
"nrp" wrote in message
... ... A lot of this moisture accumulation problem would go away if aircraft engines had a positive crankcase ventilation (PCV) system like car engines now do, but they don't for whatever reason. I suspect part of the reason car engines now last so much longer is due to the PCV system. Talking to one of the "old guys" at work some years ago this came up - his claim was that when PCV was first required, they were worried about re-cycling all the "gunk" and damaging the engines - but testing (and eventually field experience) showed that keeping the crankcase ventilated resulted in a significant boost in engine durability. He referred to PCV as one of the best things to come along... Conventional auto style PCV won't work well on an aircraft engine due to the lack of vacuum in the manifold to generate the air flow. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#76
"Stealth Pilot" wrote in message
... ... now to be serious... squeezing past the rings probably contributes a millionth of one poofteenth of a percent to the problem. Stick your thumb on the crankcase breather and have someone open the throttle - you will be surprised at the ammount of flow. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#77
#78
On Dec 25, 9:13 pm, "Roger (K8RI)" wrote:
Nope. We have taken rocker covers off engines immediately after a runup of a brand-new engine and found copious amounts of water A runup doesn't do squat about removing moisture or acid. It takes a 10 to 15 minute flight of take off and cruise power. I've never seen moisture after that, but I sure have after even a prolonged ground run. Besides, unless it's tied down I can't even hit cruise power in the runup without the tires skidding let alone full power. 24 X 24 and it'll start to acellerate which is kinda hard on the tires. My point was that there was lots of moisture in the case after a runup, and that it would take considerable hard flying to get it out. We had to redo jugs on our O-235 in one of the Citabrias at mid- time. Those engines tend to run cool (I have no idea at all why American Champion installs an oil cooler; its finned area is half blocked off as installed and they incude a cover to block the rest off in cooler weather) and the resulting condensation corrodes the cylinder walls. The worst damage was on the front of the front cylinders, the first area to cool after a flight, and that moisture causes galvanic corrosion (aluminum piston against steel wall) and pitting there. Then the rings wear it at a greater rate, a ridge forms at the bottom of the ring travel, and that sharp ridge starts shaving aluminum bits off the piston pin plugs. Aluminum slivers in the filter are the first sign of the trouble. Dan |
#79
On Dec 25, 8:13 pm, "Roger (K8RI)" wrote:
A runup doesn't do squat about removing moisture or acid. It takes a 10 to 15 minute flight of take off and cruise power. I've never seen moisture after that, but I sure have after even a prolonged ground run. 10 to 15 minutes at cruise prower is a reasonable claim. To say it takes at least one hours to heat up the engine enough to boil off water is OWT (which I often hear about). If one thinks a 30 minute cruise flight is too short to get rid of the water, does he reduce power to land? The engine cools off as the plane descends and water starts to accumulate in the oil according to this theory. |
#80
On Dec 24, 2:42 am, Stealth Pilot
I must admit that the dead hand of certification needs to be phased out if there is any prospect of innovation again. the current cosworth formula1 engines deliver 950hp at 20,000rpm from an engine package smaller in capacity than an O-200. I doubt such a formula 1 engine would have better power to weight ratio if you add the weight of the reduction gear to get the prop tip speed below supersonic. I also doubt it can match the BSFC of a O-200. People often claim the auto engines are so much better. I'd like to see an automobile gasoline engine that has 1. better BSFC than an IO-550 at its 75% rated power and 2. better power to weight ratio including the weight of the reduction gear to drive a propeller. http://www.prime-mover.org/Engines/G.../article2.html has a lot of good info. |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
LOM engines | buckey | Home Built | 14 | October 30th 03 05:22 PM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Barnyard--- Auto engines | Jerry Springer | Home Built | 10 | August 8th 03 06:38 PM |
