Is it a bad idea to fly VFR at night and navigate by following highways? At
night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Are there hidden dangers in this? Do night VFR pilots ever/often navigate by following highways? What other forms of visual navigation are usable at night? |
Mxsmanic wrote:
Is it a bad idea to fly VFR at night and navigate by following highways? At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Are there hidden dangers in this? Do night VFR pilots ever/often navigate by following highways? What other forms of visual navigation are usable at night? Why would you want to when VORs ang GPSs are available? However, on a clear night you can see the far away town lights. You just need to be sure that the lights you see are the town you want. I'll stay with my GPS for navigation. -- Regards, Ross C-172F 180HP KSWI |
Ross writes:
Why would you want to when VORs ang GPSs are available? Mainly just for practice, in case the radio navigation fails or something. However, on a clear night you can see the far away town lights. You just need to be sure that the lights you see are the town you want. I'll stay with my GPS for navigation. What if the GPS stops working? |
Mxsmanic wrote in
: Ross writes: Why would you want to when VORs ang GPSs are available? Mainly just for practice, in case the radio navigation fails or something. Why, you don't fly. Or is your latest terorist target a night target? Bertie |
Ross wrote in
: Mxsmanic wrote: Is it a bad idea to fly VFR at night and navigate by following highways? At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Are there hidden dangers in this? Do night VFR pilots ever/often navigate by following highways? What other forms of visual navigation are usable at night? Why would you want to when VORs ang GPSs are available? If you're flying a no radio airplane? Bertie |
Bertie the Bunyip wrote:
Ross wrote in : Mxsmanic wrote: Is it a bad idea to fly VFR at night and navigate by following highways? At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Are there hidden dangers in this? Do night VFR pilots ever/often navigate by following highways? What other forms of visual navigation are usable at night? Why would you want to when VORs ang GPSs are available? If you're flying a no radio airplane? Bertie Then I guess I would follow roads, but might buy a handheld GPS if I was going to do a lot of this. -- Regards, Ross C-172F 180HP KSWI |
Mxsmanic wrote: Is it a bad idea to fly VFR at night and navigate by following highways? My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) At night outside large cities, there doesn't seem to be much else that's visible. It seems to me that if you can clearly see the highway, it can guide you and you can get a good idea of where you are with respect to terrain, so it should work. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. -c |
gatt wrote:
Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. I followed a highway up to Alaska. In daylight,however. |
gatt writes:
My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) There is a sobering story right along those lines at http://www.aopa.org/pilot/never_again/2008/na0801.html I find it interesting that the author says this VFR flight scared him more than any of his combat missions in Vietnam. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. Good. I wanted to make sure I'm not missing some risk or danger to following highways. From the article above I learned that things like wires and cables are a real risk if you're very close to the highway, but only a helicopter would be that low. |
Mxsmanic wrote in
: gatt writes: My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow Roads " (or rivers) There is a sobering story right along those lines at http://www.aopa.org/pilot/never_again/2008/na0801.html I find it interesting that the author says this VFR flight scared him more than any of his combat missions in Vietnam. Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch through most of Oregon looks like somebody drew a straight line with a pencil across the landscape. If you were flying from Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow the freeway the entire route. You'd still use your VFR navigation aids and checkpoints to make sure know how far you are enroute, and also to avoid controlled airspace, etc, but having that road, railroad, river makes for a more-enjoyable flight. Good. I wanted to make sure I'm not missing some risk or danger to following highways. From the article above I learned that things like wires and cables are a real risk if you're very close to the highway, but only a helicopter would be that low. Wow, hittign a virtual wire in a virtual airplane could really ruin your day if you were insane! Bertie |
| Thread Tools | |
| Display Modes | |
| Arizona Highways magazine on soaring, flight | [email protected] | Soaring | 0 | December 20th 06 04:05 AM |
| Night Flying. How many PPSEL pilots excersie night priveledges? | [email protected] | Piloting | 42 | December 16th 06 05:51 PM |
| Night lights, night flights, OLC and records | Denis | Soaring | 19 | October 10th 06 12:51 AM |
| Hood and sim work at night loggable as night time? | Ron Garret | Piloting | 12 | September 9th 06 03:15 AM |
| FS2004 scenery which shows roads and highways? | John Doe | Simulators | 9 | March 25th 04 09:36 AM |
