![]() How do you feel about sharing the skies with this little, wingless UAV? HONEYWELL UNMANNED MICRO AIR VEHICLE OK'D FOR AIRSPACE OPERATIONS (http://www.avweb.com/eletter/archive...ll.html#197198) Honeywell's unmanned Micro Air Vehicle (https://www.honeywell.com/sites/port...fdc1e6517d&c=n) weighs 14 pounds, can fly as high as 10,500 feet, and zips along at up to 50 knots. This week, the FAA gave the vehicle an experimental airworthiness certificate, allowing it to fly in the National Airspace System. The ducted-fan aircraft can take off or land vertically and transition to sustained horizontal flight. Applicants have to demonstrate to the FAA that a collision with another aircraft or other airspace user is "extremely improbable," the agency said last year, when it issued policy guidelines (http://a257.g.akamaitech.net/7/257/2...07/E7-2402.htm) for operations of unmanned aircraft in the NAS. Honeywell's MAV was recently chosen by the Miami/Dade County Police Department in Florida for an experiment with the FAA to explore the use of small aerial vehicles for law enforcement. 10,500 feet is not within the normal realm of model airplanes. As can be seen in this video: http://www.honeywell.com/sites/porta...video&theme=T8 this 14 pound Micro Air Vehicle would not be welcome coming through an aircraft windscreen or falling on the heads of the public in urban areas for that matter. But fear not; the FAA has your safety clearly protected in this memorandum (not even a regulation nor order): :-) http://a257.g.akamaitech.net/7/257/2...07/E7-2402.htm In response to this growing demand for public use unmanned aircraft operations, the FAA developed guidance in a Memorandum titled ``Unmanned Aircraft Systems Operations in the U.S. National Airspace System--Interim Operational Approval Guidance'' (UAS Policy 05-01). In this document, the FAA set out guidance for public use of unmanned aircraft by defining a process for evaluating applications for Certificate(s) of Waiver or Authorization (COA's) for unmanned aircraft to operate in the National Airspace System. The concern was not only that unmanned aircraft operations might interfere with commercial and general aviation aircraft operations, but that they could also pose a safety problem for other airborne vehicles, and persons or property on the ground. The FAA guidance supports unmanned aircraft flight activity that can be conducted at an acceptable level of safety. In order to ensure this level of safety, the operator is required to establish the Unmanned Aircraft System's (UAS) airworthiness either from FAA certification, a DOD airworthiness statement, or by other approved means. Applicants also have to demonstrate that a collision with another aircraft or other airspace user is extremely improbable as well as complying with appropriate cloud and terrain clearances as required. Key to the concept are the roles of pilot-in-command (PIC) and observer. The PIC concept is essential to the safe operation of manned aircraft. The FAA's UAS guidance applies this PIC concept to unmanned aircraft and includes minimum qualifications and currency requirements. The PIC is simply the person in control of, and responsible for, the UAS. The role of the observer is to observe the activity of the unmanned aircraft and surrounding airspace, either through line-of-sight on the ground or in the air by means of a chase aircraft. In general, this means the pilot or observer must be, in most cases, within 1 mile laterally and 3,000 feet vertically of the unmanned aircraft. Direct communication between the PIC and the observer must be maintained at all times. Unmanned aircraft flight above 18,000 feet must be conducted under Instrument Flight Rules, on an IFR flight plan, must obtain ATC clearance, be equipped with at least a Mode C transponder (preferably Mode S), operating navigation lights and / or collision avoidance lights and maintain communication between the PIC and Air Traffic Control (ATC). Unmanned aircraft flights below 18,000 feet have similar requirements, except that if operators choose to operate on other than an IFR flight plan, they may be required to pre-coordinate with ATC. The FAA has issued more than 50 COA's over the past 2 years and anticipates issuing a record number of COA's this year. For more information, Memorandum on UAS Policy (05-01) and other policy guidance is available at the FAA Web site: http://www.faa.gov/uas But I have some questions: 1. How does one prove that a collision with other aircraft is "extremely improbable?" 2. To what standards is the PIC held; must s/he hold an airmans certificate? 3. In the event of a MAC, how does the pilot of the downed aircraft establish who is responsible for the MAC? Perhaps there are some answers he http://www.faa.gov/about/office_org/...ineering/uapo/ “… UAs are part of the future of aviation, and that future is on our doorstep right now. The system is in place today to accommodate the entry of new aircraft into the National Airspace System; this is nothing new for the FAA. It is our day-to-day business.”… “The FAA, working closely with the aviation industry, will develop safety standards and operating procedures to ensure their safe integration into the NAS.” – Nick Sabatini, Associate Administrator for Aviation Safety Contact UAPO for more information about the UAS program, UAS certifications and authorizations, or the COA application process. http://www.faa.gov/contact_faa/?retu...%2FD%24L%20%0A Or perhaps this FAA FAQ addresses the questions: http://www.faa.gov/aircraft/air_cert...s/uas/uas_faq/ Do I need an experimental certificate for my UAS? Yes, if you plan to fly your unmanned aircraft UA as civil aircraft (§1.1). The FAA's current policy is to issue only special airworthiness certificates to UAS's in the experimental category for the purposes of research and development, crew training, or conducting market surveys (§21.193). No, if you are a hobbyist and intend to fly your model aircraft in accordance with the guidance in Advisory Circular 91-57, Model Aircraft Operating Standards. No, if you intend to operate your UA as a public aircraft for the purposes of governmental functions. In this case, the FAA's Air Traffic System Operations and Safety Office (ATO-R) may issue a Certificate of Authorization or Waiver (COA). What does a special airworthiness certificate in the experimental category allow me to do? The operating limitations issued with this type of certificate allow a UA to be operated only within the line of sight of an observer, during daylight hours and when other aircraft are not in the vicinity. What should I do to receive a special airworthiness certificate in the experimental category? You should first contact Richard Posey in the FAA Production and Airworthiness Division, AIR-200. He can answer your questions, such as if your UA qualifies for a special airworthiness certificate, what you would need to do to receive a special airworthiness certificate, and when the FAA evaluation process would begin. He can also send you additional information that is unique to the unmanned aircraft airworthiness process. Contact Richard Posey Phone: (202) 267-9538 Address: Federal Aviation Administration Production and Airworthiness Division, AIR-200 Room 815 800 Independence Ave. SW Washington, DC 20591 Attn: Richard Posey Has the FAA issued an airworthiness certificate to a UAS? Yes. The FAA issued the first airworthiness certificate for UAS on August 25, 2005. Oh well, not much of substance there. Perhaps there are some answers he http://www.faa.gov/about/office_org/...ring/uapo/map/ Unmanned Aircraft Program Office (UAPO) Unmanned Aircraft Systems Roadmap The Unmanned Aircraft Program Office is developing a 5-year roadmap for the introduction of Unmanned Aircraft Systems (UAS) into the National Airspace System. This collaborative effort will specifically focus on defining related activities within the FAA, Government Agencies, and industry. The UAS Roadmap will evaluate the current state of UAS mission needs, forecast their near-term demands on airspace capacity, and chart a strategic plan to safely integrate their operations into the nation's airspace. Public release of the UAS Roadmap is delayed pending FAA AVS management team final review and approval. Not only is there nothing here, but I don't see any provision for stakeholder input. Oh well..... Here's a photograph of the FAA UAS Certification Team who issued 17 UAV experimental certificates in 2007. http://www.faa.gov/about/office_org/...ing/uapo/news/ And here are photos of some of the UAVs you'll be sharing the NAS with: http://www.faa.gov/about/office_org/...ews/jul-dec07/ Among them is the Honeywell's MAV: On December 6, 2007, Mr. Jim Fote the San Antonio MIDO issued an experimental certificate to Honeywell for their gMAV UAS. The gMAV aircraft is a VTOL, ducted fan, that weighs approximately 18 lbs. Honeywell is authorized to operate their UAS for the purposes of R & D, crew training and market survey. Honeywell will operate the gMAV on the property of the Laguna Pueblo, New Mexico. So the FAA seems to have restricted the Honeywell gMAV to a single location. Unfortunately, I don't see any TFRs in New Mexico he http://tfr.faa.gov/tfr2/list.html That might mean that the Honeywell MAV is restricted to low level. It would appear that there may be some restrictions placed on this UAV for operations within the NAS and over the heads of people on the ground: http://www.faa.gov/about/office_org/...tions/uas/coa/ Certificate of Authorization or Waiver (COA) COA is an authorization issued by the Air Traffic Organization to a public operator for a specific unmanned aircraft (UA) activity. After a complete application is submitted, the FAA conducts a comprehensive operational and technical review. If necessary, provisions or limitations may be imposed as part of the approval to ensure the UA can operate safely with other users. That is good, but it doesn't answer my questions either. https://www.honeywell.com/sites/port...fdc1e6517d&c=n The FAA certificate allows Honeywell’s gMAV Unmanned Aerial System (UAS) to fly in the National Airspace System. The experimental certificate was granted after a successful demonstration flight for FAA officials at a remote site near Laguna, New Mexico. Honeywell’s certificate is one of only four such certificates granted for unmanned vehicles by the FAA. No doubt there are some answers here, but I couldn't find them: http://www.faa.gov/aircraft/air_cert...ovals/uas/reg/ The word 'unmanned' doesn't even appear in the DEFINITIONS AND ABBREVIATIONS: http://ecfr.gpoaccess.gov/cgi/t/text.... 1.1.1.0.1.1 So while it appears, that the Honeywell gMAV was recently chosen by the Miami/Dade County Police Department to spearhead its experiment with the FAA to explore use of small unmanned aerial systems for law enforcement purposes http://www.atca.org/singlenews.asp?item_ID=5165&comm=0, it is not clear where those experiments will be conducted. There are some clues he http://www.blogsofwar.com/2007/11/28...e-testing-uav/ Miami-Dade Police Testing UAV This is all part of the same FAA test that got so much attention here in Houston. Miami-Dade police said only licensed pilots with the aviation unit will operate the devices because the airspace in the county is so busy. Only the Miami-Dade police department and the Houston police department were given permission by the FAA to experiment with the drones. “The capability of the unit is phenomenal,” said Miami-Dade Detective Juan Villalba. The unmanned aircraft will be used during SWAT team and tactical operations, especially when officers need video of a heavily armed suspect. The Miami-Dade police department has not yet taken possession on its drone, but the Houston police department has and is already conducting tests. So it would appear that despite the FAA's assertion that Honeywell will operate the gMAV on the property of the Laguna Pueblo, New Mexico, it will also be operated in Miami, and another UAV is currently operating in Huston. These contradictions raise concerns about the regulation of these UAVs in the NAS.... News stroy video he http://www.local10.com/news/14708354/detail.html# High-Tech Drones Joining Miami Police Force Unmanned Aircraft System Will Help SWAT Units POSTED: 5:48 pm EST November 27, 2007 Leave it to the Texans to missrepresent the facts: http://www.anomalytv.com/site/2007/1...rones-in-2008/ Video: Local 2 Investigates Captures Secret HPD Test On Tape Houston Police to Get Ticketing Drones in 2008 Houston police contacted KPRC from the test site, claiming the entire airspace was restricted by the Federal Aviation Administration. Police even threatened action from the FAA if the Local 2 helicopter remained in the area. However, KPRC reported it had already checked with the FAA on numerous occasions and found no flight restrictions around the site, a point conceded by Montalvo. Montalvo told reporters the unmanned aircraft would be used for "mobility" or traffic issues, evacuations during storms, homeland security, search and rescue, and also "tactical." She admitted that could include covert police actions and she said she was not ruling out someday using the drones for writing traffic tickets. HPD leaders said they would address privacy and unlawful search questions later. South Texas College of Law professor Rocky Rhodes, who teaches the constitution and privacy issues, said, "One issue is going to be law enforcement using this and when, by using these drones, are they conducting a search in which they'd need probable cause or a warrant. If the drones are being used to get into private spaces and be able to view where the government cannot otherwise go, and to collect information that would not otherwise be able to collect, that's concerning to me." HPD Assistant Chief Vickie King said of the unmanned aircraft, "It's interesting that privacy doesn't occur or searches aren't an issue when you have a helicopter pilot over you and it would not be used in airspace other than what our helicopters are used in already." She admitted that police helicopters are not equipped with cameras nearly as powerful as the unmanned aircraft, but she downplayed any privacy concerns, saying news helicopters have powerful cameras as well. The price tag for an unmanned aircraft ranges from $30,000 to $1 million each and HPD is hoping to begin law enforcement from the air by June of 2008 with these new aircraft. http://www.irnnews.com/news.asp?acti...0599&category= Vaughn Fulton, Honeywell's small UAS programme manager: The police department will operate the UAVs, and helicopter pilots from its aviation unit have been trained to fly the gMAV. "The demonstration will be in urban terrain, involving real tactical operations," he says. The 8.2kg (18lb) gMAV is Honeywell's second version of the man-portable UAV. Compared with the original tMAV developed for the US Defense Advanced Research Projects Agency, the gMAV has a larger outside diameter housing twice the fuel and providing an endurance exceeding 55min at sea level. And in addition to the hazards that may be posed to NAS operations, there is the issue of privacy: http://alea.org/public/newsletters/07_11/index.aspx Recent Rulings for Law Enforcement Use of UAVs The National Institute of Justice, National Law Enforcement and Corrections Technology Centers: Border Research Technology Center, has recently released the following technical bulletin on law enforcements use of UAS: “Unmanned Aircraft Systems (UAS), also known as UAVs, is a rapidly emerging technology that has exceptional appeal to law enforcement. UAS are considered aircraft. These aircraft can often be flown autonomously and at great distances from the command station. In addition, these aircraft can be very small and still carry enough equipment to provide video downlink capabilities. The operation of a UAS by a public agency, whether it is federal, state or local law enforcement, is enforced by FAA regulations and federal statutes. With the increase in use of UAS by the military in overseas operations, there has been a significant increase in the number of vendors both producing and marketing these same units to law enforcement. Prior to purchasing or leasing a UAS, please consider the following: For a public aircraft operation, the FAA holds the position that a Certificate of Authorization (COA) is required to operate UAS in the national airspace. The FAA has stated publicly that COAs would not be issued for use of a UAS over populated areas. Any law enforcement agency operating a UAS will be required to establish their own airworthiness for the UAS. The airworthiness establishment is the responsibility of the agency and not the vendor. Remember, any agency applying for and receiving a COA assumes liability for the entire operation. While vendor information may be used in deeming an aircraft airworthy, it should not be the only information relied upon. A vendor approaching a law enforcement agency offering to demonstrate a UAS must have an experimental airworthiness certificate issued by the FAA prior to the flight. A vendor cannot rely upon an agency’s COA to fly the aircraft. COAs are only issued for aircraft that qualify as “public” aircraft. It is not anticipated that the FAA will amend their position on the operations of UAS before the year 2010. However, there are two key activities taking place that will push the airspace access issue forward. The first is that the FAA has agreed to conduct two test projects with major metropolitan police departments. One is Miami/Dade (FL) and the other is the City of Houston (TX). Each of these will provide valuable insight into the difficulties that may exist in operating UAS in urban environments. The other activity is the creation of new regulation for small UAS to fly in the airspace. This recent development is just starting and will be the genesis for getting small UAS flying in a majority of the U.S. without a COA. Rulemaking can take time, however, so stick with the COA process for the next year or two.” The ALEA is committed to working with the FAA, NIJ, and others on rules and regulations regarding the use of UAS by law enforcement, and plans to participate in a NIJ forum on this subject during the winter of 2007-2008. Source: National Institute of Justice http://www.politicalprecipice.com/ Saturday, December 8, 2007 Smokers Who Drop Butts to be Targeted by CCTV British CCTV cameras are to be used to help catch smokers who litter the streets with cigarette butts. The littering problem has grown since the introduction of the smoking ban with areas outside some pubs particularly hard hit. Now Bradford Council has warned that it will use footage from its CCTV system to identify and prosecute the culprits in the worst-hit areas. And there is always the question of missues by LEOs: http://www.youtube.com/watch?v=IMaMY...precipice.com/ UHP (Utah Highway Patrol) tasers man in front of pregnant wife and baby over an alleged speeding ticket. Outraged? Call the Vernal, Utah UHP Office and let them know! http://www.youtube.com/watch?v=FkfkQ...eature=related http://www.youtube.com/watch?v=KMpEr...eature=related |
![]() "Larry Dighera" wrote in message ... How do you feel about sharing the skies with this little, wingless UAV? The first time an aircraft collides with one, it's going to start sorting itself out. If no such accident ever happens it's not really a problem. -c |
![]() Larry Dighera wrote: How do you feel about sharing the skies with this little, wingless UAV? Unless it is given it's own airspace by ATC I'd say it's a very bad idea. It should keep the hell out of uncontrolled airspace. With almost no vision capability (i.e. TV is very limited compared to the Mk1 eyeball) the UAV pilot won't see a converging 'craft easily. If this is not carefully considered it will kill a VFR flight sooner or later. my 2c Cheers |
How do you feel about sharing the skies with this little, wingless UAV? Appears to weigh about what a mature bald eagle would weigh (~14 lbs), and has about the same altitude range (both about 10,000 ft). Since there are a lot more eagles than UAVs, I'd be more worried about an eagle strike than a UAV strike. |
Recently, Jim Logajan posted:
Larry Dighera wrote: How do you feel about sharing the skies with this little, wingless UAV? Appears to weigh about what a mature bald eagle would weigh (~14 lbs), and has about the same altitude range (both about 10,000 ft). Since there are a lot more eagles than UAVs, I'd be more worried about an eagle strike than a UAV strike. Eagles have excellent MkII eyeballs, and can at least participate in see-and-avoid. Neil |
"Neil Gould" wrote:
Recently, Jim Logajan posted: Larry Dighera wrote: How do you feel about sharing the skies with this little, wingless UAV? Appears to weigh about what a mature bald eagle would weigh (~14 lbs), and has about the same altitude range (both about 10,000 ft). Since there are a lot more eagles than UAVs, I'd be more worried about an eagle strike than a UAV strike. Eagles have excellent MkII eyeballs, and can at least participate in see-and-avoid. http://www.birdstrike.org/ |
"Neil Gould" wrote:
Eagles have excellent MkII eyeballs, and can at least participate in see-and-avoid. Eagles have no concept of human "see-and-avoid" rules and would have no reason to expect collision or confrontation with anything other than another bird moving at their own speed. Here's a report that deals directly with aircraft strikes with bald-eagles: http://www.birdstrikecanada.com/Pape...e%20Report.pdf |
On Thu, 21 Feb 2008 21:51:05 -0000, Jim Logajan
wrote in : Larry Dighera wrote: How do you feel about sharing the skies with this little, wingless UAV? Appears to weigh about what a mature bald eagle would weigh (~14 lbs), and has about the same altitude range (both about 10,000 ft). Since there are a lot more eagles than UAVs, I'd be more worried about an eagle strike than a UAV strike. But an eagle's wingspan is between 72 to 90 inches http://www.baldeagleinfo.com/eagle/eagle-facts.html, and they have the ability to avoid aircraft. You'd have to have eyes better than Yeager to see that little Honeywell UAV at two miles up, so you couldn't count on the ground observer to see-and-avoid visually. |
On Thu, 21 Feb 2008 21:51:05 -0000, Jim Logajan wrote in : Larry Dighera wrote: How do you feel about sharing the skies with this little, wingless UAV? Appears to weigh about what a mature bald eagle would weigh (~14 lbs), and has about the same altitude range (both about 10,000 ft). Since there are a lot more eagles than UAVs, I'd be more worried about an eagle strike than a UAV strike. But an eagle's wingspan is between 72 to 90 inches http://www.baldeagleinfo.com/eagle/eagle-facts.html, and they have the ability to avoid aircraft. You'd have to have eyes better than Yeager to see that little Honeywell UAV at two miles up, so you couldn't count on the ground observer to see-and-avoid visually. Hmmm. Better back up for me: I'm not clear now what the thrust of your original post was. Was the intent to make a specific assertion (e.g. that UAVs are sufficiently dangerous they should be carefully regulated) or just throwing the subject open for discussion? My own assertion is this: in any list of priorities that drive air safety, regulation of UAVs is overkill and even takes time, money, and resources away from dealing with higher probability risks. |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
