#71
![]() "Tarver Engineering" wrote in message ... "Jim Knoyle" wrote in message ... "Tarver Engineering" wrote in message ... "Jim Knoyle" wrote in message ... Hey, Splaps. Next time you are ever near a DADC or it's diagram, check out what they have at the other end of the tubing connected to the fitting labeled *TOTAL*. Only ONE pitot tube! Yep, the term Total means they added two sensors. Nope, the pitot tube detects static pressure + impact pressure. Read the book(s). I have been writing that to you for years, Knoyle. That is why you seem such an idiot when you insist a pitot port is a pitot tube. Total means there is more than one sensor, nothing more. You really don't understand how that one little opening on the end of that pointy thing up front can detect static pressure (altitude) as well as impact pressure (airspeed), do you. That's sad! |
#72
Rick wrote:
You must be a common troll, Tarver, it is inconceivable that an adult with your level of reading and reasoning skills could function outside a constant care facility. Maybe you don't. Oh no, give Splappy his due. He's far from a common troll. He actually believes the bull**** he posts! ------------------------------------------------------------------------ |Rich Ahrens | Homepage: http://www.visi.com/~rma/ | |-----------------------------------------------| |"In a world full of people only some want to fly - isn't that crazy?" | ------------------------------------------------------------------------ |
#73
#74
#75
#76
#77
![]() "B2431" wrote in message ... From: "Jim Knoyle" Date: 1/17/2004 3:48 PM Central Standard Time Message-id: "Tarver Engineering" wrote in message ... "Jim Knoyle" wrote in message ... "Tarver Engineering" wrote in message ... "Jim Knoyle" wrote in message ... Hey, Splaps. Next time you are ever near a DADC or it's diagram, check out what they have at the other end of the tubing connected to the fitting labeled *TOTAL*. Only ONE pitot tube! Yep, the term Total means they added two sensors. Nope, the pitot tube detects static pressure + impact pressure. Read the book(s). I have been writing that to you for years, Knoyle. That is why you seem such an idiot when you insist a pitot port is a pitot tube. Total means there is more than one sensor, nothing more. You really don't understand how that one little opening on the end of that pointy thing up front can detect static pressure (altitude) as well as impact pressure (airspeed), do you. That's sad! The hole on the front only detects pitot pressure. If there are holes on the side are for detecting static pressure. No, sorry Dan, you'll have to refer to a more modern air data computer. When the label at the top of the ADC switched from pitot to total, the definition for Total Pressure (Pt) was given as: "This is a pressure input (from the aircraft pitot probe) which varies both with altitude and aircraft speed. (Range 3.11 to 42.50 in. Hg.)" *This was a direct quote from a Honeywell HG280D DADC guide* The book goes on to explain how the delta Ps is removed to arrive at a more accurate airspeed. The Ps, whether obtained from the static port(s) on the probe or flush mounted ports on the fuselage, is fed through another fitting on the DADC (labeled static) and is something else entirely. It does factor in to the math. JK |
#78
![]() "Steve R." wrote in message ... "Ralph Nesbitt" wrote in message y.com... Lockheed has used some version/model of the Allison T-56 since "1956" on all C-130 models. Yes it is called a Allison T-56 because it was a "56 model Allison Turbine Engine". The same year the C-130 first flew at/from Marietta, Ga. There have been numerous improvements made to this basic engine design over the years to incorporate new technology, increase power, etc., but the basic design remains the same. The "T 56-15 Model Allison Engine" referred to by Phil, means a Allison T-56 engine incorporating the 15 th update. Check the model # of the Allison T-56 engine used on the C-130J. If you do a little checking, you will find the T-56-15 engine was used on late C130 E & G models. Tarver you claim to be an "Electrical Engineer". Don't you know better than to argue with a person quoting the manual on a given/specified item? Apparently not. Ralph Nesbitt Professional FD/CFR/ARFF Type Actually, the J has the AE2100D3 engine. The T56 production line was shut down shortly after the J went into production. Steve R. You are correct. The AE2100D3 engine looks similar to the T-56 series, unless you see them size by side on an engine stand sans prop. The AE2100D3 makes the T-56 engine look like a "Baby" size wise. Thanks for helping Tarver out. I was waiting for his reaction. Ralph Nesbitt Professional FD/CFR/ARFF Type |
#80
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Hercules Engines | Tarver Engineering | Home Built | 0 | January 19th 04 11:05 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
