Does anyone have a means to trace to t least a general location the
following IP address? 72.191.163.46 Many thanks -- Dudley Henriques |
Dudley Henriques wrote:
Does anyone have a means to trace to t least a general location the following IP address? 72.191.163.46 Many thanks Probably somewhere in Texas - possibly Houston area (could be way out in the countryside though). Obviously can't be sure. It's an IP address belonging to RoadRunner, according to the DNS authority section. The reverse DNS lookup yields the name: cpe-72-191-163-46.elp.res.rr.com Traceroute from my location a few moments ago terminated at: gig0-1.elpstxh5-ubr2.elp.rr.com The traceroute went through what appears to be a router in the Dallas area and then possibly in Houston, based on guesses from probable host name conventions used by RR. Maybe someone with better tools and info can provide more accurate info. What makes you interested, if I may ask? |
Jim Logajan wrote:
Dudley Henriques wrote: Does anyone have a means to trace to t least a general location the following IP address? 72.191.163.46 Many thanks Probably somewhere in Texas - possibly Houston area (could be way out in the countryside though). Obviously can't be sure. It's an IP address belonging to RoadRunner, according to the DNS authority section. The reverse DNS lookup yields the name: cpe-72-191-163-46.elp.res.rr.com Traceroute from my location a few moments ago terminated at: gig0-1.elpstxh5-ubr2.elp.rr.com The traceroute went through what appears to be a router in the Dallas area and then possibly in Houston, based on guesses from probable host name conventions used by RR. Maybe someone with better tools and info can provide more accurate info. What makes you interested, if I may ask? Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. After I posted I found the Network Utility with a Ping and Traceroute Tab, so I just got the same data you did. Looks like Texas. Reason is nothing sinister really; curiosity about a Usenet prankster. :-) -- Dudley Henriques |
Dudley Henriques schrieb:
Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. Fire up Terminal.app and you'll a much more powerful tool: a Unix prompt. ;-) |
On 2008-04-24, Dudley Henriques wrote:
cpe-72-191-163-46.elp.res.rr.com elp == El Paso. Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. No, but you do have a Unix command line: it's in Applications/Utilities/ Terminal. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June) |
![]() I'm on a Mac and I don't have a DOS prompt. If you're using OS-X you've got something much, much better than a "DOS" prompt. You've got a proper UNIX shell! |
On Apr 24, 6:06*pm, Dudley Henriques wrote:
Jim Logajan wrote: Dudley Henriques wrote: Does anyone have a means to trace to t least a general location the following IP address? 72.191.163.46 Many thanks Probably somewhere in Texas - possibly Houston area (could be way out in the countryside though). Obviously can't be sure. It's an IP address belonging to RoadRunner, according to the DNS authority section. The reverse DNS lookup yields the name: cpe-72-191-163-46.elp.res.rr.com Traceroute from my location a few moments ago terminated at: gig0-1.elpstxh5-ubr2.elp.rr.com The traceroute went through what appears to be a router in the Dallas area and then possibly in Houston, based on guesses from probable host name conventions used by RR. Maybe someone with better tools and info can provide more accurate info. What makes you interested, if I may ask? Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. Use terminal and all the rich tools of UNIX are at you disposal. Cheers |
Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. uhh .. oohh. then use the shell that came with your OS (terminal). #m |
Martin Hotze wrote:
Dudley Henriques schrieb: Thanks for the feedback. I'm on a Mac and I don't have a DOS prompt. uhh .. oohh. then use the shell that came with your OS (terminal). #m Found it. Getting used to a new OS after switching from a PC :-) -- Dudley Henriques |
Does anyone have a means to trace to t least a general location the following IP address? 72.191.163.46 Many thanks Thanks everybody who answered . I have it sorted out. -- Dudley Henriques |
"British trace missile in copter strike to Iran" | Mike[_7_] | Naval Aviation | 8 | March 10th 07 08:20 PM |
Convert StrePla trace to IGC without StrePla? | Jeremy Zawodny | Soaring | 5 | January 11th 07 04:20 PM |
Pegasus/TRACE Launch Photos Posted | Brian Webb | Military Aviation | 0 | February 21st 04 03:50 PM |
Web address for TEAM??? | DL152279546231 | Home Built | 4 | January 14th 04 04:53 PM |
Trace files for Minden, NV area in IGC WSViewer format | Jerome Conners | Soaring | 1 | December 2nd 03 04:55 PM |
