What having a sky marshal really means
Old January 8th 04, 02:33 AM
Steven P. McNicoll
"Jack Davis" wrote in message
news
Steve, the difficulty only arises when people who know absolutely
nothing about airline flying try to pass themselves off as experts.
So what caused the difficulty this time?
  #82
Old January 8th 04, 02:40 AM
Steven P. McNicoll
"Geoffrey Barnes" wrote in message
link.net...
I'm guessing that the pressure differential at ground level isn't enough
to
prevent the exits from opening, but that this differential is (logically)
much higher at altitude, and thus would prevent the exits from opening in
flight. But I could be wrong.
The pressure differential wouldn't have to be that great to create a
considerable force holding the exit in place. I don't know what the surface
area of an exit is, but a square twenty inches on a side has an area of 400
square inches. It would take 200 pounds of force to overcome a 1/2 psi
pressure differential.
  #83
Old January 8th 04, 01:48 PM
Jack Davis
On Thu, 08 Jan 2004 02:32:46 GMT, "Steven P. McNicoll"
It appears I've stumped you as well.
Not quite. Here's a hint for you: When a Captain decides to evacuate
the jet the crew completes the Evacuation check list. At the
completion of that check list the engines and APU are shut down.
Got it figured out yet?
-J
Jack Davis
B-737
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
  #84
Old January 8th 04, 01:49 PM
Jack Davis
On Thu, 08 Jan 2004 02:33:36 GMT, "Steven P. McNicoll"
news
You.
-J
Jack Davis
B-737
  #85
Old January 8th 04, 02:08 PM
Robert Moore
So, just how would the emergency exits get opened when the aircraft is
on the ground and needs to be evacuated, if the cabin pressure is
significantly higher than the outside pressure?
I'm sure that every aircraft has some differences, but the Boeing B-707
and B-727 that I flew worked as follows:
It is desireable to have "some" pressurization differential at takeoff
for passenger comfort. This prevents the outflow valves from slamming
shut at liftoff with the engines at takeoff thrust causing a discomforting
pressure "bump". For obvious reasons, it is also desireable to have the
cabin de-pressurize after landing.
To accomplish these two goals, the pressurization controller has a switch
labeled "takeoff" and "landing". Normally left in the "landing" position,
the outflow valves are electrically driven open. Just before takeoff, the
switch is placed in the "takeoff" position and the automatic features of
the controller closes the valves somewhat to cause no more than a .125 psi
differential. This pressure limit is an FAA aircraft certification limit
and is sometimes stated as "no more than 250 ft below field elevation". The
reason for the limit is obvious....to permit an emergency evacuation.
Sometime during flight, the controller switch is placed in the landing mode
and upon touchdown, the "squat switch" on the landing gear signals the
controller to open the outflow valves.
At a maximum of .125 psi differential, the air load on an average emergency
exit would be less than 100 lbs.
Bob Moore
ATP B-707 B-727
PanAm (retired)
  #86
Old January 8th 04, 03:50 PM
Wdtabor
In article k.net, "Steven
P. McNicoll" writes:
Do the sky marshals guard every emergency exit? What would happen if a
terrorist opened and emergency hatch at 36,000 ft? Can they be opened at
all
when the plane is at altitude?
Well, if they can be opened at altitude, the terrorist would be the first to
depart. So what would his purpose be in opening one?
Not only that, but if he can open it at altitude, then he is Superman and
you're going to lose anyway.
Don
Wm. Donald (Don) Tabor Jr., DDS
PP-ASEL
Chesapeake, VA - CPK, PVG
  #87
Old January 8th 04, 06:06 PM
Steven P. McNicoll
Thanks for the tip - I'll try to remember that.
No charge.
Give your brain a chance, boy!
That's good advice, you should heed it yourself.
Suppose someone calls me on the
interphone and says he's a FAM and starts feeding me some BS about a
"situation"? How do I know for sure unless I've met him/her
previously?
How do you know what for sure? If the person on the phone is truly a
marshal you have a "situation". If the person is posing as a marshal do you
not also have a "situation"?
Would I be willing to risk the lives of my passengers and
crew on what could possibly be a diversion?
How is the risk increased by not knowing if the caller is truly a marshal?
How do I really know what's going on back there?
You don't. Why would you need to?
For all I know there could be six
terrorists poised at the door and I could be wasting valuable time
talking to some lying schmuck on the phone. Think about it and tell
me how you would handle the situation.
Schmuck or marshal makes no difference, if someone on the phone tells you
there's a "situation" in the cabin then there's a "situation" in the cabin.
Advise ATC that you have a "situation" and divert to the nearest suitable
field. Don't open the cockpit door for anyone, let security forces on the
ground sort out the "situation".
And, in the unlikely event that an FA has to knock someone in the head
with a fire extinguisher (present company comes to mind) because
he/she feels that another 9-11 style attack is in the works, I'd be
all kinds of ****ed-off if the FA accidentally clocked a FAM and
Abdullah is now free to take over the jet!
So what was the marshal doing that caused the FA to believe he was about to
initiate another 9/11 style attack?
  #88
Old January 8th 04, 06:18 PM
Steven P. McNicoll
"Richard Riley" wrote in message
If you're really interested I'll be happy to tell you. But it seems
like you're just looking for an argument. So I'll end it here.
Tell me.
  #89
Old January 8th 04, 06:44 PM
Jack Davis
On Thu, 08 Jan 2004 18:06:33 GMT, "Steven P. McNicoll"
Oh, I get it now. We'll talk again when you get some PIC time.
Congratulations! You just made it to the Kill file along with the
"Rockaway baby". (Is that you, Bill?)
-J
Jack Davis
B-737
  #90
Old January 8th 04, 06:51 PM
Steven P. McNicoll
No doubt I join many others there who raised questions you could not answer.
GNS 480 means no GNS 430 upgrade ? Scott Moore Instrument Flight Rules 17 September 4th 04 04:05 AM
"Comrade's casualty abroad means grim duty at home" Mike Military Aviation 0 June 1st 04 09:21 PM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Air Vice Marshal Tony Dudgeon Keith Willshaw Military Aviation 0 January 9th 04 12:43 PM
"Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? Richard Instrument Flight Rules 20 September 30th 03 02:13 PM
