#81
#82
"Richard Kaplan" wrote
So why hasn't someone developed an inexpensive, reliable turbine engine for experiental airplanes? First off, that's in process. There's already an RV-4 flying with one, and there's a company now developing them. sufficient mechanical stability, so everything moves too much. Note that the two modern aviation piston engines - the Thielert and Orenda - have abandoned that nonsense. What planes are these used in? Do you have any references about these? The Thielert is used in the new Diamond twin. The Orenda is used in certain agricultural aircraft, and is an STC'd replacement for the King Air. Well as one example I experienced a sudden catastrophic engine failure this year in my 1999 Toyota minivan. An engine cooling fan circuit malfunctioned and the engine overheated while driving in a snowstorm. I pulled over right away but nonetheless the engine block had melted and I needed a new block and new cylinders... $8000 in warranty work repairing the engine due to failure of a $125 part. You are the only person I know who has had that happen. It's extremely rare. On the other hand, I can name quite a few such situations with certified engines that happened to people I know. I've had an engine die because a little rust clogged the fuel injectors. Turns out the drain plug in the fuel servo was steel. No, it was not an illegal replacement - it was steel by design. If I were to replace it with non-rusting brass or aluminum, that would be illegal. A friend had an engine die because the drive to his dual-mag sheared. Bad metal. Another had an engine die on takeoff because the scat tube that carried the air collapsed. It was an STC'd installation. When he replaced the scat tube with aluminum, that was illegal. I could go on and on. Well can anyone do BETTER than FAA certified airplanes? Who in your mind can produce an airplane with a more reliable engine than an FAA certified engine? Any professional operation. Toyota, Honda, GM, Ford, Bombadier - ANYONE. But not some guy working in his garage. The fact that some guy working in his garage on a shoestring budget can come close should tell you what a disaster the certified engine is. Michael |
#83
Thanks... now why are separate cylinders a disaster?
Jose -- (for Email, make the obvious changes in my address) |
#84
#85
Michael wrote:
Andrew Gideon wrote Well, isn't flying a light plane on a long overwater leg dangerous behavior? Or are you suggesting it's safe? See the problem here? I see a linguistic trap. Nothing is safe but death (and I'm not even sure of that {8^). Right. That's why I don't believe that there is any such thing as a safety seminar. The only really valid safety advice it could give is to hide under the bed. I don't see this. It sounds like you're requiring that a safety seminar provide a means to achieve absolute safety. That doesn't seem reasonable. We'd call those "absolute safety seminars", I expect laugh. [...] And the point I'm trying to get across is that there is no such thing as safe. When you're flying for fun, you're taking unnecessary risks. I don't have a problem with that, obviously, but I think you should be honest about it. Flying for any purpose involves unnecessary risk. Driving involves unnecessary risk. Walking involves unnecessary risk (at least where I live, given that we can have food delivered {8^). But we don't really want to think about the risks involved in eating, do we laugh? I think we're in agreement in all areas but your definition of "safety seminar". I don't see it as necessary that one such provide absolute safety, nor do I have a problem with one describing how to increase the safety involved in performing an unnecessary act. - Andrew |
#86
![]() "Michael" wrote in message om... Why? FAA. I say again... The FAA has few limitations on experimental airplanes. Why hasn't someone developed an experimental airplane with a stellar safety record by addressing all the safety issues you mentioned which are being thrwarted by the FAA? -------------------- Richard Kaplan www.flyimc.com |
#87
#88
#89
![]() Michael wrote: Note that NONE of the new aviation engines (Orenda, Thielert, Honda, Bombadier) have separate cylinders. Just a quick look with Yahoo turned up the Morane Renault, Zoche, and Jabiru engines - all new designs with separate cylinders. I'd bet the guys going to Oshkosh will be able to provide other examples when they get back. In general, separate cylinders are advantageous for air-cooled engines and blocks are preferred for water-cooled designs, but this is not a universal rule. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
#90
![]() "Michael" wrote in message om... Note that NONE of the new aviation engines (Orenda, Thielert, Honda, Bombadier) have separate cylinders. No automotive engines do this either. In fact, ONLY obsolete aviation engines do this. So why dont' we see lots of homebuilts eliminating separate cylinders? There are some great minds in the homebuilt community and minimal FAA regulation. -------------------- Richard Kaplan www.flyimc.com |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
