CG hook on aero tows??
Old January 4th 04, 11:53 PM
Ted Wagner
Default CG hook on aero tows??
A few seconds into take-off roll today in a Pilatus B-4, while applying left stick to correct for a dipping right wing, the right wing suddenly dipped all the way into the ground. The glider lurched to the right, and a second or two later popped up into the air, a good 20 feet up and 30 or more feet out to the side. By that time I had full left rudder in addition to full left aileron, so the glider recovered rather quickly, and I was able to bring it to normal take-off position right about the time the tow plane started to climb. I was amazed he had maintained his heading directly down the runway. The winds were light and variable. It was my ninth flight on the B-4.
After landing, the tow pilot apologized, saying it was his fault -- something about the wake turbulence. But I'm still puzzled about what, if anything, he did wrong; it looked like a completely normally take-off roll to me.
I had thought that maybe a sudden tail wind had reversed the effective correction of my aileron deflection during take-off, causing the right wing to dip harder instead of leveling off. Does this make sense to anyone with more experience on an aircraft like the B-4?
Also, I'm curious to know how much the CG hook location on the B-4 contributed to the squirrelly sequence of events after the right wingtip hit the ground. How many 15+ meter gliders have CG-only hooks? Are such exciting events more commonplace with CG hooks?
Other than the wobbly tows, I'm loving the B-4, it's the first 15-meter single-seater ship I've flown, and the first with retractable gear...
~tw
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Aero Advantage closing shop. Eric Ulner Owning 51 May 17th 04 03:56 AM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
Cambridge Aero Instruments Inc. Changeover Joe McCormack Soaring 3 July 30th 03 08:45 PM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 06:20 AM
