By 2030, commercial passengers will routinely fly in pilotlessplanes.
Old October 6th 05, 04:59 AM
Morgans
As far as high jacking: I think that a pilotless plane would be more
secure. The designers could put in a code or something and make it
impossible for a hi-jacker to take control of the plane.
Of course he could still blow the damn thing up in mid-flight, but he
wouldn't be able to fly it into the WTC or such.
Never again will a terrorist be allowed to fly a plane into a high value
target. The 4th plane on 9-11 proved that.
  #82
Old October 6th 05, 12:57 PM
Neil Gould
Recently, Greg Farris posted:
says...
I see it a little differently. The contest is not between humans and
computer control a computer can fly an airplane autonomously from
point A to B. That's a ways off, considering the current state of AI.
What AI?? The scenario you've just described is thousands of times
simpler than what happens every time you turn on your computer to
check the aviation ng. Taxiing is the only element in this scenario
that is not already fully automated, and performed better by machines
than by people. We only fly today to keep ourselves in practice, in
case we "really" have to fly "someday".
I suspect that you are confusing "autonomous" with "automatic". There is
no question but that machinery can follow programmed instructions
precisely (that is at the heart of CNC), however that machinery is not
making decisions in a greatly dynamic environment. In your example, the
location of airports are fixed, and it is a relatively simple task to have
a set of instructions that would get an aircraft from one to the other;
OTOH, taxiing is a dynamic environment, requiring informational
interaction and control based on mutually agreed decisions -- i.e.
autonomy. AFAIK, today's systems are incapable of that. Weather is also a
dynamic environment, one which every aircraft must contend with on every
flight; course deviations based on developing weather also require
autonomy. How do current-day automatic systems handle that? AFAIK, they
can't.
One point of the DARPA challenge (cited earlier in this thread) is to
create autonomous vehicles capable of simply getting from point A to B in
a dynamic environment. The results speak for themselves.
Regards,
Neil
  #84
Old October 6th 05, 05:45 PM
Andre
As was pointed out earlier, I think the issue is more social then technical.
We have UAVs that are towed to a takeoff point, a computer program lauches
and later lands the vehicle and a pilot sees what the plane sees via
satilite. The flight is carried out, 99% by the program put into the UAV
before departure and the "pilot" takes over only if they see something on
the ground that makes them want to take a closer look.
The military has already started to launch hellfire missiles from UAVs
flying in Afganistan on orders from someone looking at a TV in Washington.
Before 9/11 I got to sit in the cockpit of a Dash8 from TO to YOW. In
response to changes from the tower, the pilot just entered the change into
the autopilot and it did the rest. The pilot did not take the controls until
he was about 500 AGL on approach. If the controller could just click on the
aircraft on his screen, type in the new heading or alt. and the computer
would do it that might simplify everyone's job with fewer communications
errors. You might still get a few people killed getting the bugs out of the
system, like when they sent the lander to Mars with one subroutine working
with KM/min and the other subroutine working in miles/hour.
Mind you at that point the highjacker just has to capture a control tower
and send a bunch of aircraft into the same location and doesn't get to be
with a single virgin, let alone 70.
So we should be clear on what constitutes autonomous, what parts would the
plane control and where would the pilot be who can override the computer.
The problem is that society will not accept a pilotless plane because of the
what if factor. What if the computer failed, who will reboot it, what if the
weather goes bad, etc. And the old quetion seen in all airplane disaster
movies, "who is flying the plane"?
"Greg Farris" wrote in message
says...
They do - and what they tell us is that navigating over uncharted terrain,
full of obstacles, is a challenge for land vehicles. Quite a different
challenge from taxiing across a few hundred feet of perfectly charted,
smooth pavement, custom designed to fit the particularities of your
vehicle!
If we really wanted pilotless airliners (and my argument is that we do
not,
and will not, probably ever) it will be a simple matter to eliminate the
human-controlled taxiing phase. Simply towing the aircraft would be one
way
to do it. Besides, ground operations are one of the most error-prone
phases
of aircraft operations, usually because pilots misunderstand
instructions. So this would be a good candidate for automation, even
without getting rid of the pilots.
G Faris
  #86
Old October 6th 05, 07:18 PM
Neil Gould
Recently, Andre posted:
technical. We have UAVs that are towed to a takeoff point, a computer
program lauches and later lands the vehicle and a pilot sees what the
plane sees via satilite. The flight is carried out, 99% by the
program put into the UAV before departure and the "pilot" takes over
only if they see something on the ground that makes them want to take
a closer look.
(rest snipped for brevity)
All that has happened is that the pilot is outside the cockpit. The UAVs
are *not* acting autonomously, which is a pre-requisite for _pilotless_
operation.
Neil
  #89
Old October 6th 05, 09:42 PM
Stubby
operation.
Right. The SALT II treaty forbids dropping weapons or launching
vehicles from _pilotless_ vehicles. But _remotely piloted_ vehicles do
not violate this restriction.
Power Commercial to Glider Commercial Mitty Soaring 24 March 15th 05 03:41 PM
Do You Want to Become a Commercial Helicopter Pilot? Badwater Bill Rotorcraft 7 August 22nd 04 12:00 AM
What to study for commercial written exam? Dave Piloting 0 August 9th 04 03:56 PM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Home Built 125 February 1st 04 05:57 AM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Piloting 129 February 1st 04 05:57 AM
