#81
I remember back when I was working on my Lear type (first time I had ever
flown a jet). I was given a V1 cut and, while I had the airplane under control, I was about 30 degrees off runway heading, screaming over the planes in the tiedown area at 100 feet or so. I got better after that..... Bob Gardner "Matt Barrow" wrote in message ... wrote in message ups.com... I remember a recent discussion with a pilot mate where I was mentioning how illogical a crash-shortly-after-takeoff is, given that beyond V1 takeoff can safely be continued even with just one good engine. I'd even told him that if I saw an aircraft airborne following takeoff, I'd presume it safe. Days after that tete-a-tete, a Fokker went down in Pakistan shortly after taking off. And today the Bombardier at Kentucky. Doesn't add up, does it? After all, if the engines are good and there's no bomb going off, it should be pretty hard to crash an aircraft! Getting cross-wise with a twin following an engine failure is easy if you're not "On your game". |
#82
Newps wrote:
Emily wrote: How much would a typical light twin pitch up on takeoff with the trim set like that? I know myself, I usually ended up trimming down on climb because the nose was hard to hold down (although I never flew the 76) Then you started with too much nose up trim on takeoff. I think I'm just wimpy, actually. I trim up in the flare, because it's the only way I can land one-handed. Every plane is different. Go out and try it yourself with whatever you fly. Go up to altitude and slow down as much as possiblein a takeoff configuration, then roll in full nose up trim and go to full power. It'll get your attention but you'll have no problem. Unless an engine goes out...but I'll probably try it next time I'm up. |
#83
Emily wrote:
Gene Seibel wrote: Fatalities Accidents/hull loss Takeoff 27% 17% Landing 15% 52% Thus there is a much lower risk of getting into an accident on takeoff, but takeoff accidents result in a higher rate of fatalities. Though my two accidents followed landings, there have been a couple takeoffs that scared me far more than any landings. Same here. I can't think offhand of any landings were I thought I might crash, but I vividly remember almost taking out the localizer antenna on takeoff once. You pull the yoke back to take-off. :-) Matt |
#84
Emily wrote:
Newps wrote: Emily wrote: How much would a typical light twin pitch up on takeoff with the trim set like that? I know myself, I usually ended up trimming down on climb because the nose was hard to hold down (although I never flew the 76) Then you started with too much nose up trim on takeoff. I think I'm just wimpy, actually. I trim up in the flare, because it's the only way I can land one-handed. What do you fly? The largest airplane I've landed outside of a simulator is a 182. It was easy to flare with one hand. Might want to hit the weight room a little more often. :-) Matt |
#85
Judah wrote:
Matt Whiting wrote in : If the tower cleared the airplane to the correct runway and the pilots taxied to a different one, how does the tower share in this blame? On what basis are you assuming that he was cleared to the correct runway? Doesn't matter. It is up to us as pilots to be familiar with all available information prior to our flight. That includes the length of runway required for takeoff and the lengths of the runways at the airports we are using. Matt |
#86
Judah wrote:
"Steven P. McNicoll" wrote in nk.net: "Judah" wrote in message 8... Matt Whiting wrote in : If the tower cleared the airplane to the correct runway and the pilots taxied to a different one, how does the tower share in this blame? On what basis are you assuming that he was cleared to the correct runway? He's not. He said IF the tower cleared the airplane to the correct runway. I read the inflection of the "If" as a statement of presumption, not as the subject of the query. But you're right - I could have misread the intent. I was speculating that the clearance was correct, but even if it wasn't, I make the same assertion - it is the pilots' fault if they took off on a runway too short for their operating conditions. What part of PIC don't you understand? Matt |
#87
Bob Gardner wrote:
You and I both know that the final decision is the pilot's...but we live in a world where the media wants sensation and the legal system wants to assign blame. When the lawsuits finally hit the courts (and there will be lawsuits, count on it), the prosecutors will look in every nook and cranny for someone to pin it on...and the tower will be in their sights along with others. Yes, Bob, I'm all too aware of the likely legal outcome, but that doesn't make it right. Matt |
#88
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message ... Well, that would also be a mistake as that isn't the proper reference for the DG. Perhaps, but it's one that many use and it works quite well if you know the magnetic azimuth of the runway. It works well if you know what runway you are on. However, a runway can be quite a ways off the magnetic azimuth before it gets renumbered so you could easily be 5 degrees off on your DG setting. Matt |
#89
Emily wrote:
Steven P. McNicoll wrote: "Matt Whiting" wrote in message ... I can certainly see how one could taxi to the wrong runway and even line up on it. But taking off on it is inexcusable. One of the last checks I was taught to make before firewalling the throttle is to check that the heading of the airplane matches the runway to which I was cleared for takeoff. It takes less than two seconds to make this check and it will catch this error every time. Perhaps they did, and when they found the 40 degree error they reset the gyro to correct the discrepancy. Speaking for myself, if I get on a runway and see an error that large, I check to see if something else has been wrong. Especially if I'm IFR, I don't want a 40 degree error on my DG. That being said, I almost took off on the wrong runway once, and figured it out before I did. It does happen, probably more than the public realizes. I landed on the wrong runway at Reading, PA early in my flying career. I was cleared for a right downwind to R36 and hadn't made many right traffic patterns before. I wasn't paying sufficient attention and ended up lining up on 31 and didn't cross-check the DG as I should have. I noticed the error at almost the same time the controller did, but traffic wasn't a factor so he just came on quickly and said something like "it appears you are lined up for 31 rather than 36, cleared to land 31." I definitely understand how this can happen which is one reason I'm much more careful now about cross-checking with the compass and DG, especially when flying IFR. Matt |
#90
![]() Bob Gardner wrote: You and I both know that the final decision is the pilot's...but we live in a world where the media wants sensation and the legal system wants to assign blame. When the lawsuits finally hit the courts (and there will be lawsuits, count on it), the prosecutors will look in every nook and cranny for someone to pin it on...and the tower will be in their sights along with others. They won't be prosecuters, they will be the scum sucking trial lawyers and they will be looking for money. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Approaches and takeoff mins. | jamin3508 | Instrument Flight Rules | 22 | September 14th 05 02:51 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 3rd 03 11:53 PM |
