Hawker vs. Glider Midair - with photo!
Old August 31st 06, 10:33 PM posted to rec.aviation.piloting,rec.aviation.soaring
Jim Logajan
Default Hawker vs. Glider Midair - with photo!
Graeme Cant gcantinter@tnodedotnet wrote:
Like when I hit another car from behind, prima facie it's my fault.
I'd bet that is no longer the case. There is an insurance fraud tactic
where the perps deliberately cause rear-end accidents by pulling in front
of an innocent driver's vehicle and slams on the brakes. See for example:
http://personalinsure.about.com/cs/v.../aa062203a.htm
  #82
Old August 31st 06, 10:36 PM posted to rec.aviation.piloting,rec.aviation.soaring
Discus 44
There have been many photos of the Jet. While this is remarable, are
there any photos of the remains of the glider? It might shed some
light on where the jet ran into the glider. Anyone with common sense
can see the Jet hit the glider and not the other way around as so many
so called :"journalists" have intimated. It is strange that so many
unknowledgeable people seem to be arm chair experts about this.
I would liek to see FLARM adopted here. It may be a better way than
having Xponders and ATC involved with soaring.
  #83
Old August 31st 06, 11:29 PM posted to rec.aviation.piloting
Jay Beckman
"Dave S" wrote in message
news
Newps wrote:
Stefan wrote:
It was meant to be an indirect answer to Kingfish who asked what a
glider did up there.
He glid.
The glider pilot glid..
The Hawker pilot (and passengers) shat...
No doubt...
  #84
Old August 31st 06, 11:51 PM posted to rec.aviation.piloting,rec.aviation.soaring
Jack[_1_]
Ron Natalie wrote:
Larry Dighera wrote:
Because it is my understanding that federal regulations grant gliders
right-of-way over powered aircraft.
Because your understanding is incorrect and not supported by the
construction of the regulation. The only part of the rules that
mention category is one that begins with "Converging other than
head on or nearly so."
It's possible that the glider had the right of way, it's also
possible that he didn't.
In either case, there was DEFINITELY A FAILURE TO SEE (and avoid)
as the jet pilot never saw the glider according to reports (and
I suspect the glider pilot never saw the jet) so the right of
way rules don't seem to have mattered because unless there you
know the other guy is there there's not going to be any manouvering
rules to apply.
You will invariably provoke an argument by making that statement, and
the argument will continue ad infinitum, even after all parties to it
have read and reread the applicable FAR -- though most of your opponents
will understand why you make your claim.
The FAR's are written no more comprehensibly than is the norm for the
Law, from the Constitution down to the lowest traffic regulation.
91.113.(d), even within the full context of 91.113, is just one example
among multitudes. Recent FAR's actually seem to be more poorly written
than those which have been in force for some time, indicating the
problem is no more appreciated by those in charge of writing them today
than ever it was, or we have simply gotten stupider.
If you would care to cite some specific rulings that support your claim,
that would carry some weight. If we go on about it here without such
citations, at the end of 10,000 lines of rant we'll be right back at
this very same spot.
Jack
Sec. 91.113
http://tinyurl.com/loggu
Right-of-way rules: Except water operations.
(a) Inapplicability. This section does not apply to the operation of an
aircraft on water.
(b) General. When weather conditions permit, regardless of whether an
operation is conducted under instrument flight rules or visual flight
rules, vigilance shall be maintained by each person operating an
aircraft so as to see and avoid other aircraft. When a rule of this
section gives another aircraft the right-of-way, the pilot shall give
way to that aircraft and may not pass over, under, or ahead of it unless
well clear.
(c) In distress. An aircraft in distress has the right-of-way over all
other air traffic.
(d) Converging. When aircraft of the same category are converging at
approximately the same altitude (except head-on, or nearly so), the
aircraft to the other's right has the right-of-way. If the aircraft are
of different categories--
(1) A balloon has the right-of-way over any other category of aircraft;
(2) A glider has the right-of-way over an airship, powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute,
However, an aircraft towing or refueling other aircraft has the
right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter course to
the right.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter course
to the right to pass well clear.
(g) Landing. Aircraft, while on final approach to land or while landing,
have the right-of-way over other aircraft in flight or operating on the
surface, except that they shall not take advantage of this rule to force
an aircraft off the runway surface which has already landed and is
attempting to
make way for an aircraft on final approach. When two or more aircraft
are approaching an airport for the purpose of landing, the aircraft at
the lower altitude has the right-of-way, but it shall not take advantage
of this rule to cut in front of another which is on final approach to
land or to overtake
that aircraft.
  #85
Old August 31st 06, 11:57 PM posted to rec.aviation.piloting,rec.aviation.soaring
Morgans[_4_]
"Discus 44" wrote in message
ps.com...
FLARM???
  #86
Old September 1st 06, 12:02 AM posted to rec.aviation.piloting,rec.aviation.soaring
Jack[_1_]
Aluckyguess wrote:
If the glider came in from the side how would
the Hawker see him[?]
At a 3-4x speed differential the glider cannot "come in from the side".
Nonetheless, there are side windows -- even in Hawkers.
Does the dog crossing the freeway at 15 mph run into the grill of the
semi which is cruising at 55? I think not.
When you are the hood ornament you'll have a different view of things,
whether that chrome greyhound is sticking in your ear or your arse.
Jack
  #87
Old September 1st 06, 12:16 AM posted to rec.aviation.piloting,rec.aviation.soaring
Ron Natalie
5Z wrote:
Ron Natalie wrote:
There is NO SUCH RULE.
FAR 91.113
http://www.airweb.faa.gov/Regulatory...C?OpenDocument
[(2) A glider has the right-of-way over an airship, powered parachute,
weight-shift-control aircraft, airplane, or rotorcraft.]
THat clause applies only when coverging other than head-on or nearly so.
Head-on (or nearly so) or overtaking operations has rules that are not
affected by aircraft category.
  #88
Old September 1st 06, 12:19 AM posted to rec.aviation.piloting,rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
Default Hawker vs. Glider Midair - with photo! - Flarm.
Flarm http://www.flarm.com ,
or OzFlarm http://www.rf-developments.com ,
or perhaps LX Flarm http://www.lxnavigation.si/avionics/products.cfm .
On OzFlarm see
http://www.users.bigpond.com/keepits...g/OzFLARM1.pdf .
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Morgans" wrote in message
ps.com...
There have been many photos of the Jet. While this is remarkable, are
I would like to see FLARM adopted here. It may be a better way than
FLARM???
  #89
Old September 1st 06, 12:26 AM posted to rec.aviation.piloting,rec.aviation.soaring
5Z
But we are talking about airplanes running over gliders. That will
most likely be a non headon situation, and in that case the airplane
shall avoid the glider. Of course, that's just like saying the
pedestrian has right of way in a crosswalk - some dopes think that
stepping out in front of a car will somehow magically make 1) the
driver notice them, 2) allow the driver to stop in time.
-Tom
  #90
Old September 1st 06, 12:48 AM posted to rec.aviation.piloting,rec.aviation.soaring
Aluckyguess[_1_]
"5Z" wrote in message
FAR 91.113
As long as the glider doesnt pull out in front of the other aircraft.
There are no absolutes.
If you are going the speed limit in a car and someone runs out in front of
you its not always your fault.
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Cloud Flying Shawn Knickerbocker Soaring 48 August 30th 06 07:21 AM
Refinish a Glider in Europe Jim Culp Soaring 0 November 18th 05 04:00 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
