NYC's East River is about 2000' wide. So when you approach the north
endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). Suppose you're afraid to fly too slowly because you don't want to stall during the turn, so you cruise up the river at 90 knots. Suppose you're afraid to bank too steeply because you don't want to stall during the turn, so you use just a 30-degree bank. Oops: your turning radius is about 1200'. Using the East River VFR corridor requires planning the turn carefully--especially since you need to leave an extra margin in case you have to dodge high-density traffic there. --Gary |
Gary Drescher wrote:
NYC's East River is about 2000' wide. So when you approach the north endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). I have flown the Hudson River VFR corridor several times, but only flew the East River corridor once. My impression at the time was that a very tight turn is required to go back south to exit this corridor. -- Peter |
![]() "Gary Drescher" wrote in message . .. NYC's East River is about 2000' wide. So when you approach the north endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). Suppose you're afraid to fly too slowly because you don't want to stall during the turn, so you cruise up the river at 90 knots. Suppose you're afraid to bank too steeply because you don't want to stall during the turn, so you use just a 30-degree bank. Oops: your turning radius is about 1200'. Using the East River VFR corridor requires planning the turn carefully--especially since you need to leave an extra margin in case you have to dodge high-density traffic there. only have to increase bank to 36 degrees to get under 1000' radius ( or slow to 81 kts) or go half way and 33 degrees bank and 85 kts. shouldnt be a problem in a 172 ( isnt that what you fly?) stall speed would still only be 55 kts. ( assuming 50 kts strait and level from memory) terry --Gary |
"d&tm" wrote in message
... "Gary Drescher" wrote in message . .. NYC's East River is about 2000' wide. So when you approach the north endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). Suppose you're afraid to fly too slowly because you don't want to stall during the turn, so you cruise up the river at 90 knots. Suppose you're afraid to bank too steeply because you don't want to stall during the turn, so you use just a 30-degree bank. Oops: your turning radius is about 1200'. Using the East River VFR corridor requires planning the turn carefully--especially since you need to leave an extra margin in case you have to dodge high-density traffic there. only have to increase bank to 36 degrees to get under 1000' radius ( or slow to 81 kts) or go half way and 33 degrees bank and 85 kts. shouldnt be a problem in a 172 ( isnt that what you fly?) stall speed would still only be 55 kts. ( assuming 50 kts strait and level from memory) terry Yup, I fly 172s and Arrows. But the folks in the news were in a Cirrus. In any case, the turn can certainly be executed--my point is just that the situation is unusual (outside of mountain flying) for the degree of planning that's required in order to make the turn safely. --Gary |
I think that any pilot with the fears that you describe should go up with an
instructor and explore the low-speed end of the operating envelope until he or she is comfortable. "Fear" of stalling is based on lack of knowledge or experience, and I know from reading your posts that you do not fit into either category. Bob Gardner "Gary Drescher" wrote in message . .. NYC's East River is about 2000' wide. So when you approach the north endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). Suppose you're afraid to fly too slowly because you don't want to stall during the turn, so you cruise up the river at 90 knots. Suppose you're afraid to bank too steeply because you don't want to stall during the turn, so you use just a 30-degree bank. Oops: your turning radius is about 1200'. Using the East River VFR corridor requires planning the turn carefully--especially since you need to leave an extra margin in case you have to dodge high-density traffic there. --Gary |
NYC's East River is about 2000' wide. So when you approach the north endpoint of the VFR corridor there, you need to make a U turn with a 1000' radius (or less if you're not right next to the eastern shore when you start the turn). Suppose you're afraid to fly too slowly because you don't want to stall during the turn, so you cruise up the river at 90 knots. Suppose you're afraid to bank too steeply because you don't want to stall during the turn, so you use just a 30-degree bank. Oops: your turning radius is about 1200'. Using the East River VFR corridor requires planning the turn carefully--especially since you need to leave an extra margin in case you have to dodge high-density traffic there. --Gary In occasions like these I was trained to do a chandelle. Immelman turn will also do ;-) |
"Stefano" wrote in message
.. . In occasions like these I was trained to do a chandelle. Immelman turn will also do ;-) Except that you're probably already close to the 1100' ceiling in this case. ![]() --Gary |
Recently, Stefano posted:
Gary Drescher wrote: Oops: your turning radius is about 1200'. In occasions like these I was trained to do a chandelle. Immelman turn will also do ;-) Wow. You can do an Immelman in under 500'? Impressive! Neil |
![]() "Neil Gould" wrote Wow. You can do an Immelman in under 500'? Impressive! How about a baby hammerhead turn, with a half roll coming out of it? g -- Jim in NC |
"Morgans" wrote in message
... "Neil Gould" wrote Wow. You can do an Immelman in under 500'? Impressive! How about a baby hammerhead turn, with a half roll coming out of it? g -- Jim in NC Presuming that no one is immediately on top of you, somethng akin to a duster turn works quite well and only uses about 50 feet to make a really dramatic difference in the turn radius. I used to do that to turn around a Tomohawk (PA-38) in a small radius. Peter |
Second Helicopter Crash into the East River | Bob Chilcoat | Piloting | 2 | June 21st 05 08:50 AM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Naval Aviation | 0 | April 7th 04 07:31 PM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
