I understand that one normally turns on beacons or anticollision
lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: I understand that one normally turns on beacons or anticollision lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom? Hmmm. Do you turn on your virtual strobe before you start your virtual engine, so as not to endanger anyone with your virtual prop? |
Kingfish wrote:
Mxsmanic wrote: I understand that one normally turns on beacons or anticollision lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom? Hmmm. Do you turn on your virtual strobe before you start your virtual engine, so as not to endanger anyone with your virtual prop? Can't he just read the regulations? He's obviously got access to internet. § 91.209 Aircraft lights. No person may: (a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)— (1) Operate an aircraft unless it has lighted position lights; (2) Park or move an aircraft in, or in dangerous proximity to, a night flight operations area of an airport unless the aircraft— (i) Is clearly illuminated; (ii) Has lighted position lights; or (iii) is in an area that is marked by obstruction lights; (3) Anchor an aircraft unless the aircraft— (i) Has lighted anchor lights; or (ii) Is in an area where anchor lights are not required on vessels; or (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. |
Emily writes:
Can't he just read the regulations? He's obviously got access to internet. § 91.209 Aircraft lights. No person may: (a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)— (1) Operate an aircraft unless it has lighted position lights; (2) Park or move an aircraft in, or in dangerous proximity to, a night flight operations area of an airport unless the aircraft— (i) Is clearly illuminated; (ii) Has lighted position lights; or (iii) is in an area that is marked by obstruction lights; (3) Anchor an aircraft unless the aircraft— (i) Has lighted anchor lights; or (ii) Is in an area where anchor lights are not required on vessels; or (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Mxsmanic posted:
Emily writes: Can't he just read the regulations? He's obviously got access to internet. § 91.209 Aircraft lights. No person may: (a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)- (1) Operate an aircraft unless it has lighted position lights; (2) Park or move an aircraft in, or in dangerous proximity to, a night flight operations area of an airport unless the aircraft- (i) Is clearly illuminated; (ii) Has lighted position lights; or (iii) is in an area that is marked by obstruction lights; (3) Anchor an aircraft unless the aircraft- (i) Has lighted anchor lights; or (ii) Is in an area where anchor lights are not required on vessels; or (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. Then, go read the rest of the regs to discover what "Operate and aircraft..." means. Neil |
Neil Gould wrote:
Recently, Mxsmanic posted: Emily writes: Can't he just read the regulations? He's obviously got access to internet. § 91.209 Aircraft lights. No person may: (a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)- (1) Operate an aircraft unless it has lighted position lights; (2) Park or move an aircraft in, or in dangerous proximity to, a night flight operations area of an airport unless the aircraft- (i) Is clearly illuminated; (ii) Has lighted position lights; or (iii) is in an area that is marked by obstruction lights; (3) Anchor an aircraft unless the aircraft- (i) Has lighted anchor lights; or (ii) Is in an area where anchor lights are not required on vessels; or (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. Then, go read the rest of the regs to discover what "Operate and aircraft..." means. No good deed, it appears.... |
Mxsmanic wrote:
Nothing in this quoted section mentions engines, so it doesn't answer my question. Those are the regulations. As it doesn't mention engines, there is no requirement having anything to do with engines. Many people put the beacon on when the master (not the engine) is turned on. I used to do that as well (it's also a good reminder that your master is on after you get out of the plane). However, I only have strobes now, and I don't run those until I'm on the runway now. |
Ron Natalie writes:
Those are the regulations. As it doesn't mention engines, there is no requirement having anything to do with engines. OK, thanks. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Sat, 14 Oct 2006 15:34:12 +0200, Mxsmanic
wrote: Emily writes: Can't he just read the regulations? He's obviously got access to internet. ... (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. Yes it does. In the excerpt here, "Operate" means running the engines. That means all conditions, day or night, except for the exclusion. That's also mentioned in section 3 of the AIM, "Airport Operations." In that section, they mention the risk from jet/prop blast. I've read other FAA articles that discuss the risk of propeller accidents, which might be prevented with lighted anti-collision lights. A spinning propeller may not be immediately evident to someone walking across the ramp. Walking into a propeller can not only cause serious injury or death, but even worse, may require an expensive engine teardown to inspect for damage. Any measure that helps prevent that can only be a good thing. RK Henry |
RK Henry writes:
Yes it does. In the excerpt here, "Operate" means running the engines. According to whom? -- Transpose mxsmanic and gmail to reach me by e-mail. |
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
Landing lights | Robert Barker | Owning | 20 | May 11th 06 02:33 AM |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 05:18 AM |
