Steering on the taxiway
Old November 25th 06, 02:59 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Steering on the taxiway
Is it better to use just the rudder or differential braking to turn on
taxiways? I understand that steering mechanisms vary considerably
from one aircraft to another, but I'm still curious. In this case,
I'm wondering about a Baron 58, the aircraft I fly in my sim (most of
the time).
I note when taxiing that the aircraft seems to oversteer, especially
as speed increases. That is, I'll move the rudder to straighten out
on the centerline of the taxiway, but the aircraft still continues to
drift slightly in the turn and overshoots the centerline. Is this the
way the real aircraft works? If so, what causes it? I should think
that if the rudder pedals turn the nose wheel directly, it would be
hard to overshoot unless the nose wheel actually skids or something
(?). This isn't happening at high speed, it's like 16 knots or so (or
does that count as high taxiway speed?).
Old November 25th 06, 03:25 AM posted to rec.aviation.piloting,rec.aviation.student
john smith
taxiways?
The Baron is a twin, you also have differential power.
Old November 25th 06, 05:05 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
john smith writes:
Is it practical/desirable to use it for steering?
Unfortunately it is very awkward to adjust the throttles separately in
a sim, so I've never tried this type of steering.
Old November 25th 06, 03:09 PM posted to rec.aviation.piloting,rec.aviation.student
john smith
Mxsmanic wrote:
john smith writes:
Depending on the size of the aircraft and the engines, only small
increases/decreases (+/- 100 rpm) in power are necessary if applied at
the correct times.
Old November 26th 06, 12:36 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
the correct times.
So why are you trying to tell him how to fly a simulator?
I don't get it.
Old November 26th 06, 03:14 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Dohm
Yes, it is.
Hmmm. Let me guess ... you don't have a full throttle quadrant in addition
to your yoke and rudder pedals (hopefully with brakes).
Without all of that/those, I don't see how you hope to simulate any
particular type of aircraft.
Old November 26th 06, 05:06 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Peter Dohm writes:
Just a single throttle. The occasions where I might need separate
throttle controls are so rare that they don't justify the expense of a
full dual set of throttles. For things like single-engine failures, I
pause the sim to reset throttles or feather props or whatever.
Old November 26th 06, 12:43 PM posted to rec.aviation.piloting,rec.aviation.student
Peter Dohm
Perhaps, since you are not really using it as a simulation in preparation
for a flight. OTOH, you found one.
Thus simulating nothing.
Old November 26th 06, 06:10 AM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Using a game, I don't see how he can hope to accurately simulate anything, other
than entertainment.
Old November 25th 06, 03:22 AM posted to rec.aviation.piloting,rec.aviation.student
G. Sylvester
Mxsmanic wrote:
I should think
It's actually 18 TAS, not IAS, that is correct.
One Known Fatality In OSH Taxiway Accident AJ Piloting 0 July 31st 06 04:03 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
tailwheel steering Marvin Barnard Home Built 7 February 1st 04 10:30 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
