#81
#82
#84
On Sat, 22 Jan 2005 06:11:42 GMT, "Gene Whitt"
wrote: MY Bad, Mixed up two different flights and situations. One was SVFR from the Spreckles Sugar plant and Monterey with 400' ceiling. whet we went in SVFR Other was Contact where we had to change runways to maintain cloud clearance. Gene SVFR with a 400' ceiling? Is that legal? |
#85
![]() wrote in message ... SVFR with a 400' ceiling? Is that legal? By itself, yes. But extended flight under a solid 400' ceiling will likely require a violation of FAR 91.119 |
#86
#87
![]() "Steven P. McNicoll" wrote: wrote in message ... I'd say it should read "any short-cut without a revised clearance or a cancellation is a legal no-no." But, ATC is not authorized to issue an initial or revised clearance to short-cut any required segment of an instrument approach procedure except for radar vectors provided in accordance with 7110.65P, 5-9-1. If in VMC the pilot can cancel IFR and discontinue the SIAP. If conditions permit a contact approach the pilot can request one, receive a revised clearance, and discontinue the SIAP. Read me previous messages: I said that contacts, visuals, and cancellations were the only exceptions to a full approach (or 7110.65, 5-9-1 vectors to final). |
#88
![]() wrote: On Sat, 22 Jan 2005 02:14:22 -0800, wrote: wrote: On Tue, 18 Jan 2005 20:48:17 -0800, Ron Garret wrote: Simple, but illegal. You can only descend below minimums once you have the field in sight AND you're on the final approach segment (and, if you really want to pick nits, have reached DH or MDA) Actually, you need the runway environment in sight. And I would find it interesting to know how one descends below the DA or MDA without first reaching them. One of the enforcement charges against the fired NWA crew that landed at the USAF base in Rapid City, SD, when they were cleared for a VOR approach to the civil airport was just that. And, the visibility was severe VMC. Just what? No runway in sight? I haven't seen the case, but that would be the "umbrella" charge, plus descending before being a position to make a normal descent. |
#89
![]() "Steven P. McNicoll" wrote: wrote in message ... True, provided you cancel, or receive a clearance for a contact or visual approach. Otherwise you must fly the IAP regardless of how good the weather might be (VMC, not VFR). A visual approach is not an option when an instrument letdown is necessary. Depends on how you define "when necessary," Steve. The FAA postion is that "when necessary" is when the pilot is on an IFR flight plan and has not received a clearance for a visual or contact, regardless of weather conditions. It's in the AIM that I cited to someone else here. |
#90
![]() wrote: On Sat, 22 Jan 2005 02:08:12 -0800, wrote: Paul Tomblin wrote: In a previous article, said: On Mon, 17 Jan 2005 23:45:57 -0700, Newps wrote: wrote: Once a clearance for an approach is issued, the pilot is bound by the appropriate segments of the approach (Part 97) and the applicable parts of 91.175. Any "short cut" with either a contact, visual, or cancellation is a ^^^^^^^^^^^^ legal no-no. Baloney. Once I'm in a position to fly visually to the airport/runway I can do just that. that's not what this says, I don't think: (a) Instrument approaches to civil airports. Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter. I don't see anything there that prohibits you from cancelling IFR when you have sufficient visibility and cloud clearance to operate under VFR. You can cancel when the reported ground visibility and your observed flight visibility permit. Then, none of 91.175 has any application from that point on. (you can't cancel in Class A airspace but that has no application to 91.175 in any case.) You can cancel any time you are operating in VFR conditions. Ground visibility may or may not have something to do with that. If it's reported and you're going to land at that airport served by the IAP, then it's pertinent. Otherwise, it's not. |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
GPS approach question | Matt Whiting | Instrument Flight Rules | 8 | November 1st 04 10:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
