Gasohol
Old June 3rd 07, 12:38 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
"Jay Honeck" wrote in message ups.com...
You know I've been wondering: Does the Alka Seltzer trick really check to
see if alcohol is present? I'm no chemist, but I wonder if the Alka Seltzer
is just reacting with the water that most alcohols will attract from the
moisture in the air.
How about it? Any chemists in the group? If the mogas were blended with
alcohol with low water content, would the Alka Seltzer fizz at all? Maybe
the best test is still the "line on the beaker" test.
Well, we've been down this road before, back when the Alky test first
came on the scene. Some chemist here ended up concluding that the
test was valid, but I'm always open to hearing other thoughts on the
matter.
If the danged test DIDN'T work, that could ruin my whole day...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Seems to me the best test would be to do the alka seltzer test right alongside the 'water to the line' test, using the
same fuel sample, preferable a known dirty gasoline sample...
  #82
Old June 3rd 07, 02:55 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Peter Dohm
Default Gasohol
"Blueskies" wrote in message
et...
to
Seltzer
with
Maybe
matter.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Two of the more knowledgeable contributors have stated that the Alka Seltzer
reacts with the water.
Logically, one could split a fuel sample into two parts and test both.
Then, if the fuel passes the AlkaSeltzer test and fails the "line on the
beaker" test; then Clare and Bob will have been proved correct and we will
have also gained a means to determine that fuel has alcohol added, but has
not absorbed moisture.
However, if the Alka Seltzer fizzes and the combined water and alcohol rises
above the "line on the beaker"; then the fuel will have failed both tests
and nothing at all will have been proved--because, as far as I know, the
"line on the beaker" does not seperately determine the amounts of water and
alcohol in the fuel sample.
Really, the only way that I know to correctly "do the science" is to
purchase a small amount (perhaps a liter) of anhydrous ethanol from a
medical supply and perform a series of tests on a variety of
samples--including samples of known pure and dry avgas and mogas. For the
moment, I am unwilling to undertake the project, and also I believe that
Clare and Bob are correct.
Peter
  #83
Old June 3rd 07, 03:16 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Default Gasohol
How sure are we that the gasohol in service station tanks contain no water?
Is it possible that all tanks containing gasohol contain at least some water
dissolved?
Is it a certainty that the alcohol added to gasoline contains no dissolved
water?
I don't know the answer to any of these questions. Does anyone know, for
CERTAIN, any of these questions?
My guess is that all service station tanks, (unless they have never had
straight gas, and that they are BRAND NEW) have had an opportunity to get
some water in their tanks. If that is the case, and you put gasohol in
them, the gasohol samples will contain some dissolved water, and the seltzer
test will work.
If that is the case, doing a scientific test with clean gas and adding water
free alcohol will prove nothing.
  #84
Old June 3rd 07, 03:52 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
David Lesher
Default Gasohol
B A R R Y writes:
Ken Finney wrote:
I already am, but there an STC for diesels in 172s.
Running on Jet-A, not Biodiesel.
Which is just kerosene...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
  #85
Old June 3rd 07, 04:06 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
David Lesher
Default Gasohol
ktbr writes:
The joke on us all is that gas pumped to your local distribution
terminal has no alcohol in it... At the distribution terminal are huge
tanks of gas, and smaller tnaks of alcohol, dye, additives, etc...
It is true that all oil companies fuel is essentially the same,
and has been true for a long time.
Anyone here recall Sohio with Winter-Ice Guard?
A) Yes, pipeline carry fuel that is traded widely between companies.
Many times, groups of competitors jointly own the pipeline company.
Inland Corp == Sun, Union, Shell & BP
[There are large efficiencies of scale on same; it costs almost as
much to run a 6" dia pipeline as an 18" one.]
Exception was that no one would take low-end Sunoco as it was lower
octane than regular. [Sun mixed a % of the low end and high octane
right at the pump.]
B) Yes, all the additives are injected at the marketing terminal;
aka where the trucks are loaded. So yes, you should be able to
buy un-altered gas, with the right connections...
  #86
Old June 3rd 07, 05:05 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Default Gasohol
In rec.aviation.owning David Lesher wrote:
B A R R Y writes:
Almost everything on or dealing with airplanes "is just whatever"
with a pile of drawings and specifications to prove to the satisfaction
of the FAA that it is the correct "whatever" right down to the
material covering the seat.
Jim Pennino
Remove .spam.sux to reply.
  #87
Old June 3rd 07, 05:15 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Default Gasohol
dissolved?
water?
test will work.
Finding water free alcohol is basically impossible.
Alcohol will absorb about 2-3% water by volume as soon as it is exposed
to normal air, and that is what you will find in a medical supply
alcohol that is about 98%..
So if everything is kept as dry as possible, you can expect gas that
is 10% alcohol to be at least .2% water minimum.
Whether .2% water is enough to fizz an Alka-Seltzer tablet I have no idea.
Jim Pennino
  #88
Old June 3rd 07, 05:27 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Jay Honeck
Default Gasohol
I don't know the answer to any of these questions, but I've run almost
9,000 gallons of mogas through Atlas' Lycoming O-540, without a
burp.
In that time, I would be willing to bet that SOME ethanol-polluted
gasoline has run though his veins. It almost seems inevitable.
Personally, I am skeptical that gasohol is going to harm my 1974-
vintage aircraft. I use the damn stuff in every other gasoline engine
I own, including my 1986 Goldwing, my 1995 Toyota, my 1995 Ford van,
my 1997 Subaru, my 2000 Mustang, my three lawn-mowers, my two yard
blowers, and my one snowblower -- ALL without problems.
But, hey, if the FAA says it's bad, I gotta believe 'em -- so I test
every tank for alcohol.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #89
Old June 3rd 07, 06:09 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Default Gasohol
No doubt that you engine doesn't give a crap, but your fuel system could be
a different story.
I have seen pictures of fuel line swollen to the size of sausages, and who
knows what the other rubber parts (O-rings, fuel bladders, if you have them)
would look like, and how much alcohol it would take to get it to swell.
I think you are wise to keep on testing. If it were me, I would want to
know if the seltzer test worked as reliably as the add water test, and how
the seltzer would work on a fresh batch of alcohol.
Perhaps you can catch the gas tanker starting to fill a station's tanks, and
get a sample of gasohol right off the tanker, where it is less likely to
have gotten mixed with water, from storage tanks.
Gasohol Blueskies Piloting 240 July 6th 07 12:42 AM
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
