#81
Matt Whiting wrote:
I don't plan to buy one so I have no need to do the math. If you want to prove a point, you do the math. *I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. |
#82
Larry Dighera wrote:
So, are you saying that the FADEC will command a reduction in engine power to reduce heating as the high-temp limit is approached? I'm not absolutely sure on this, but I don't think so. I think it just has an extremely efficient cooling system (overkill, so to speak) which is regulated by FADEC, i.e. reduced to keep the engine temperature high enough. Of course I believe that if one really tries, one *will* find a way to kill the engine. E.g. the POH forbids a sustained power setting of more than 75%. Or, as others have pointed out, remove the coolant before flight. Or if nothing else helps, take a sledge hammer. |
#83
Matt Whiting wrote: Roy Smith wrote: Matt Whiting wrote: It's fully FADEC controlled, so no overheating possible. Automobile engines have been digitally controlled for two decades and they still can overheat. Yes, but they don't overheat because somebody set the wrong combination of three different knobs. What part of "so no overheating possible" didn't you understand? That statement is simply factually incorrect. Matt Taken literally, the statement, "no overheating possible" is indeed incorrect. But, FADEC still gives you a protection against most of the bad things people do to engines through poor technique. |
#84
Stefan wrote:
Matt Whiting schrieb: Drain the coolant and go flying. Tell me how long the FADEC prevents the engine from overheating. Yawn. Dry the oil and go flying. So, you finally admit that the FADEC can't prevent overheating. Matt |
#85
Roy Smith wrote:
In article , Matt Whiting wrote: Roy Smith wrote: Matt Whiting wrote: It's fully FADEC controlled, so no overheating possible. Automobile engines have been digitally controlled for two decades and they still can overheat. Yes, but they don't overheat because somebody set the wrong combination of three different knobs. What part of "so no overheating possible" didn't you understand? That statement is simply factually incorrect. Matt Taken literally, the statement, "no overheating possible" is indeed incorrect. But, FADEC still gives you a protection against most of the bad things people do to engines through poor technique. No question about it. That wasn't the statement made, however. Matt |
#86
Stefan wrote:
Matt Whiting wrote: I don't plan to buy one so I have no need to do the math. If you want to prove a point, you do the math. *I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. No, I never claimed that. Matt |
#87
Matt Whiting wrote:
*I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. No, I never claimed that. Matt You wrote: Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt Of curse I did completely misunderstand you. No, please don't explain. It gets boring. |
#88
Matt Whiting wrote:
Drain the coolant and go flying. Tell me how long the FADEC prevents the engine from overheating. Yawn. Dry the oil and go flying. So, you finally admit that the FADEC can't prevent overheating. FADEC can't prevent to become a moron, either. |
#89
![]() "Matt Whiting" t wrote I didn't see any details on their web site, but if they use a hydraulic coupling then that should isolate the prop during a strike assuming proper design of the hydraulic drive. There is likely though some loss of efficiency as I don't know of any hydraulic drives that are 100% efficient. I read that a clutch protects the engine from prop strikes, and a harmonic dampener isolates torsional harmonics. I take that to mean an isolation rubber dampener, as is common in industrial motors and transmissions. -- Jim in NC |
#90
"Morgans" wrote in news:lX9Oi.32$Mx6.29
@newsfe05.lga: "Bertie the Bunyip" wrote You try letting the coolant out? That would definitely make it easier! Only you would think of doing that. ;-)) Well, the manufacture hopefully would, but being German they would probably say "this cannot happen" Bertie |
100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 09:17 AM |
Old AvGas | gwengler | Piloting | 2 | December 16th 06 01:07 PM |
Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 04:35 AM |
The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 07:27 PM |
Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 07:45 AM |
