Electric Car? How about a Compressed Air Car?
Old November 20th 07, 09:01 AM posted to rec.aviation.piloting
Larry Dighera
Default Electric Car? How about a Compressed Air Car?
On Mon, 19 Nov 2007 23:51:55 -0500, Orval Fairbairn
wrote in
Larry Dighera wrote:
200 watt-hours = 682 BTU. Since there are about 115,000 BTU in a
gallon of gasoline, that implies that the electric car would get the
equivalent of 168 miles per gallon, ignoring efficiency differences.
Ignoring the efficiency differences between a vehicle powered by a
gasoline powered IC engine and an electric motor is useless. Consider
the IC engine converts about 25% of the energy in it's fuel into
useful power. I don't know the efficiency of the Volt electrical
power system, but it could be as high as 95%. Add to that the energy
recovered by regenerative braking...
Regenerative braking is a fantasy! Batteries are not set up to take
high-wattage charging, which is what regenerative braking really is. In
addition, the assumption of RB is that braking is a slow process; in
reality, it is a rather fast process, where the energy of motion is
converted to heat, through the brakes.
You are correct to suspect the physics of regenerative braking, but
that doesn't mean it can't be done. The electricity generated by the
motor when the brakes are applied is stored in a low impedance
capacitor. There's some information about the technique used on an
electrically powered vehicle that has no brakes he
http://www.gizmag.com/go/6104/1/
Another of the tricks employed by PML is the use of a 350V, 11
Farad ultracapacitor. Capacitors are used to store electrical
energy and can release/absorb their energy 10 times faster than a
battery. Using an ultracapacitor means that acceleration or power
boost at higher speeds can get energy twice as fast at peak draw,
offering “nitro-like performance.”
  #82
Old November 20th 07, 01:46 PM posted to rec.aviation.piloting
Yes - I have a name[_2_]
I know I used to buy home heating oil that was 'dyed #2 diesel fuel'. I
wonder if they'll start selling different colored elecricity to homes and
auto charging stations?
"James Robinson" wrote in message
There is another factor that hasn't been mentioned. There is no
tax in the electricity rate to cover highway maintenance or
construction. If electric vehicles really do become that popular,
then something equivalent to the 50 cents a gallon now charged on
gasoline will have to be applied to the electricity used by electric
vehicles. That would add something like 2 to 4 cents a mile to the
electric vehicle cost, to keep the state and federal highway funds
solvent.
  #83
Old November 20th 07, 04:07 PM posted to rec.aviation.piloting
Larry Dighera
On 20 Nov 2007 14:03:46 GMT, James Robinson wrote in
In addition, the assumption of RB is that braking is a slow process;
in reality, it is a rather fast process, where the energy of motion
is converted to heat, through the brakes.
Let's see. An fully-charged 11 farad capacitor at 350 volts can provide
about 15 horsepower for 10 seconds. Not exactly a huge amount of power
storage, but it is something.
I would be better persuaded by your assertion if you provided the
calculations you used to arrive at your conclusion or an objective,
credible source that supports it.
The capacitor would also weigh about 75 lb., so you would have to take
into account the energy cost of accelerating and hauling the extra weight
as a discount against the saving from recovering braking energy.
See above.
A quick calculation suggests that the extra weight hauled for 10 miles
would consume the same amount of energy as one charge cycle of the
capacitor. Accelerating that weight would use about 10% of the useful
charge of the capacitor. Thus, the capacitor has to be fully charged at
least every 9 miles, on average, to simply break even. That might give
some benefit in city driving, but would likely be a cost on a highway.
See above.
Yes, energy recovery from regenerative braking is a reality, but it is
more hype than anything else.
See above.
In the first place, you only get energy recovery when the brakes are
applied. With highway driving, braking is not that common, so the amount
of energy recovered is vanishingly small, and there might be a cost in
hauling the extra weight of the storage medium around.
In my experience, the freeway congestion within 100 miles of Los
Angeles provides ample opportunity for braking.
Second, even when the brakes are applied, you have a couple of issues:
The amount of energy recovered will only be a fraction of the energy
available from braking because of the losses in the charge/discharge
cycle.
What would you expect the efficiency of the Supercapacitor
charge/discharge cycle to be?
http://en.wikipedia.org/wiki/Ultracapacitor
Other advantages of supercapacitors compared with rechargeable
batteries are extremely low internal resistance or ESR, high
efficiency (up to 97-98%), high output power, extremely low
heating levels, and improved safety. According to ITS (Institute
of Transportation Studies, Davis, CA) test results, the specific
power of supercapacitors can exceed 6 kW/kg at 95% efficiency
With batteries, it might be less than 50 percent given the
efficiency losses at high charge rates.
Please provide the data upon which your conclusion above is based.
There is also an economic consideration. The motor and control system
has to be sized to handle the peak power flow,
While that may be a consideration for the control system, I would
expect it to be a non-issue for the motor and the conductors used in
the connecting the battery and the motor, because the time durations
involved should be brief, so any heating due to the overload would not
have sufficient time to cause harm. (Hey, I can guess too.)
and in heavy braking it
might be 10 times that required for acceleration. Consider that an
energy-efficient car might do zero to 60 in say 20 seconds, but is able
to stop from 60 mph in less than two seconds.
The prototype electric Mini Cooper and Tesla Roadster mentioned in
these links seem to do 0 to 60 mph in ~4 seconds:
http://www.teslamotors.com/performan...and_torque.php
The Tesla Roadster’s specs illustrate what it does (0 to 60 mph in
under 4 seconds)...
In the MINI QED, this package offers a 0-60mph time of 3.7 seconds
and a 150mph top speed ...
I'd say that five fold error casts some doubt on your other
unsubstantiated conclusions.
The designer of a vehicle knows that the cost of the motor and control
system varies in about direct proportion to the power to be handled. He
would have to determine whether it would be economically reasonable to
provide a motor that is ten times the size and cost needed for
acceleration just to capture all of the small amount of braking energy
available.
That statement reveals a fundamental misunderstanding. While it may
be true that the active semiconductors may need to be sized for the
peak current, that reasoning is inappropriate for the motor and
conductors.
For a real-world example, look at the current hybrids. They use friction
brakes at highway speeds, and do not recover braking energy
regeneratively,
Where did you get that idea?
http://www.toyota.com/prius/specs.html
Brakes Power-assisted ventilated front disc/rear drum with
Anti-lock Brake System (ABS) and integrated regenerative braking
so you can see the designers did not figure it was worth
it to capture all of the braking energy. The same principle would likely
apply to all-electric vehicles.
With all due respect, you talk as though you have all the answers, but
fail to provide a shred of hard evidence, let alone credible sources,
to support your assertions. Lacking that, I am unconvinced of your
arguments.
  #84
Old November 20th 07, 04:30 PM posted to rec.aviation.piloting
Scott[_5_]
On 20 Nov 2007 14:03:46 GMT, in rec.aviation.piloting, James Robinson
You keep saying "highway". Most if not all of the pure EVs I know of are
pretty well targeted for city driving; short hauls, relatively low speeds,
and frequent stops.
-Scott
  #85
Old November 20th 07, 06:27 PM posted to rec.aviation.piloting
Denny
solvent.
ehhh heh heh, I see in the future the public treated like farmers are
with fuels. Where they have to pay a road tax on every KWH they use
from the power company then file for a refund for the KWH use din the
home and not for charging their car.... Should be a hoot to watch...
  #86
Old November 20th 07, 06:30 PM posted to rec.aviation.piloting
Denny
When you are talking about battery packs with the capacity of "all electric"
cars, I'm not sure (but have a definite opinion) about how true that is.
When you have a 200 amp pack, and you can safely charge at up to 10 C, that
would be a 2,000 amp charge capacity! That is a hell of a lot of juice. I
can't imagine anything but an emergency braking exceeding that!
To handle braking loads, perhaps we can dump the braking energy into
a super capacitor bank and then use that to invertor charge the
battery at a normal rate...
  #87
Old November 20th 07, 08:11 PM posted to rec.aviation.piloting
Larry Dighera
On 20 Nov 2007 19:35:03 GMT, James Robinson wrote in
Yes, electrics tend to operate at relatively low speeds, with stops, but
low speed stops generate very little energy to be captured.
If I monitor the instantaneous Miles Per Gallon readout in my car,
it's clear that a lot of fuel is used to accelerate the vehicle to
highway speeds. Intuitively, it would seem that the potential energy
recovery would equal the energy expended to accelerate the car, less
efficiency losses such as drag, friction, and electrical system
inefficiencies. Are you saying that's incorrect?
If you
captured all of the energy available from a stop from say 30 mph, with no
efficiency loss, that energy might propel the car an additional 250 feet
at 30 mph. Maybe say 150 feet additional per stop to account for
efficiency loss.
Of course, the energy recovery doesn't solely occur when the vehicle
stops, but during all deceleration.
http://www.toyota.com/html/hybridsyn...nter/4wdi.html
How it works
The key 4WD-i components are the Motor Generator Rear sensors or
"MGR" and electronic control units. ... The MGR also captures
kinetic energy upon braking, deceleration, or coasting and uses it
to charge the hybrid battery pack.
  #88
Old November 20th 07, 10:19 PM posted to rec.aviation.piloting
Gig 601XL Builder
James Robinson wrote:
It seems the state revenuers are on the case, but trying to
differentiate where you got electricity to charge your vehicle is
going to be a real challenge, as you can't dye electrons.
It seems the easiest would be to do what most states already do which is
record your odometer reading each year at registration renewal and have you
pay on a cost per mile basis.
  #89
Old November 20th 07, 10:44 PM posted to rec.aviation.piloting
Larry Dighera
On 20 Nov 2007 21:27:32 GMT, James Robinson wrote in
I know of a person who owns a Mercedes diesel who was pulled over by a
revenue officer to check that he wasn't using dyed fuel in his car. The
officer got a sample of fuel, and put a test chemical in that enhances
the dye as a check. When he confirmed the fuel was legal, he sent my
friend on his way. It shows they do check in some states.
It also proves that, without probable cause nor a warrant, the LEOs is
some states have no issue violating the fourth Constitutional
amendment guaranteeing against unreasonable search.
  #90
Old November 20th 07, 10:51 PM posted to rec.aviation.piloting
Gig 601XL Builder
is record your odometer reading each year at registration renewal and
have you pay on a cost per mile basis.
The problem is that paying once a year might mean people get a big
surprise. In the Oregon experiment, where they are charging by the
mile, the odometer is read when the car fills its tank, and the tax is
automatically charged to a credit card based on the difference from
the previous reading. At least that way, a person pays smaller
amounts more frequently, and shouldn't get an annual shock, and the
state would lose less money if a person couldn't pay.
Well you could pay a monthly or quarterly amount in arears. Say it is a
$0.10 a mile and this year I drive 10K miles. I then have to may a montly
tax of $83.33 per month the next year.
Remember if we are all electric there won't be a time where you have to go
somewhere and fill up.
Compressed air as fuel? Dancing Fingers Home Built 15 July 14th 07 07:20 AM
Electric DG Robbie S. Owning 0 March 19th 05 03:20 AM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? Gil G. Rotorcraft 9 July 30th 03 12:36 PM
Pre-Rotator Powered by Compressed Air? nuke Rotorcraft 0 July 28th 03 12:52 AM
